Question about Maytag Performa PAV2200
My perfoma pav220aww will not spin at all. I checked the belt and its ok but i found white plastic shavings all over the bottom.
  • Anonymous Mar 19, 2009
    my performa washer is spinning but clothes are soaking wet when I take them out to put in dryer...
  • 100 Answers
SOURCE: frigidaire front loader washer
one of the welds on your inner stainless steal tub may have broke causing the drop of your tub.  The tub has a warranty on it but the labor to put it in is around 3hrs give or take any hour.
Posted on Oct 30, 2007
  • 4088 Answers
SOURCE: duet ghw9100 washer clunking noise on spinning
With the machine off, push upward on the inner drum and release. If the clunking sound occurs and the drum seems somewhat loose, likely the front main bearing for the drum is damaged and must be replaced. Major tear-down!
Posted on Nov 28, 2009
barkencoa
  • 3463 Answers
SOURCE: Drum runs rough on spin. Plastic shavings in the
It is plastic of the outer drum that is being shaved off by the inner drum due to it running off center.
To replace the bearigs is a major undertaking, as it involves a strip down.
Posted on Dec 20, 2009
SOURCE: my washing machine started to make a loud grinding noise
My washer is making loud noise when washing.
Posted on Feb 15, 2010
  • 670 Answers
SOURCE: Hi There: Our machine makes a
You did not supply the make and model of the washer. But from your description, it seem like you have a front load washer. The problem you describe sound like the support arms that hold the wash drum are broken. It is a big job to fix and also an expensive one unless it is still under warranty. The wash drum and spider will need to be replaced at a minimum, if the outer wash tub is damaged, it will also need to be replaced. The wash tub is made of plastic, and it is being damaged with the wash drum scraping the insides of the tub. To repair the entire washer needs to be disassembled and the drum and tub needs to be removed. The parts and labor most likely exceed the cost of the machine. Sorry.
Posted on Oct 14, 2010
Plastic Shavings in drum
Sound like you've got a balance problem. You can check your 2 front shocks by removing in the bottom front panel. You can check the 2 back ones by removing the whole bacl panel. My drum spindle housing cracked from all the hard water.
Jun 19, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
My perfoma washer is not working on the last Spin CYCLE
timer bad as far as balance is unit level on flat surface
Jan 18, 2010 | Washing Machines
Indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Aug 04, 2009 | Indesit W 123 Front Load Washer
My washing machine started to make a loud grinding noise and does not rotate to wash nor to spin. after moving the machine i found some plastic shavings under it.
Sounds like the bearings for the drum have or are on the way out. The belt has probably broke or come off.
Depending on the age, cost of new and personal feelings it can be repaired but normally it isn't cost effective, unless the machine cost £500+ ($800+)
Jun 14, 2009 | Washing Machines
No spin
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me plz……………………….
Apr 10, 2009 | Washing Machines
Amana NAV2330 Wont Agitate or Spin
i would assume that perhaps you did not wind hte belt correctly arround the legs of the pump and therefore are not putting the correct tension on hte pulley(remember to hook spring back up to tension idler?)
Dec 08, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore elite top load ms9711174
THE KENMORE TOP LOAD WASHER HAS A CLUTCH AND DRIVE COUPLING THAT IS PART OF THE SPIN CYCLE.
THE DRIVE COUPLING ATTACHES THE MOTOR TO THE TRANSMISSION AND IS MADE OF PLASTIC AND RUBBER.
IT COULD BE GETTING HOT AND TORN. THE OTHER POSSIBILITY IS THE CLUTCH MAY BE SLIPPING. THERE COULD BE OIL THAT HAS GOTTEN INTO THE CLUTCH AND SO THE CLUTCH WON'T GRIP. PULL THE CABINET OFF OF THE WASHER OR TIP IT BACK AND CHECK THE FLOOR FOR BLACK OR WHITE SHAVINGS OR OIL. THE SHAVINGS WOULD BE FROM THE DRIVE COUPLING AND THE OIL COULD BE FROM THE TRANSMISSION OR THE SPIN TUBE.
Apr 01, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
102 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
