Question about LG Studioworks 700S 17" CRT Monitor
How can i manually set the frequency of my monitor?
I can't launch the game Warcraft III in our pc. It says that the there is something wrong in the frequency of our computer... they taught me that I should set the operating frequency of our monitor for me to open it,,,, what should I do?
  • 4,889 Answers
You can change it from display settings->Advanced->Monitor->Refresh rate.
Try different frequencies like 72Hz, 80Hz etc., and see if it does the trick. I can provide you more specific info if you can just tell me whats your OS.
Posted on Mar 08, 2009
My TV/Monitor says "Unsupported" when
The problem is not in your monitor.The problem is in your computer.So try to fix your computer with upgrading the board,Use high specs of memory and card reader.Thanks..
Aug 21, 2011 | Coby TFDVD1973 LCD TV
I installed warcraft III frozen throne but when i launch it it says "input not supported". Help. thanks
It is because your game display setting is different from your monitor.
1st Step Check the screen refresh rate of your monitor and the Screen Resolution..
to see the Screen Resolution
Right Click on "Desktop">Properties>Settings
to see the refreshrate of your monitor. Right Click on "Desktop">Properties>Settings> Click "Monitor" tab. then you will see the screen refresh rate.
to fix this follow this steps.. Click "Run" > type "regedit" > go to "HKEY_CURRENT_USER" > SOFTWARE > Blizzard Entertainment > Video. and on the right panel Double click "refreshrate" > click "decimal" then change the"value data" to the same refresh rate of your monitor, then press "OK". then after that Double click again the "resheight" on the right panel then click "Decimal" change again the "value data" with the same of your monitor (see screen resolution) click "OK" do. the same on "reswidth". (see images below)
Hope this help.. Don Masta
Apr 29, 2011 | Blizzard Entertainment WarCraft III: The...
When I open my war3.exe it says "Warcraft III was unable to initialize DirectX. Please ensure you have DirectX 8.1 or newer installed and that your display drivers are current. DirectX may be found on your...
well, maybe because the application you have has some faulty configs! this might happened because you installed war3 before installing the latest directX. Try uninstalling and reinstalling the game. If that doesn't work either, try to search for driver updates related to your video card!
Aug 10, 2010 | Blizzard Entertainment WarCraft III: The...
Warcraft 3 problem with monitor (turning to sleep mode)
Hello
If only monitors turns off it means that game is in higher resolution than monitor can support.
However, warcraft is preety old game and such things shouldn't happen.
Possible sollutions:
1. Download lastest Video card drivers from producent website
2. Install lastest DirectX
3. If still problem occurs:
Click Start->Run...
enter "regedit" -> press enter
open following directories: HKEY_CURRENT_USER -> Software -> Blizzard Entertainment -> Warcraft III -> Video
doubleclick on "resheight" -> check "decimal" and enter 640, apply with OK
then doubleclick on "reswidth" -> check "decimal" and enter 800, apply with OK
Run game and see if it helped.
Cheers,
Mike
Apr 21, 2010 | Blizzard Entertainment WarCraft III: The...
Help me change my grafics card frequency from 100htz - 60htz
It sounds like the frequency referred to is the monitor's frequency. If it's an LCD monitor, the frequency is usually 60Hz. If you are using a VGA cable, it's guessing the frequency and has guessed wrong.
The other possibility is that the Railroad Tycoon game sets the screen resolution and frequency to something your monitor is not capable of displaying. It sees a nice graphics card and shoots the settings to the top of the range. If you can change the settings before playing the game, you might get it to work.
Aug 18, 2017 | MSI GeForce Computers & Internet
Heello pc restart when i open warcraft 3 how i fix this
do u use pirated game of warcraft or was this problem earlier..
Mar 27, 2009 | Blizzard Entertainment WarCraft III: The...
World of Warcraft Patch problem
Try these two solutions -
Try to move the World of Warcraft folder back to where it was originally installed and run the patch.
Or try this -
1. go to Macintosh HD => Users => Shared => Blizzard: delete the .plist file inside
2. launch the World of Warcraft game and let the patch go through again, download/patch
Good luck.
Aug 26, 2008 | Blizzard Entertainment World of Warcraft...
Monitor shows "Out of Range" 60hz/85khz when starting up guitar hero III
I got the solution fokes ... go into C:\Documents and Settings\Administrator\Local Settings\Application Data\Aspyr\Guitar Hero III and modify AspyrConfig ( open with notepad ) and modify          <s id="Video.Width">1440</s>     <s id="Video.Height">900</s>
This is how worked to me...the idea came after many many tries to fix it... and it will sure work for you :)
Apr 09, 2008 | Scanport 610A 14 in. Flat Panel LCD...
LG Studioworks 700S 17" CRT Monitor Logo
139 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
