I purchased a second hand indesit washing machine .but without the manual it is very difficult to operate the machine. also it is locked. please send me the user instruction manual and tell me how to unlock.
    Scholar:
  • 87 Answers
Take off the bottom panel (usually 3 screws) there should be a tech sheet in there either inside the panel itself or usually taped to the right hand side. Since I don't know the exact model and it's behind the door you cant open, try reaching up from the bottom panel you took off and there should be a little pull ring. See if that does it. Look at the tech sheet and it will also tell you how to go into diagnostic mode. Try that to get it to run a bit. You can go to
http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
enter the model number and you should also beable to get the user manual there. Let me know how it goes.
Posted on Mar 08, 2009
I need user manual for indesit wi25
Type your washing machine name into the Google search box and scroll down the list of 'hits'. You'll see your washing machine instruction booklet offered for free as a PDF which you can download in a couple of seconds.
Mar 09, 2013 | Indesit W 123 Front Load Washer
My INDESIT W43T washing machine problem is cannot start,water no come in and i check the door also no lock,i try to another stage,only pump water out system function.another stage no function.what should i...
I have index w43t. it makes some abnormal noise from drain pump and water is not drained. I opened the drain filter and found the noise came from the drain motor. How can i solve this problem?
Aug 02, 2010 | Indesit Washing Machines
HAVE JUST AQUIRED WIA 111 without hand book. How
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Not sure what you mean by ‘turn off lock’. If you mean the door lock light is on or flashing this may indicate a fault, in which case you would have other lights flashing as well to indicate what the fault is. Click on this link for Hotpoint, Creda and Indesit error code definitions or if you need a free user hand book then click on user manual and select your manufacturer.
Mar 06, 2010 | Indesit Washing Machines
We have been given an indesit 1100 washing machine but no instructions. I'd like to know how long each of the settings last so that I can do the most economical wash. thanks
if you write to Indesit:
Indesit Company UK Ltd
Morley Way,
Peterborough
PE2 9JB
I am sure they can send you an operating manual.
Jul 01, 2009 | Washing Machines
HELP WITH MODEL W822R
I have recently acquired an Indesit washing machine, model number W822R and like you I was stumped as to how to use it. I too looked on Indesit's web site and could not find a manual for this particular machine. Years ago I owned a very similar machine, but only had a vague recollection of it's operating instructions. I looked through several of the manuals on Indesit's site and realised that there was a common theme running through them. The operating manual closest to W822R is the W101. All the wash cycle numbers match and my washing machine works perfectly with them.
One thing to bear in mind is that a lot of modern machines are cold fill only, whereas the W822R is hot and cold fill, so make sure you have both hoses on the back otherwise some wash programs won't work. The W822r can still be used as a cold fill machine by using a plastic 'Y' connecter, available from most plumbing outlets.
Hope this helps
Dawn
Apr 06, 2009 | Indesit WA 125 Front Load Washer
Washing machine
Sure you can. Click on "Indesit" or "washing machines" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Jan 04, 2008 | Washing Machines
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
