Question about Philips Car Audio & Video
How to wire up a dap 4040 power wires?? is the acc12v connection necessary, i thought that is why there is a remote wire to supply power.
  • 1557 Answers
SOURCE: Amplifier does not turn on. Power supply available
then it canonly be the internal fuse or the mains power has burnt out
Posted on Dec 28, 2010
  • 142 Answers
SOURCE: Antenna Power supply
First order of business is to check and see if the antenna is operating properly. If the wire in your harness is intended to power the antenna, connect 12 volts to this lead, and the antenna should go up (this needs to be done with the key in the ON or ACCY position). If the antenna does not go up, check the fusebox for a blown fuse. If the antenna does indeed go up, then you can scratch that off the list of possible problems and move on to the next step.
The Clarion should have a power input wire to keep the clock alive, and a power wire (normally of heavier guage) to actually power the radio. Make sure the radio operates when the key is in the ON or ACCY position. If the radio is operating, so far so good.
I'm kind of confused when you say there are two wires on the clarion... "power antenna turn-on" and "auto antenna". Are these both on the clarion? There should be a wire that constantly feeds the antenna with power (I would cal this one auto antenna). It should always be powered to 12 volts. The antenna should operate when the "antenna turn on" lead becomes 12 volts. Normally this ONLY happens when the clarion RADIO is on (ie: if you're listening to a CD, the antenna probably won't get activated).
After checking all this, if you're still having problems and if you haven't already done so, grab a DC volt meter and verify that the clarion power antenna turn on lead goes to 12 volts when you turn on the radio. If it does not, then there is an internal problem within the radio. If this lead IS going to 12 volts when it is supposed to and the antenna still isn't working, then my guess is that the antenna is malfunctioning.
Let me know what you find out... I'll keep looking at stuff from this end. Good luck.
Posted on Apr 19, 2008
SOURCE: jvc KDAVX44 install issue
No, you do not need to connect the parking break wire for the unit to be powered. My radio worked when the parking break wire wasn't attached, but you cannot watch video's or use USB without attaching it to something... you can bypass the parking break to a switch if you like.
Posted on Jul 08, 2008
  • 614 Answers
SOURCE: Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Posted on Jun 21, 2009
  • 36 Answers
SOURCE: Security Camera
it is important to know model and make or camera if you want a solution
Posted on Nov 29, 2009
Remote start / auto starters install help / advice
Remote Car Starter Installation Guide
NOTE: The information on this sheet is provided to you on an "as is" basis with no representation or warranty of accuracy whatsoever. It is the sole responsibility of the installer to check and verify any circuit before connecting to it. Only a computer safe logic probe or digital multimeter should be used. Dr.Detail and/or any other associated or unassociated individual or corporation who furnishes this document assumes absolutely no liability or responsibility whatsoever pertaining to the accuracy or currency of the information supplied. The installation in each and every case is the sole responsibility of the installer performing the work and/or any other associated or unassociated individual or corporation assumes no liability or responsibility whatsoever resulting from any type of installation, whether performed properly, improperly or in any other way. The information supplied is a guide only.
The following information is provided as a reference guide for remote starter installation. We will discuss the most common characteristics of the wires you must locate and connect to in the vehicle for this type of installation. As always, we recommend that you use a digital voltmeter to perform all wire tests. Test lights can seriously damage vehicles on board computers and cost you big $$$. We also recommend that all wiring connections be soldered to assure a solid lasting connection. Avoid routing any wires near any sharp objects under the dashboard, pay special attention to wires routed through the firewall. Split looming is a good idea for wires running through the engine compartment, if you don't have any available to you, taping the full length of the wire will also add some protection.
Before getting started
When a customer's vehicle enters your installation bay you should take a few moments to give it the once over. Check all the switches and systems in the vehicle as well as the exterior lights to make sure that they are working properly and report any defect to the customer before beginning your installation. In the case of a remote starter installation you should also listen to the engine to make sure that it is running properly.
Ignition switch wiring
The major connections for your remote starter are done at the key switch, IGNITION, ACCESSORY, STARTER and in most cases POWER. These wires are usually easy to find, coming off the vehicle's ignition switch. These wires are typically large in gauge however; they can be small gauges as some cars use these wires to control remote relays for all the vehicles operations instead of the wires themselves.
Power wire
The power wire for your car starter should be connected either directly at the battery or to the wire that supplies power to the vehicle's ignition switch. Some vehicle's have more than one wire supplying the key switch but may be fused differently. A good example of this is the dodge intrepid, there are 2 constant power wires at the ignition switch, both are the same gauge, RED & PINK/BLACK. The RED wire is fused at 20 amps and the PINK/BLACK is fused at 40 amps, connecting a remote starters power lead to the RED wire would eventually result in a blown fuse as most remote car starters draw much more than 20 amps. If your remote car starter has 2 power wires you can connect 1 power wire to each of the vehicles power wires. Determine which one is used to supply the accessory output and connect that wire to the power wire that can handle the higher load.
Ignition wire
This wire supplies power to the vehicle's ignition system and fuel pump, it shows between 10 and 14 volts with the key in the RUN and CRANK positions of the key switch. Some vehicles have more than one ignition wire; all ignition wires should be connected when installing a remote starter. Use relays for connecting additional ignition wires.
Second Ignition wire
Some vehicles have more than one ignition wire; all ignition wires should be connected when installing a remote starter. Use relays for connecting additional ignition wires. This Second ignition wires must be connected to an additional relay and
can not be tied in with the original ignition wire. Just connect the new relay using the first ignition relay negative trigger wire and connect the B+ to a known good 12V source.
Accessory wire
This wire supplies power to the vehicle's blower and heater/Ac controls. It shows between 11.5v and 14v with the key in the ACCESSORY and RUN positions of the key switch. Some vehicles have multiple accessory wires to control all the heater and a/c functions. If it is necessary to connect a second accessory wire, use a relay!
Starter wire
This wire supplies power to the starter solenoid to crank the engine. It shows between 11.5v and 14v with the key in the START position of the key switch. Many of today's vehicles have a second starter wire which control a sensor that help starting in cold weather, this wire should always be connected. If it is necessary to connect more than 1 starter wire, use a relay!
Parking light wire
The wire that supplies voltage to the vehicle's parking lights can usually be found at the vehicle's light switch or in the harness of wires going to the rear of the vehicle. This wire shows voltage when the parking lights are turned on. Some vehicles have independent left and right parking light wires. Diodes will be needed to isolate the 2 wires from each other. Some Volkswagen cars need to have the parking light wire isolated from the light switch or the wipers and heater will come on when voltage is applied to the park light wire.
Brake wire
This wire can be found at the switch harness above the brake pedal, it shows between 11.5v and 14v when the brake pedal is depressed. This wire can also be found in the harness going to the rear of the vehicle or at the brake light itself.
Ground wire
Proper connection of your ground wire is essential for your car starter to function properly as it relies as much on this wire as it does on the Tachometer wire to start the vehicle properly and read tachometer pulses. This wire should always be connected to a clean unpainted metal surface in the kick panel or firewall. Grounding directly at the battery terminal is not recommended.
Tachometer wire
Your remote starter requires a tachometer reference signal to monitor when the vehicle has started so it can disengage the starter. The vehicle's tachometer reference wire can usually be found on the engine distributor or coil pack or at the ECM (power control module) or PCM (power control module). References to these modules are often found in Wire Magic. First look for the vehicle's ignition coil or coil pack by following the spark plug wires (if possible) to where they junction together at a distributor. You can usually located a small wire harness at this location were a tachometer reference can be found. If the distributor appears to be supplied via a spark plug wire from another module this will be the coil and will also have a tachometer reference wire. A fuel injector is also a source of tachometer pulses, however this provides a signal for only 1 cylinder so make sure the car starter you are installing can be programmed for this setting. Tachometer reference can almost always be found at the vehicle's computer but this is not always easy to access, see the vehicle's data sheet for the recommended tachometer wire and location.
Factory security
Most factory installed security systems can be disarmed by turning the key in the driver's door to the unlock position. In these cases there will be a wire coming from the door that can be pulsed to shut the security down and allow the vehicle to start without tripping the factory alarm system, this wire can usually be located in the kick panel. If the security system does not disarm with the key, check the vehicle's owner's manual or e-mail us on the vehicle you are working on.
Passive anti-theft systems
Some vehicle's are equipped anti-theft systems that are based on security against tampering with the ignition switch and hot wiring of the vehicle such as GM's Passkey V.A.T.S, Passkey 3, Passlock I, Passlock II or Ford P.A.T.S similar systems found on other makes and models. See the "Factory Anti-theft Bypass Reference Guide" list for details on all these transponder based systems.
Always make all your connections before installing you main power fuse and be sure to program and test all functions properly before closing up you installation.
In closing Use tie wraps or screws to properly secure the starter module and keep the wiring away from any moving parts such as parking brakes or steering column shafts. Mount any switches in a good accessible location where they won't get kicked or hit accidentally.
Take the time to properly explain all functions and features to the customer before they leave the premises. Most comebacks are the result of misunderstandings about how a product works or performs. Doing this will save time and money.
For more help chat email or visit us at or for current specials of the week.
on Jul 29, 2010 | Car Audio & Video
Thermador c272ub double oven is it single fase wireing
yes,the black and red era the 2 wires that supply 120 volts each for the required 240 volts necessary to operate the oven,the white is the neutral wire and the green is the case ground wire,and it should be connected to any metallic part on the oven not with the white wire,only if the power supplying this oven comes directly from the main power panel in the house and isn't off a sub panel before the oven can this be considered ok to be connected together
Feb 07, 2013 | Thermador Ovens
Jensen crossover power supply yellow wire connect to battery negative. blue wire connect to ??? Black wire connect to ground.
The blue wire is a remote turn on for your power antenna. It's kind of like a switch power off of the back of the radio. Do not connect this wire to switch power from the key. A red wire should be connected to the vehicles accessory system off of the key.
Jul 29, 2011 | Car Audio & Video
Replaced smoked RaidmaxKY-520ATX power supply. Replacement power supply does not turn on. Which wires are remote power up from mother board ?
You can actually test the power supply before connecting it to the motherboard. Take a look at the power supply pinout by CLICKING HERE. Jump pin 14 with 13, 15, 16, or 17 to turn it on. You will have to get a manual for your motherboard to see how the front panel connector is configured with your case power switch. If you have that manual you can jump the 2 connector pins for the power switch to test the p/s from the motherboard.
Jun 03, 2011 | RaidMax (KY-520ATX) 420-Watt Power Supply
Trying to find wich two or more wires from wiring harness turn on power supply for a compaq presario 7594
In ATX PC power supplies, here is the wiring scheme:
Green: PS-ON (+5V)
Gray: PWR OK (+5V)
Purple: +5VSB
Blue: -12V
White: -5V
Orange: +3.3V
Red: +5V
Yellow: +12V
Black: Ground (AKA Common)
Use a paper clip to connect the GREEN wire and a BLACK wire. There should be a black one right next to the green. This is how I test PSUs before and after I repair them. Now it should be running, assuming there are no internal problems.
You can also connect the GRAY to ground with an LED. Not necessary, but I like to do it ;)
Nov 24, 2009 | Computers & Internet
Wont power on after checking all the wires
Apr 15, 2009 | Performance Teknique ICBM-782 Car Audio...
Remote wire?????
The old pioneer car radios solved this problem by supplying the battery power to the radio from the amp. When the radio turned on, it began to draw more power from the amp supply lead and this would turn the amp on. It was a simple circuit in the amp that only used one or two transistors. You may need to build this circuit or find a manufacturer of a similiar circuit. In the short run, you can use a small toggle switch to supply the trigger voltage (+12 volts) to the trigger wire connection on the amp. Good luck.
Nov 18, 2008 | Audio Players & Recorders
After connecting my Sony XM-1252GTR Car Audio Amplifier it won't turn on
Hi. You should be able to turn the amp on by touching the remote wire to the B+ main power terminal. this will tell you if it is a problem with the remote from your head unit.
Oct 21, 2008 | Sony XM-1252GTR Car Audio Amplifier
Car Audio & Video Logo
356 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
