Question about RCA General Electric 28310EE1 Skype IP Wireless Phone
Communication Error I have the same problem, the phone always shows comunication error. I could never use the this phone with skype because it always gave the "comunication error" messagen
  • 2 more comments
  • strufuli Mar 08, 2009
    I tried for a several times to syncronize the phone and reset it, but never worked. The phone still shows me the message "comunication error"
    I do not have another phone to try at the same jack. I would like to know if there is a solution for my problem
  • strufuli Mar 12, 2009
    The telephone works with a normal phone line, but I tried to conect it in a friends internet connection and I got the same problem. When I get try ti Sign in to Skype it gives me a "Communication Error"
    Tried that for several times. Doesn´t work
  • 583 Answers
Here is how I would proceed to trouble shoot the problem.
0. Make sure Skype is not running on your computer.
1. Unplug the MODEM wait 10 seconds and plug it back in. See if that fixes the problem.
2. Unplug the Router for 10 seconds and plug it back in. See if that fixes the problem.
3. On the back of the MODEM, find the reset button and reset The modem. See if that fixes the problem.
4. On the back of the router, find and press the reset button. See if that fixes the problem.
5. Repeat step 1 and 2, See if that fixes the problem.
6. Go in to the router software and restore everything back to factory defaults. See if that fixes the problem.
Posted on Mar 12, 2009
  • 154 Answers
1. Unplug the Base Station2. Unplug the ethernet cable from Base Station
3. Unplug the telephone line from Base Station (most important)
4. Plug the base station back in
5. Go to advanced option on the handset and register handset
6. Place handset in charger
7. Once registered, plug in the ethernet cable to get Network Connection
8. Finally plug in the phone line again.
Hope this helps
Posted on Mar 08, 2009
  • 916 Answers
Please try syncing the phone on another phone jack. Check to see if you have the same problem. If you do then return the phone for a replacement.
    Genius:
  • 1,847 Answers
Try another phone on the same jack.Let me know the status.
  • Legin Varghese
    Legin Varghese Mar 09, 2009
    Try the following steps
    Kevin
  • RCA Master
  • 19,396 Answers
Try syncing again the phone with the base.
  • Ginko
    Ginko Mar 08, 2009
    You get communication error when the phone does not detect line signal in the middle of a phone call.
    Communication error may be a syncronization problem between the handset and the base, in this case re sync the handset with the base.
    If instead you get communication error only in the middle of phone calls, in that case call your phone service provider because the problem is a disturbed line.
  • Ginko
    Ginko Mar 08, 2009
    If you cannot even sync the phone, and you are doing the procedure correctly, try first unpluggiong phone power cable and phone cable. If handset battery is removable, also remove handset battery.
    Plug phone together ensuring phone cable is well in the socket.
    If still no luck, then the phone is defective, call the seller, or the RCA support number listed on the phone documentation, and simply have the phone replaced.
Xerox WC 7655 host to host usb failure. comunnication error 7655
Try changin the usb connector of the cable that goes from the screen to the rear left of the machine. There are 4 connectors there.
Oct 01, 2014 | Xerox WorkCentre 7665 Copier
CANON 2420L ERROR CODE-E000197-0000
Printer engine comunication error.
Communication between the DC controller and image processor PCB
Aug 01, 2014 | Canon Office Equipment & Supplies
Skype update
Try restarting your computer, if that doesn't help try un-installing it and re-installing it
Dec 09, 2013 | Skype IM
My computer is'nt comunication with the printer
It could be just a slight communication issue. Try to unplug your printer from your computer. Then unplug the printer from the power source. Replug after 10 seconds. When the printer turns on, replug it into your computer. Doing this usually fixes minor communication issues. If error continues, you may refer to this article on 'Communication Not Available' Error Message and Print Job Stalls in Print Queue for troubleshooting steps. You can also contact Lexmark technical support for additional assistance. Thanks.
Jan 21, 2011 | Lexmark X2600 InkJet Printer
Error communicating with kernel
try to instal the antivirus again there is some files corrupted
ok ;)
May 28, 2009 | Encore Computers & Internet
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
I have a Dell computer that i just recently puchased. I went to wal-mart and got a Lexmark z1300. It came with the cd that i up loaded and had no problems doing. It shows that the printer is active and...
try this...go to printer and faxes....right click on the printer which is ur default printer (Lexmark z1300) ...now go to its properties....in that click on ports tab...see that weather it is using usb port or not...hope this will workout..:-)
Apr 02, 2008 | Office Equipment & Supplies
No comunication
witch errorr messages comes up???
Nov 04, 2007 | Lexmark Z617 InkJet Photo Printer
Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Sep 07, 2007 | HP LaserJet 3050 All-In-One Printer
RCA General Electric 28310EE1 Skype IP Wireless Phone Logo
197 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
David Payne
David Payne
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
