Question about Kitchen Ranges
In changing the bottom element the connecting wires with the staycon fell back behind the wall into the insulation , how can I retrieve them there are several numbers (ie.) 164D3333P124-2 JBP24 JBP26 JBP30 JBP35
  • 19,396 Answers
Ry this website:
STAYCON CodeS-SourceS.com
Posted on Mar 08, 2009
  • Ginko
    Ginko Mar 08, 2009
    You can try getting the wires back using a rigid wire, too hook up the wires.
    When this happens, the regular solution is making the hole in the wall bigger , so to access the wires and get them back.
Whirlpool oven dony heat up to the temperture
You likely have an oven element that is burned out. The elements can be replaced. Determine which element is burned out and put your hand near the element with the door open to see if if is the bottom or top element that is burned out. Then go on the web to an appliance part sales company such as appliance parts.com. Enter your Whirlpool model number and do a search for heating elements.
Order one. When it comes, turn off the power to your oven. (go to your house power panel and turn off the breakers that feed the oven.) Back to the oven. Open the oven door and look at where the element comes out of the oven wall. Undo the two screws, pull the element out through the two holes in the oven wall an inch or two. If you find insulation coming out with the wires, push the insulation back into the hole so you can just see the attaching electrical wires. Find attached to the old heating element a electrical wire connector with wire going back on of sight into the hole in the oven cabinet, one for each element end. Unplug the connector. You may need pliers to wiggle it while pulling off. Reverse the installation. Plug the connectors on to the ends of the new element. Reinstall the two screws that hold the element to the wall. Turn the power back on to your oven. Give it a try. It should work and is the most common reason why your oven would not get up to temperature. Likely one of your two elements is burned out.
Nov 04, 2014 | Whirlpool WFE510S0AS 30" Freestanding...
We have a GE electric stove with a JDP 39 oven element which has burned out. How do we get the bottom heating element out to replace it?
UNPLUG the stove or turn off its breaker.
Inside the oven, trace the element back to the rear wall. There should be one screw on each side next to where the element goes through the rear wall. Unscrew that screw on each side and pull the element toward you - it'll come easily, bring its wiring behind it (this is why there must be NO power to the stove!). Detach the wiring from the element... DO NOT allow the wires to pull back through the wall, or you'll have to pull the whole range out to retrieve them.
To install the new element, just reverse that procedure.
Jul 31, 2014 | Ovens
I HAVE A AMANA SINGLE WALL OVEN THE ELEMENT SPARKED AT THE BACK OF THE WALL. I PURCHASED A NEWW ELEMENT AND WHENITOOK THE OLD ONE OUT THERE WAS NO WIRE TERMINALS AT THE ENDS OF THE PLUG IN END OF THE...
when it burnt off it fell somewhere between the oven chamber and the back panel.once finding it,its just a matter of splicing a new wire terminal end and attaching it to the element. The problem lies in thats its a built in wall oven and may be needed to be removed from the cabinet to find and repair this wire. Depending how tight it fits into the cabinet it may not come out easily and even break the wood around the cabinet. which of course you could face in pulling it out to replace it with a new oven. ONe thing to keep in mind is that all wall ovens are slightly different in size and the replacement oven needs to be pretty close to the size of existing one or the cabinet will need to cut or filled in so their wont be a gap left when new one is smaller leaving a gap in cabinet up to 2 inches on either top or side walls
Aug 13, 2011 | Amana Ovens
How do you replace bottom element in top oven?
Turn off the power to the oven at the breaker box.
Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
Pull the element toward you a little bit until you see the wires behind it.
Unscrew the leads and take the bad element out.
Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
Fasten the brackets, making sure they're tight.
Restore power to the appliance.
Dec 23, 2010 | Ovens
Replacing heating element in oven-connecting wires fell back in
hey sorry about that,as a repair man i hold on to those babies like crazy.almost all ovens i worked on [its many]the rear wall dose not come apart.if yours dose great go that way.but other wise yes you have to go thru the back.i would try fishing abit more before i pulled it out if was me.God bless,tom
Jan 02, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
We have a frigidaire stove. The bottom element has broken in two. We have purchased the new element but cannot locate our manual to show us how to install the new element. Can you give us instructions?
Hello the first thing you do is unplug the stove before doing anything ,open the oven door remove 2 screws holding the element to the back wall pull element forward remove wires with insulated pliers attached to the element ,reattach wires to new element resecure to back wall and test. good luck
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Bottom oven element
Yes you will have to remove the back panel , but first shut off the breaker to the stove as one of these wires go directly to the power cord. Normally I would tell you to unplug it but in trying to move it out you may cause one of the wires to touch the frame and ZAPPP you! So please b4 you go farther shut the breaker off. Once you have the stove pulled out, it should have several screws that hold the back on. Not a big deal. Push the element through and connect the wires. In the future be very careful as you are pulling the element out and usually the wires will stay connected and you can replace the element from the front. Just remember to shut the power off first!
Oct 03, 2008 | Maytag MER5775Q Electric Kitchen Range
Trying to replace heating element - can't retrieve wire
You will have to take the oven out ,Turn off the power and check if the wires are tied behind the oven,
May 31, 2008 | Frigidaire FEB27S5A Electric Single Oven
Element wires fell behind oven
I just had the same problem with our Electrolux wall oven. I don't expect you are still having problems 3 years later, but thought I would post for the benefit of anyone else with this issue.
Firstly, turn your power off. I then had to unscrew two screws on each side of the oven door which allowed the oven shell to come forward. You should then see the power cord which you can remove from the powerpoint. If your oven is hard-wired in, then I would definitely call an electrician.
Once I removed the oven, I placed it on the floor and unscrewed a few screws that held the top and back casing on. After removing the casing, you can see the wiring and you just need to push the fallen wire back through.
Before you put the casing back on, you could replace your element just in case the wire falls through again.
Sep 17, 2007 | Whirlpool Ovens
Kitchen Ranges Logo
138 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
