Question about Poulan Garden
Feather lite cord will not retract after starting however when you turn it off the cord recoils.
3 Suggested Answers
  • 203 Answers
SOURCE: Weed eater Feather Lite Blower - replacing pull
This should help you out. Go to Poulon's website. Look for a tab to "order parts". Model is fl1500. That will take you to a page that you can look at the blower "chassis" to order parts. That shows you how the bottom housing goes together. You have to take off the bottom housing, the blower fan, the top housing. That should take you to the starter cord mechanism.
Good luck.
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=FL1500 Gas Blower Type 3&AFID=59
Posted on Nov 21, 2009
2strokeguy
  • 183 Answers
SOURCE: I have a Homelite Mighty Lite 26cs gas weed
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Posted on Aug 20, 2010
Pull cord will not retract
remove the recoil section and replace the broken spring
Aug 07, 2016 | Garden
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
My weedeater pull rope won't retract back inside when pulled to start, how do I fix this?
Spring is likely sprung out of the recoil. Take the recoil apart, rewind the cord and turn it enough to put some tension on it. Then put the cover back on.
Oct 04, 2014 | Troy Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pull cord engaging
recoil clutch fingers are broken or stuck. Take the recoil cover off and look at it while pulling the cord to see if the fingers arent coming out. If the fingers are still coming out then you have worn out grooves on starter cone where fingers engage to turn the motor. If the recoil is damaged a new one can be purchased as a unit from Troy Bilt online for a reasonable price.
Jan 25, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Cord will not retract
you have a top piece on the recoil assembly which im trying to find now but replae that and it should fix your problem
Aug 14, 2010 | Homelite Mighty Lite Lawn Trimmer
Hello, my mighty lite 26 ss weed waker is broken. The starter cord will not retract. it stays out and I am unable to start the engine. what is the problem and how do i fix it? thank you
You will have to disassemble the unit to that point and inspect the recoil pulley (rope coils on it) and the ratchet mechanism under it and the recoil spring that draws the rope back in.
Aug 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Need to replace recoil rope how do i get the feather lite xt260 apart
Most of these units are assembled with Torx (Star) screws. You will need a few different sized drivers of these to get to the recoil unit. Take your time and pay attention what screws went where. If you like, sketch drawings of complicated parts help for reassembly later.
Jun 08, 2010 | Garden
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
Jun 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
48 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
