Question about Philips GoGear HDD075/17 MP3 Player
How do you charge a 2bg go gear? trued laptip but no luck
  • 8,596 Answers
Some slightly older laptops generally do not have enough power to make an mp3 player properly function. Make sure the USB ports on the laptop are USB 2.0. Also, the Go Gear HDD series had a proprietary adapter which required you to plug it into the computer and the wall simultaneously. Do you have the proprietary adapter?
Posted on Mar 25, 2009
2 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: how do you charge a 2bg go gear? trued laptip but
Your laptop has to have a USB 2.0 port. Many laptops do not even have enough power to properly run an mp3 player. If your laptop is definitely compatible, here is the method to force recognition (note: the Philips HDD series of GoGear needs a proprietary adapter, so if your model # starts with HDD, make sure you have the original adapter):
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
Posted on Mar 26, 2009
My hunday accent 1999 model feels as if it dosnt have power and sometimes when i push the petrol peddal it veels as if it dosnt get petrol tru fast enough i have replaced the carborator and cleaned out the...
most shops will charge you a minimal amount to put it on a diagnostic test. If you have done the work yourself I would suggest pulling the test plug on your catalytic converter and if that increases power it needs to be replaced. good luck!
Oct 17, 2013 | 1999 Hyundai Accent
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
Oct 04, 2013 | Uniden Lands Phones
Tru-test tiller parts
Is there a bushing on the front of the drive on a tru-test tiller
Apr 11, 2012 | Garden
Dont know how to connect tv to reciever so sound go threw surround sound reciever
Well depending on what kind of tv or reviecer you have ,,,if you using standard rca jacks,,red,yellow,white,,,,the hook to reciever to tv ,,or availble input,,should be a place on the tv that just has the red and white by itself ,,hook there,,but tru surround sound is digital,,either a optical cable or hdmi,,depending on your gear,,but tv doeant run surround ,,really,,but dvd,,or blu ray like that does,,k good luck,,
Nov 20, 2010 | LG Televison & Video
Nokia N97 usb block has degraded to the point it wont charge unless balanced on an object. does anyone have a guide on how to replace the usb block connector and where i can get one? \r\n warrenty was...
well you will have to change the charging point and u can always do that at a phone repairs shop or take it to the company shop nearest to you for repairs and if you dont want to go tru that stree you can always charge your battery tru desktop charger , thnks .
Jun 15, 2010 | Nokia N97 Cell Phone
Tru GDM-47 cooler evaporator icing up.
possible bad defrost timer,or control on an off is bad,were you adjust temperature...thermostat from 30 to 65.00 dollars....possible there is leak or unit is under or overcharged..more than likely under charged...possible defrost heater is not working...good luck..michael doctor airr appl.repair..service tech..843-384-8474...call if need additional help ..its free..
Mar 27, 2010 | True GDM-47-RL Refrigerator
How do you charge a 2bg go gear? trued laptip but no luck my in mp3 it won't come on
Mar 25, 2009 | Philips SA920017 MP3 Player
Uniden hand set
What is the model # of your handset. It must be tcx 900 or tcx 905 to be compatible with the tru 9488. Good luck! :)
Jan 12, 2008 | Uniden TRU9488 Phone
Philips GoGear HDD075/17 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
