Question about Abit IP35P Motherboard
My Pc wont boot no signal in my monitor Help!
My PC:
Abit IP35P
2x Team Elite 1gb
Sapphire Toxic HD 4850
Ok, back to my prob:
I installed another hard drive (ATA), my system hard drive is SATA, but after i added the new drive, my monitor wont boot or display anything, no signal. so i removed the hard drive. everythings the same, fans running, no beep, the power light is on except that after like 5 secs it will shutoff and power itself on again. T_T help. i tried the clear CMOS thingy at the rear panel. huhu./. help me. i really need my pc. ( sorry for my bad english) thanks.
  • davidhayter Mar 16, 2009
    I have the abit ip35-p mainboard with a core 2 quad q8200, 620watt corsair power supply, Gainward 9800 gt 512mb ddr3, 4gb Ram ddr2 Corsair and hyper 212 Cooler Master fan. I have windows xp home service pack 2.
    I'm having the same problem where the power goes off then on again after like 5 secs, on the boot screen, then it freezes. I have not added any additional hard drive. The boot screen shows, if i can remember well, this message "(some figures)1 cpu ...Memory T" ( where it was supposed to show 1 up to 4 cpus, when booting normally).
    How do I fix this?
Hi there..in mobo with platform p35 works the same like that on-off and on again,its normal so dont worry about that
the real problem is screen blank,i've got replaced new mobo with the same type,but the problem still the same.so its not the mobo problem i think.
Posted on Mar 29, 2009
    Problem Solver:
  • 17 Answers
May be your in second HDD, you didn't set the jumper up. There are some more settings you will have to configure in the BIOS menu. in the BIOS, you should set the primary HDD as the master and the second(newer HDD) as the secondary. Then it should boot without any problem but if the problem persists I don't know what to do next.
Posted on Mar 08, 2009
Abit NF7-s
Take out the ram and reseat it. Try again, if you still have the problem, take out half the ram and test it and then switch it around till you find out what ram chips are possibly bad.
Jan 30, 2014 | Abit NF7-S Motherboard
Blank screen, no signal to monitor, no HD light, no mouse light, no keyboard lights, no beep.
maybe it could be a frayed/broken wire leading to the visual/sound parts. if not then bring it to tech support and have them look at it
Dec 20, 2013 | Computers & Internet
Sapphire 4850 Contrast
make sure the adapter is not damaged when it is plugged into the card.
Mar 04, 2013 | Sapphire Technology Sapphire Hd 4850...
PC wont boot
Check your specs for this one on your Card (should be on the box or in your included documentation), but I believe your card is PCIE v2.1. If this is the case, your card won't work. Your mainboard is an older one, and you can tell by the black PCIE slot that it is only PCIE 1.0. NOTE: PCIE v2.0 cards will work with PCI v1.0 as long as they meet power requirements, etc. (yours should be fine) but there are no updates to fix this on your mainboard. Time to dig out your receipt and look over the return policy. Again, a PCI v2.0 should work OK, just not the v2.1 cards.
Please take a moment to leave feedback if I helped you out today.
Jan 27, 2012 | Sapphire RADEON HD 6750 1 GB DDR5...
I just got the Sapphire 6850 Toxic edition and am attempting to use it in my custom PC, but when I install the card, no signal is making it to my monitor. I have attempted using dvi cables, and VGA cables...
Since you have ruled out the mainboard and the graphics card slot as causing the problem, I would say the actual graphics card is the faulty component. Try it in a friends computer, you may find that the card is faulty. Claim warranty support as soon as possible.
Try installing your old graphics card and uninstalling the drivers for it, then install the drivers for your new graphics card. Remove the old card and install the new card. This would ensure that drivers are not causing the problem, this may be posssible if say your old card is Nvidia based.
Take care!
damnor01
Sep 12, 2011 | Sapphire Toxic RADEON HD 6850 256Bit PCI...
Have an AN9 32X mobo with a Sapphire HD 4850 (512) vc, which works fine with Win XP Pro, but when I go to install a new HD (WD 1tb) and new OS all I get is graphics card crashes and won't actually boot. ...
Try this site- http://abit.ws/page/sa/motherboard/motherboard_detail.php@pMODEL_NAME=Fatal1ty+AN9+32X&fMTYPE=Socket%20AM2&pPRODINFO=BIOS
I assume you know what key to press at boot up in order to get the machine to boot into bios. On mine I have to keep hitting the delete key at boot time for the Award setup screen to show. Other machines may take different key strokes.
Also you might want to get a copy of a compatible edition of a Linux distro and boot into it. You'll have to set your BIOS for the DVD to be your first boot drive in order for the "live" Linux DVD to boot into Linux.
Jul 09, 2017 | Abit Fatal1ty AN9 32X Motherboard
No signal from monitor, help!
do u have a video card? or your monitor in connected in tou integrated grapics port? (i.e. in *********** board.) maybe your bios is set up in booting up on iether of its two and your monitor is connected to a different. try connecting it from the two, while booting up.
Aug 17, 2009 | Abit IP35P Motherboard
Radeon HD 4850. I get a blue screen every time I turn my PC on. It says something `atikmdag.sys` and it's counting to 100 and then the computer restarts. This blue screen it only happens after I install...
Blue screens are software related errors. You would need to try to start the PC in protected mode and remove the drivers from the registry and/or the startup. If possible, run the system restore and put it back to a prior date before you tried installing the drivers. It's possible you may have a card that will not work with your system.
Jun 13, 2009 | Computers & Internet
When I insert my graphic card Ati HD 4850,my system does not boot.I am getting post code error 52 -Test memory(clear all extended memory to 0).Also the fan spins to 100% and does not want to stop.Two...
are your system meet the requirement???
ATI Radeon™ HD 4850 System Requirements
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
  • 450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
  • Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
  • Minimum 1GB of system memory
  • Installation software requires CD-ROM drive
  • DVD playback requires DVD drive
  • Blu-ray™ playback requires Blu-ray drive
  • For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 4850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
Dec 12, 2008 | Computers & Internet
Not switching ON
It turned out that the bracket on my video card was too long and when i was tightening it , it was bending and stressing the video card. put in some spacers and it is working fine now
Nov 16, 2008 | Abit IP35P Motherboard
Abit IP35P Motherboard Logo
568 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
