Question about Galaxy Radios DX-949 40-Channels Base CB Radio
Galaxy DX 959
Can I add Feq's to this radio? How can I do this
  • GR275 Mar 13, 2009
    Thank you I will try this
  • 40 Answers
1. Remove bottom cover from radio. 2. On the main PCB, locate J33. (See diagram above) 3. Locate wires on pins marked "P5" (yellow) & "P6" (grey). 4. Cut wire on "P5" (yellow) and install a SPST switch in line. 5. Cut wire on "P6" (grey) and install a SPST switch in line. NOTE: By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
Posted on Mar 11, 2009
  • 773 Answers
SOURCE: refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Posted on May 03, 2009
Benimur
  • 6966 Answers
SOURCE: my galaxy 959 cb radio wil not put out any transmit
Based on your post of no transmit, a couple of possibilities:
1. defective microphone or cord or PTT switch (the red TX light does not come on when pressed);
2. TX light comes on but no output, defective finals and/or drivers. These are the transistors screwed to the chassis of the radio very near the antenna terminal;
3. defective regulator IC that provides the TX B+;
5. insufficient amperage from you power supply;
6. too high SWR.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 16, 2008
SOURCE: Add ch's to the Galaxy DX 959
yes very easily have done 3 of these radios myself. It is posted on the net
Posted on Mar 10, 2009
  • 219 Answers
SOURCE: can't talk about 2 miles ,swr is good
If your talking at least 2 then it sounds like it is the antenna. Any antenna should talk 10-12 miles on a good day, no matter what radio you're using. So I'd get a second look at that system.
Posted on Jun 02, 2010
Ironfist109
  • 3018 Answers
SOURCE: is it best to use in am mode in normal trasmitions
  • This Galaxy was built as a CB to run on AM (11 Meter). The majority of people on the CB run AM stations. Sideband (upper and lower) is where the carrier is removed and the wave being transmitted on is cut in half. You can do this just fine but mainly if you want to talk to someone and you both know your going to be on Sideband for a little privacy. 38 LSB is a great channel to catch some DX side band on world wide. But yea, AM is the best to find people to chat with.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Oct 02, 2011
Adjust modulation galaxy radio
vr 14 is high vr 18 is low vr 16 is fine tune it. but there is a procedure to it so you will need the manual. go to www.cbtricks.com in the left column you will see radios , schematics , manuals.,click on it find g then click the go to galaxy dx and look at the list til you find dx-959 open it up and you will be in your glory. good luck.
Feb 08, 2014 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy dx 959 radio wont transmitt
I would suspect mic first possibly broken solder connection at jack that inserts into radio.
Jan 06, 2013 | Galaxy Radios DX-959 40-Channels Base CB...
959 With not work
check the board maby you have cut or short somthing
bernard
http://www.rylwy.com/
Aug 08, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
Wiring code by number and color for turner mic road king 56 to galaxy dx 959
same pin out as if you were connecting it to a cobra 29.
Jul 19, 2012 | Radio Communications
I overdrove my finals on the galaxy dx 959 by adjusting vr17 too far, now nobody can hear me
you probably blew your audio ic not you final .take it to a tech and let him fix it.
Jun 30, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
How to wire a HG M73 mike to a galaxy DX 959
Stock
1- Shield (Ground)
2- Yellow (Audio)
3- Red (Transmit)
4- White (Receive)
Cobra
Stock
1- Audio
2- Transmit
3- N/C
4- Shield
5- Receive
Dec 04, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Lights
This is a hard one to explain here And I know I shouldn't but call me 904-845-3847. Mel
Jun 20, 2010 | Galaxy Radios DX-959 40-Channels Base CB...
Refurbished dx 959 from galaxy no modulation? no transmitt?
Apr 24, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy DX959
it can not be tuned to go high or low you need to add switches for that and then realign the radio.
Mar 08, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Mar 08, 2009 | Galaxy Radios DX-949 40-Channels Base CB...
Galaxy Radios DX-949 40-Channels Base CB Radio Logo
268 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
