Having difficulty setting up DVD player wth Toshiba TV model
2927db, is there a channel i should select to view DVD, tv is thru SKY
  • 59 Answers
If your scart is in scart one you wont to be selecting AV1 if your set is quite old you will have to tune the set for your dvd player.
Posted on Mar 10, 2009
Can not record channel 160? GoVideo only goes up to channel 125??
all machines go only to channel 125 maybe you have channel 160 on cable box or sky just set vcr to channel 3 or 4 and channel 160 will come thru vcr to your tv
Dec 16, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Toshiba rd-xv47kb auto tune
Check that you have the arial plugged in correct input otherwise it will not tune up.
May 11, 2008 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Useless at setting up. No sound on playback. Blocked timer record
You won`t get round the scan without an aerial.You still can set a recording as long as you set the recording channel as av2.Make sure the scart lead is fully in on dvd and tv,this can lead to no pic but sound,or sound no pic
Oct 27, 2009 | Televison & Video
Batteries changed sky + remote now does not work - TV Toshiba. Do I need a code to align my remote to my tv again?
Yes, very often after removing the batteries to replace them in a sky handset, you do need to re-code the hand set to your type of TV. Refer to your user guide for the code number for your type & model of TV.
Jul 22, 2009 | Sky ARF E- Belt CP Collective Pitch...
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Oct 12, 2008 | Televison & Video
CANT FIGURE OUT HOW TO RECORD OFF AN 'AV' SETTING
The method is the same as for TV channels; select the input (i.e. view the desired channel), then press the record button. AV1 and AV2 usually are at the end of the channel list, and can be found by pressing the channel UP or DOWN buttons.
Aug 13, 2008 | Sony RDR-GX300 DVD Recorder
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Dec 21, 2007 | Televison & Video
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
Electro Med Services...
