Question about GE WBVH6240F Front Load Washer
Drum won't Tumble or spin
All diagnostic tests work except "t10". "t11", and "t14". When I push start for these 3 tests, the machine beeps twice instead of once and nothing happens. The machine also doesn't return an error code.
  • 240 Answers
Check motor winding resistance. new motor comes with motor control unit. main controls are not common on ge
Posted on Apr 27, 2009
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Washer won't drain
DIAGNOSTIC MODE
To enter diagnostic mode follow the steps below.
1. Turn the power on at the power point but off at the machine.
2. Press and hold WASH TEMPERATURE SETTING DOWN and then press POWER until the
machine gives 2 short beeps and lights up.
3. Release the buttons after the beeps as the beeps indicate diagnostic mode has been entered.
4.1 Last Fault Data
When in diagnostic mode the last fault can be found by pressing the SPIN SPEED UP or DOWN
buttons until the HOLD and SLOW lights are illuminated. Binary can then be read from the wash
progress lights.
4.2 Drain Pump Test
MW Washer
When in diagnostic mode press SMART TOUCH CYCLES to activate the drain pump. To
deactivate the pump, press SMART TOUCH CYCLES again.
GW Washer
When in diagnostic mode press REGULAR to activate the drain pump. To deactivate the pump,
press REGULAR again.
4.3 Water Valve Test
The water valves can be activated in diagnostic mode by pushing WASH TEMPERATURE SETTING UP to activate the Hot Valve and WASH TEMPERATURE SETTING DOWN to activate
the Cold valve as with previous models.
Pressing each button once will activate the valve. To de-activate valve press the same button
again. This is also good to use when installing machines as it takes the shock out of the fittings
and seals and allows checking for leaks on the inlet hoses, both machine end and tap or super-tub
end.
Caution: Do not leave the machine unattended when either or both valves are operating
May 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
Kenmore model 417-44052400 front load washer error code E04 (5 vertical LED flashes & beeps and 4 start led flashes. I ran the diagnostic test, it dose everything up to tumble, it won't tumble or...
Take the front lower panel off 2 or 3 screws you will see the pump.You will see a black "baffle" atatched to the pump.squeeze it feel a sock?Take the boot loose and clear.Only other thing would be the motor control board back let hand corner replaced many of these when tubs dont move.I hope this helped.
Nov 17, 2009 | Crock Pots & Slow Cookers
Maytag Neptune TL electronics problem
neptunes are known for the control board, spin bearing and wax motor going bad. replace unit
Jun 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Kenmore 44092500 Won't complete spin cycle
AllExperts.com gave me the answer I needed at no cost.
Jul 29, 2008 | Kenmore Energy Star 44092 Front Load...
I ran the test program and found faults
No you will need to check the motor controller board
Nov 21, 2007 | GE WBVH6240F Front Load Washer
Washer won't start
First of all, does the washer make a distinctive "click" when you push the START button? This is an indication that your door latch is locking (or at least making an attempt to lock). Normally, however, the display would have an "fdl" fault code indicating a door lock failure if it were bad. I have seen the latch go bad and not register a fault code, though. You can perform this simple diagnostic test to see if any fault codes register: 1. Select DRAIN/SPIN 2. Under SPIN SPEED select NO SPIN 3. Then, under OPTIONS push the PREWASH button 4 times. You should hear the door latch click then "C00" will show on the display. The washer will begin a series of tests (C01...C05 - depending on options and model) by testing the hot and cold fill valves, the various dispenser compartments, followed by tumble, drain and spin. If there is something wrong the diagnostic test will abort and a fault code will be displayed. The washer usually beeps when it displays a fault code. If you attempt to perform the diagnostic and the display momentarily flashes after you press the PREWASH button the fourth time and goes out, this can also be a symptom of bad door latch. You need to perform these simple steps first in order to further diagnose. Let me know what you come up with.
Jun 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
GE WBVH6240F Front Load Washer Logo
249 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
