Question about Acer Aspire 5500 5570-2609 Laptop
Audio driver is installed but till windows media player is not working and giving the message that sound system is not installed properly.
  • 4 more comments
  • supriyophy16 Mar 08, 2009
    Means i installed the realtek high defination audio driver but still it is showing that audio driver is not installed properly.Yes there is some
    blue question mark there in device manager.The yelow marked device are bluetooth audio,ethernet controller,mass storage controller,pci device,and usb20 camera.
    Windows xp is my operating system
    Which kind of specification i am not etting properly.After formatting i tried to install the drivers from the driver cd.but we cam and audio driver are not installing properly.
  • brownleopard
    brownleopard May 11, 2010
    Have you tried to update your drivers?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    What Operating system is on your computer? Your missing alot of drivers.
  • Ben Wabnick
    Go into the device manager and let me know if there are any yellow question marks.
Windows media player throws error when I play any audio
As you may have already notice, there isn't a problem with your driver.
However to gain a better understand the problem you rule out a couple of things. However, if the this problem is only present in windows media player. Then you should try another play i.e. VLC media player.
1. Go to you device manager and make sure the device is working properly. If not try uninstalling the device, restarted the computer letting windows discover the device again.
2. Next go to windows media player file (press "alt" key to get toolbar in newer version. Select options -> devices select your speaker -> properties and be sure that your audio device is available and selected.
3. Finally if all these options has failed, please use an alternative media like the one mention above (VLC media player).
I hope this have been a great help in your troubles. Please provide feedback on the solution.
Jan 19, 2014 | Microsoft Windows 7 Home Premium 64BIT...
No Audio Device
Try using the VLC Player. It comes with drivers and codec. I've seen it solve problems with sound and audio.
Try using VLC as your player. Go to www.google.com andin the search box type "download vlc" (without the quotes). Look for the Video Lan download from site www.videolan.org/vlc Downloadand install it. It downloads and installs in 3 minutes or so. It'sa very fast player, smooth and it can play just about any type of dvd formatsand media. It's totally FREE.
If VLC Player works try your media player again. It might be necessary to reinstall Windows Media Player if it still gives you the error message.
May 30, 2012 | QDI Group QDI SynactiX 5EP-A (SYNACTIZ...
I am already install realtek high defnition audio drivers but that is not working At the time of playing any media file using windows media player , it shows an error message that is "Windows...
go to control panel-sound-default audio device & check which device is enabled as default device. In case of HD audio remove the speaker jack & reinsert, if that port is selected as default audio then you should get an immediate message saying 'audio jack plugged in'.
Jun 09, 2011 | Computers & Internet
I have a dc5100 sff and legacy drivers. The device manager is saying that the device is working properly but still no sound if I try to play a cd, dvd, or music from my external hardrive. Even if I go...
All you will need to do is download and reinstall your audio drivers.
Head over to the HP downloads center to download the latest audio driver for your PC.
Once it is downloaded, install it and reboot your system.
Feb 10, 2011 | HP Compaq dc5100 Small Form Factor PC...
No audio file will play on WMP, no dvd or audio disk will play...
Windows Media Player cannot play several files in the playlist. This might be caused by one or more problems.
To find information about the specific problems, click the Now Playing tab, and then click the blue or red icon next to each file in the List pane.
In some cases, you might encounter this error message if there is a problem with your sound device, such as a sound card or sound controller. For example:
  • Your sound device requires an updated driver. To determine if an updated driver is available, see Windows Update or see the sound device manufacturer's Web site.
  • Your sound device is not functioning properly. To troubleshoot the problem, see Windows Help and Support or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device, and then try to play the file again
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Problem in sound driver
i want to install sound system in my computer va712 view sonic but i don't have any CD how can i do it or down load it at free of cost ?
Feb 14, 2009 | Compaq Audio card Sound Card
Speakers dont work
u need properly sound driver
check your sound chip in motherbord and tell me i give u link to install proper driver
Apr 01, 2008 | Computers & Internet
Sound Driver
Your sound device is either damaged or has no driver installed. Look in Control Panel/System/Hardware/Device Manager for yellow marks.
You'll find the driver at the Compaq site.
I can't help you further without a model number.
Jan 22, 2008 | Computers & Internet
Sound Drivers
you have to download the sound drivers and install the software..can't give you the exact driver as haven't specified much about your PC.
still try to download one of the common driver like realtek- Ac97... from the following URL ..
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=23&Level=4&Conn=3&DownTypeID=3&GetDown=false
or try to download other audio drivers and install it...your problem would be fixed.
hope to get rated as fixed...
regards
bzoy
Dec 27, 2007 | Genius Soundmaker 32 Sound Card
Sound device
The reason for the message will be the fact that windows doesnt recognise that there is a sound device available because the driver for your sound card or onboard sound is not built into XP and therefore you will have to find out what make of audio you have and install the relevant driver.
Aug 24, 2007 | Microsoft Windows XP Professional With...
Acer Aspire 5500 5570-2609 Laptop Logo
142 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
