Question about Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
The fan on my rangemaster runs ok ,, no heat changed the element for a new still no heat,, light on front comes on ???????????
  • Anonymous Apr 04, 2009
    i have simaler prob my oven only get's to 140 carnt get it any hotter
  • 188 Answers
Test the switch for continuity with neon tester. by testing both sides while in on potision.
Posted on Mar 26, 2009
New rangemaster prof.fx90 induction cooker but hob not working. - comes on if a ring is on if you touch the hob but no other lights come on + it won't heat up.
Induction stovetops wont heat until a metal pot is put on top of the element. They work through electromagnetism. These tops wont work with glass or aluminium pots. They have to be steel.
Nov 28, 2014 | Rangemaster Kitchen Ranges
Why would oven fan cut ot ?
I can only guess but I would expect that to be normal. I would assume it will come on when the heat is on and off when the heat is off. This would be controled by the oven thermostat.
Apr 27, 2014 | Rangemaster Kitchen Ranges
Fan not coming on in fan oven Second (smaller)
fan motors seized or slow. Turn ovens on with the doors open and switch them on individually,you should see the fans turn behind rear panels, if not see if elements redden up as test if not they may be faulty also.
Oct 26, 2010 | Rangemaster Classic 110 Kitchen Range
Main oven fan is working but not hating up
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Dec 18, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
What do I look for? Rangemaster Kitchener 110
Problem solved, took the back off the inside of oven and the element had a huge burn hole in it. Brought a new element from the local spares shop £17+vat. Easy to fit and it works better than ever.
Nov 13, 2009 | Rangemaster Kitchener 110 Electric Range
Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Jun 08, 2009 | Neff U1721 Double circotherm Electric Oven
Rangemaster 110 oven heats by itself
That happens either because the timer control is faulty, or because there is a contact on the element wires or connectors, and the element is grounded.
Control board and wiring harness are tested using a multimeter.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 17, 2009 | Rangemaster Professional 90 SS (electric)...
Fan oven element not working
getting a shock just means that live is connected. if no heat, that means that no neutral assuming element is ok. do you have a multimeter so you can check if live and neutral present at element? are you sure old element was faulty as it seems strange that putting in a new element did not cure problem i have a memory that there may be a fan fail stat mounted close to the element. worth a check
Apr 01, 2007 | Rangemaster Professional 110 (Duel Fuel)...
Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
209 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
