Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Moving the frig.
Some one gave me a kenmore top freezer 2002, when he move it he but it on its side. Will this cause a problem? I was told not to plug it in for a coupble of days. What should i do.
thanks for the help
  • nocody1 Mar 08, 2009
    will it matter that it was plugged in for about 20 min. after standing it up
  • 30 Answers
Yes,let the unit set in the upright position for 24 to 48 hours before plugging it in.
Posted on Mar 08, 2009
  • Joey Terry Mar 08, 2009
    This really depends on if the oil migrated from the compressor while it was laid down. If when you plugged the unit in it started running and cooled off then you are Probably ok, if on the other hand the compressor was very loud and you let it continue to run it could have damaged the compressor.
My Frigidaire refrigerator is at 60 degrees Fahrenheit and will not cool down
There are a few possibilities. First, Is the freezer portion working okay? If yes, then the problem is blocked air flow from the freezer to the frig. If no, then the cooling fan could be bad or the thermostat could be bad. First check for temperature in Freezer section, should be about 4-8 degrees no more. If it is cold, then locate the cooling fan behind the back of the frig and see if it is moving or listen for movement. If it is moving then rearrange the food in your freezer compartment.and frig compartment away from the vents. If it is not moving, then the thermocouple could be bad. compressor problems and freon leaks are not that common unless the frig has been moved alot. The cooling fan or thermocouple or overstuffed freezer compartment are the usual suspects in 90 % of cooling problems. cooling fans and thermocouples can be cleaned by using canned compressed air to remove dust which will sometimes cause a failure. The parts are inexpensive but labor is about $80. Start with the freezer because all of the cooling for the whole unit starts in the freezer.
Dec 18, 2010 | Frigidaire Refrigerators
Amana side by side refrigerator wont cool properly after moving from one house to another
have a two year old side by side amana frig. the freezer side works fine, the frig is at 56 degrees at coldest setitng. HELP, can't get repair guy for five days cause we live in rural area.
Apr 19, 2010 | Amana ARS266ZBS Side by Side Refrigerator
The fan in my freezer was making a loud noice for several weeks as if it was having a hard time starting & now it is not working at all. The temp. in the freezer still remains the same. What will that...
Without a freezer fan the temp. in the frig will rise and the milk will spoil. After more days the temp. in the freezer will rise as well. Without a freezer fan the air is not moving, so naturally the the evaporator will ice up. Worst case the motor will smell like burnt. the frig will suffer 1st then the freezer. someone can get sick be careful. hope this was helpful replace the motor
Mar 30, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
My kenmore refrigerator side by side
All the cooling takes place in the freezer and is blown over to the frig side so the frig side will start to warm up soon. Possible cause is the starting device to the compressor is faulty, compressor motor locked up or cold control faulty and not closing.
Feb 19, 2009 | Kenmore Refrigerators
Fridge not cooling
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer not working
is there frost building up in the freezer?mike
Nov 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Refrigerator Ice Maker
it sounds like your inlet water valve is not closing all the way,pull frig out turn water off,remove valve get model number from inside the frig. and replace it,let me know-mike
Jul 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer and refrigerator run but is not cold
Andeb, couple of things you want to check. Is the fan in the freezer section running? Take the lower back panel off and see if the condensor fan is running as well as the compressor. As long as you tilted it only slightly I would think this is a fan or overload relay problem. Check the things I mentioned and post back...Catriver.
Aug 21, 2006 | Kenmore 50522 / 50524 Side by Side...
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
74 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
