Question about Altec Lansing 121 2.1 Speakers w/ Subwoofer Computer Speakers
Need cable for the input for the subwoofer - Altec Lansing 121 2.1 Speakers w/ Subwoofer Computer Speakers
  • 62 Answers
How do i conect supwofer out put ?
You need a mono RCA subwoofer cable (http://www.amazon.com/Belkin-PureAV-Subwoofer-Audio-Cable/dp/B0001XGR1C/ref=sr_1_5?ie=UTF8&qid=1425294043&sr=8-5&keywords=Subwoofer+cable.
Down where the speakers hook up to the rear of the unit there is a subwoofer output RCA connection. Plug RCA cable in there and run it to the Input of the powered subwoofer.
Mar 01, 2015 | Sharp CD-DVD500 System
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
How to Connect HT-CN300 Subwoofer to Onkyo TX-SR313?
Hello! You will most likely need a RCA cable with single ends (both being male ends) One end plugs into your subwoofer input....marked subwoofer input on the subwoofer..........The other end will plug into your receiver that is marked subwoofer . When low frequencys from your media.....whether dvd,s /cable or audio cd,s is present the sub woofer will kick in , Make shure to adjust your setting on the rear of the sub if it has any like volume or frequency , most better subs have them as where the home theater in a box combo usually does not!
Jan 01, 2014 | Sharp HT-CN300 System
I have a s108sp subwoofer with a right and left input assuming this is for a cable going to one input on my Sony reciever. The subwoofer also has inputs for speakers. Do I plug the speaker wires into...
Hey there houleo!
If your subwoofer has a stereo input and stereo outputs, then it's a good idea to send the signal from your receiver to the sub, then out to the other speakers you have hooked up. Some subwoofers will take the low frequencies out of the signal to the left and right speakers, so that the sub handles it alone. This often gives a nice crisp sound.
Reciever/amplifier
l l l l V V Subwoofer l l l L------> Right speaker
V Left speaker
If this helps you out, I'd appreciate if you rated me well :) If you've got any more questions, feel free to ask! Cheers! -The Chicken
May 26, 2011 | Acoustic Research S108PS Subwoofer
THERE IS NO SIGNAL COMING FROM THE SUBWOOFER, IT IS CONNECTED TO A SONY AMPLIFIER IN THE SUBWOOFER JACK, AND CONNECTED TO THE SUBWOOFER IN THE LOW LEVEL INPUT. THE SUBWOOFER IS CONNECTED TO THE MAIN, AND...
With everything connected correctly there could be a couple of possible problems:
1. If your receiver has on screen display capabilities, you may need to turn the subwoofer output "on"
2. If your subwoofer has speaker wire inputs/outputs, you could run speaker wire to it, then to your speakers & test if the subwoofer is working... hence verifying that the receiver has a function to turn the subwoofer output on/off
3. The cable between the subwoofer & receiver could be bad. Try another cable.
Mar 16, 2011 | Audio Players & Recorders
What kind of wire do I need to connect the subwoofer to the av-d58? The subwoofer is the same that came with the receiver but I have somehow misplaced the connection wire.
Without knowing more about the subwoofer (powered, passive, what kind(s) of input it takes, I have to take a wild guess. Most powered subwoofers use the old standard RCA cable. I there are two jacks on the sub for Left and Right input you just get an adapter to make the cable plug into two jacks.
Dec 01, 2009 | Aiwa AV-D58 Receiver
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
Can't connect subwoofer to onkyo av receiver
you would need a y jack to connect those to the receiver
Feb 16, 2009 | Onkyo HTR500 Receiver
How can i connect an mp3 player on my Power Acoustik PTID-4007
Expandability Options:
  • 3 sets of preamp outputs (front, rear and subwoofer)
  • Telephone Mute trigger wire for Bluetooth adaptation
  • iPod Ready: IC-1 iPod Connection Cable Required and Sold Separately
  • Front-panel auxiliary input: Mini USB input and SD Card slot
  • Rear auxiliary input: 1 back-up camera input and 1 A/V input
  • 1 Video output
The aux rear a/v input should do the trick.
If it is a component (RCA) type input, you will need a Male 3.5mm to dual Male RCA adapter.
If it is a 3.5mm input, a Male 3.5mm on each end.
I believe you will need the Dual RCA (red/wht) to 3.5mm cable.
The Audio inputs are purple RCAs on the back of your head unit.
Jan 14, 2009 | Car Audio & Video
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
