Question about Miele Novotronic T220 Electric Dryer
My miele condenser dryer has developed a problem. The water collection container light comes on within minutes of starting the dryer (obviously, I have emptied the container). I have cleaned the condenser unit, I have taken the hose out and put it in a bucket to collect but the problem persists. I have cleaned everything I can think of or find. The dryer is 4 years old and has only ever been used a couple of times a week and only during the winter so it is not old in those terms.
  • 14 Answers
It could be fluff blocking or jamming the condensate pump, can you hear the pump running? access to the pump is through a small service panel at the back. it is hard to get the pump out there is a spring latch to releaseit which is hard to find until you know where it is.
Posted on Aug 26, 2009
Hotpoint condensing dryer model TCFS93BGP. cleanfilter/empty water light keeps coming on after 3/4 minutes
Hi, my dryer has 3 things to check out of which one is more hidden:
- empty the water reservoir
- clean filter in the door
- clean condensor which is hidden below the bottom panel which has to be released through a button behind the door
The last one is less obvious and more difficult to find/reach. Might need to consult the manual.
Did you check all 3?
Hope this helps
Mar 25, 2016 | Hotpoint Dryers
Why would the Dryer not heat after an international move from Austrailia 230V 50 hz to Thailand 220V 50 Hz, when programs, air movement, evrything else functions properly?
Your problem is one electric leg has no power. You are getting power for a single need. But you need double that power for the heating need.
like 110. And. 110. Equals 220 Soo 110 is supplying one need ,that needs only 110 But the heating coils need 220 that is where the second leg comes in... Be sure bothe breakers have powers going out. Into dryer
Apr 29, 2014 | Dryers
The empty container/pc light comes on after approx 5 mins of drying cycle even when the container is empty
at the back of the dryer there should be a plastic tube from top to bottom ( this is the overflow pipe from the water container that needs to be emptied after each use, if the container is allowed to fill up, the water gts picked up by this pipe and collects at the base of the machine, stupid idea, i know) undo the clip at the bottom and empty the tube, also, with the tube still of, tilt the dryer and if loads of water comes out where u disconnected the tube you just need to get the water out. re connect the tube and bobs your uncle. hope this helps. p.s u may want to remove the top cover ( 2 screws ) and blow down the tube to make sure it aint blocked. when re fitting the tube, dont be scared of bending it to get it back into the slot where it tucks into the machine
Oct 25, 2010 | Miele Novotronic T230C Electric Dryer
Miele T358C dryer. water not being pumped out of the sump??
TRY THIS:
TRY THIS:
In some cases cleaning the condenser out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, it is normal for there to be some water in the tubes when you do this, you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier for air circulation; and empty the water container often or reconfigure your pluming arangement to reduce the water left in the container. The circuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later :?) DRRXR
TIP OF THE DAY--
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
Feb 02, 2009 | Miele Novotronic T220 Electric Dryer
Asko T741 - Thermostat keeps cutting out
Ken from Mecheltec suggests removing condensate sump and pump assembly and servicing it. Clear condensate hoses from lint and debris then carefully reinstall assembly. You should be ok.
Oct 06, 2008 | Asko T741 Dryers
Condenser tumble dryer water problem
Took advice...isolated from electricity supply...removed left side panel (side with condenser tank), to access the pump. Cleaned it all out (masses of water and grey lint!) and put it all back together again. Bit fiddly getting the panel back on...no screws left over...result!
All working great now.
Simpler solution maybe...There is a 'trap door' that can be removed, which gives access to the area where the water and lint accumulate.
1) Isolate from electricity supply.
2) Take out the condenser unit at the bottom LHS front of the machine (routine maintenance).
3) Underneath of where the condenser unit usually lives..at the back...reach in and open the 'trap door'. This needs a flat head screwdriver and you must release the two plastic clips holding the trap door.
4) You can now access the area where the water and lint accumulate...which makes the 'float' give a false container full fault.
5) Clean out this water and gunk regularly (once a month)!
Hoping this will avoid taking the side panel off again...
Jun 02, 2008 | Bosch WTE86300 Electric Dryer
LG TD-C700E/40E/41E/45E Condenser Dryer
sounds like your condensin pump is leaking and triggering the over flow micro switch not a job 4 a novice call an engineer good luck
Jul 25, 2007 | LG DLE2512W Electric Dryer
TC7103W - electric dryer
there is a lint blockage between the water collection box and the pump
Jun 02, 2007 | Zanussi TC7114W Electric Dryer
Condenser Dryer Still Filling Room With Moisture
all dryers produce moisture. thats what hapens when you heat wet cloths up. the dryers job is to remove the moisture to dry. thats how the automai]tic cycles work by deteting the moisture in the exhaust. i will say there is nothing wrong with your dryer. only thing i dont understand is the containers of water?
May 13, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Miele Novotronic T220 Electric Dryer Logo
408 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
