Question about Microwave Ovens
Installing a Whirlpool over the range microwave oven, just trying to figure out if I have to vent it outside or not. Instructions say venting outside is not necessary if you have a recirculation system. What exactly does that mean? The unit is set up by default to recirculate, so do I not need to vent it outside?
  • Anonymous Apr 29, 2009
    I don't have a manual to install this microwave, need to know how to install it
    Scholar:
  • 87 Answers
I would say that you do not have to vent it outside. One of the most common complaints I get is that the microwave is not sucking up a lot of air. I have called Whirlpool and they have said that most of these newer microwaves don't really have a lot of air movement in them and they have smaller blower motors. Some of this was due to the fact that people didn't like the noise of a big fan that was necessary fo move air. I have noticed this on my own also. When boiling sweetcorn this summer, it would barely **** up the steam whether it was recirc or to the outside, I usually test them by putting a cleenex under the vent abd see if it holds it there. Bottom line is they really don't move a lot of air and it's not worth the cost and time of venting it out. Hope that helps
Posted on Mar 08, 2009
Installing a microwave / convection oven above a stovetop
Needs to be properly vented to outside the house. Only install a microwave that's designed for over-stove use in this space.
Aug 25, 2014 | Microwave Ovens
I'm installing a new Over Stove Microwave. Want to do outside vent, but a 2x4 stud blocks the 10" wide rectange of space needed for vent. Is it possible to vent up through cabinet above then...
When you say "outside vent" do you mean horizontally through an outside wall? If that is what you are trying to do having the 2x4 in the way does not make much of a deterrent. But if it makes you feel better, moving over a bit and not have the 2x4 in the way, that certainly would be better.
Sep 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
We have a sharp 1480 and have to mount it with no outside vent. Can this be done? patqlt@verizon.net
Most of these over the range models come already set up for unvented operation. That is, set up for use with no outside vent. The oven will filter air through the a charcoal filter inside the upper grill and the vent covers underneath. If you ever wish to change the operation to allow the unit to vent outdoors, you need to change the direction of the blower fan assemby inside the top of the microwave oven. These instructions should be listed in the installation manual that comes with your oven.
Aug 16, 2010 | Sharp R-1480 Microwave Oven
Is there a piece I can install on the bottom of my over-the-range microwave that will help keep the front of the microwave from being covered in steam when cooking on my stovetop?
Every over the range microwave has a vent on it that should be venting that steam. I don't know of anything you could put under there that would solve your problem as that is where then vents are and they would be blocked. It sounds to me as though your steam is not being vented properly, and this could also happen if the steam is being vented back into the room instead of outside as many OTR microwaves allow you to do. Its a little bit of work to vent it outside but I myself did that with my microwave and have never had a steam accumulation problem.
May 03, 2010 | Maytag Appliances Over-the-Range Microwave...
Samsung Microwave for over the range vent issue
Most over the range models can be vented to the outside, or they can be set up (sometimes requiring a special adapter) to recirculate with a charcoal filter.
It depends on the model, and you would of course have to consult the installation instructions to be sure.
You can download many Samsung over the range microwave installation instructions here.
You may need the free DJVU viewer to view or print your manual.
You can order Samsung parts here.
Dec 05, 2009 | Samsung Microwave Ovens
I dont have a vent for above range microwave oven
It doesn't have to vent outside. These are designed to recirculate the filtered air back into the room. If you cook without a range hood now it will work fine for you.
Eric
Oct 29, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool microwave oven mh7155xmb0 not venting
Possibly a bird built a nest (swallows) in or on the roof vent. Make sure the fan turns freely when off. Check the vent tube that goes up to the roof--if flex-tubing, it may have collapsed and pinched off the air flow (it may be too long). Make sure that a one-way valve which should be near the exit of the hood is free to move when air flow pushes on it. This valve is supposed to prevent back-flow of air into the house. Hope this helps!
Mar 09, 2009 | Whirlpool MH7155XM Microwave Oven
Fan on over the range microwave does not have enough suction to **** the steam from stove through the microwave. Does the blower get turned a certain way for this to work? Is there a .pdf operational...
This may be caused by a weak fan, improper installation, clogged filters, blocked air ducts, or a blocked outside vent.
Assuming yours is a Whirlpool, you can download Whirlpool owner's manuals and installation instructions here.
This will help you check the mounting and setup, as well as helping you check the filters to see where the problem lies.
Please write back with your brand and model number if you yours is not Whirlpool.
Jan 02, 2009 | Whirlpool MH1170XS Microwave Oven
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
1,864 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
