Question about Dell System Board for Optiplex GX 150, PIII DELLGX150SB-06 Motherboard
My monitor does not show
When i switch on my computer the monitor shows nothing on it
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    try reseating the memory into the slot. If you have more then one stick of memory then try one at a time in each slot until the memory comes back up.
  • 87 Answers
Make sure the video cable and card are plugged in properly. Does the monitor power light come on?
Posted on Mar 08, 2009
Reasons of y signals not going to the monitor
Is the monitor showing a blank screen or is it showing the message NO SIGNAL??
If you have a Desktop try the steps below:
If it is showing the message NO SIGNAL, then the video card in the computer is bad, because when the monitor is bad, it will show nothing at all. To isolate the problem plug another monitor on the computer and see if it displays. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok, then your original Monitor is bad. If the Borrowed monitor displays the same as your original, then the video card in the computer is bad.
If it is a laptop try the steps below:
May 24, 2012 | Intel Motherboard
Computer comes on but nothing show on monitor u can hear the fan but nothing show on the monitor
  1. Make sure that your monitor cable is plugged into the back of the computer, also sometimes depending on the setup of your computer there can be 2 places to plug you monitor into on the motherboard, if you see another port that looks the same try plugging it into that one and try again.
Feb 15, 2011 | Compaq Presario 5WV270 (202498-003) PC...
When switch on my monitor it shows nothing but the led indicator is on mode
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Monitor turns on and computer runs monitor is plain
look like ur RAM is crrupted...if u can see some alpha numeric char while starting then screen is OK
or Windows may be corrupt...
May 08, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Nothing is showing on the monitor
just your monitor back panel open next monitor neck board put dry solder
Sep 26, 2009 | Compaq Computers & Internet
Monitor shows ''NO SIGNAL''
This is normal. The monitor is telling you it is not getting a signal from the computer, which is true because you've turned off the computer. The monitor power is still on, however. The monitor power is not controlled by the computer power switch. Just turn it off with its power switch after you shut off the computer.
Nov 23, 2008 | Computers & Internet
My P35 S-611 not show VGA video
Check the refresh rate of the LCD, may be too high. Try at 60hz first.
Set the display to 1024x768 or 800x600 then go higher... allowing it to revert back to previous mode if nothing shows.
(some/most CRT monitors cannot display widescreen format)
Set at 60hz using a CRT (you will see flicker on CRT) - then switch to LCD
Apr 18, 2008 | Toshiba Satellite P35-S611 Notebook
Computers & Internet Logo
83 people viewed this question
Alun Cox
