Question about LG Studioworks 700S 17" CRT Monitor
My lg monitor has turned green how to fix it - LG Studioworks 700S 17" CRT Monitor
  • Anonymous Mar 27, 2009
    Same problem. Model: Studioworks 710s
    Green screen tried resetting the monitor, tried unplugging it and replugging it, nothing seems to work
  • arulkum Mar 29, 2009
    i am also facing the same problem.. but its still not working the same
  • 4 Answers
A common cause of a green screen is simply that the cable is not securely connected to the video card. Try to unplug the monitor cable from the back of the computer, and then plug it back in again and securing it with the thumb screws if possible. If that does not work, there may be a reset option in the monitor's configuration menu.
What make and model is your monitor?
Is it a solid green color? Does it change after a period of time being left on?
Posted on Mar 08, 2009
Space bar was blue but is now green ..there's a green hue when pc is on
use warranty to replace problem with electronic expensive to fix then monitor
Aug 06, 2012 | LG Flatron L1810B 18.1" LCD Monitor
The lg fratron ez. H713sh is flashing a green led and nothing is coming on e display, thought of connectng otha monitors bt didnt succeed.
If you get the same result with the other monitors, you may have to replace your VGA card.
First turn off the system.
Remove the VGA card from your computer.
Clean it and fix it again. This might fix the problem.
If you get the same result, replace your VGA card.
Jul 12, 2011 | LG Studioworks 552V 15" CRT Monitor
My montor is going green in place how can i fix it
move the speakers away from it the magnet is pulling the color out of the screen :)
Jan 27, 2010 | LG 19 Widescreen LCD Monitor, 1440X900...
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
My lg monitor has turned green how to fix it MY MONTIOR FLICKERS AND TURNS GREEN. IT DOES SHOW THE REGULAT DISPLAY COLORS SUMTYMS BUT WITHIN MINURES IT AGAIN TURNS INTO A GRENISH TINT DISPLAY.
This could be a sign that the monitor is failing, but it could also be a very simple solution as well. There should be two cables that come from the back of the monitor - one is the power cord and the other goes to the back of the computer. You will want to disconnect the cable from the back of the computer and then blow out the end with the pins in it (either with a deep breath or a can of compressed air. Now connect the cable back to the computer. You may need a screwdriver to remove the cable and you definitely want to make sure the cable is screwed in after you reinsert it even if it wasn't when you removed it.
If the display still shows a green tint, perform the same steps where the cable connects into the monitor. Some displays don't allow this part of the cable to be disconnected from the monitor, so you may be unable to perform this step.
Hope this helps,
Chris
Mar 23, 2009 | LG Studioworks E700S 17" CRT Monitor
Problem with LG 22 inc monitor TV
please calrify it's just one pixel that is permanently green? if so then it's blow and you have to hope it's under warranty, live with it, or get a new one.
Dec 02, 2008 | LG L1915S 19" LCD Monitor
No picture and flashing green light
If u'r PC is OK, then this problem is showing when the main PCB of the monitor failed. This is 3 yr warranty monitor, contact the LG service provider in your area. They will change the PCB. Here is the link to get the service center info
http://www.lgservice.com/
Feb 25, 2008 | LG Flatron L1715S 17" LCD Monitor
LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Nov 27, 2007 | LG Flatron 995FT 19" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
1,417 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
