Question about EliteGroup ECS 865PE-A7 Intel 865PE Chipset 800MHz FSB Dual-channel DDR 400 Socket 775 ATX Motherboard with AGP... (MB77EC865PEA)
ECS 865PE long beeps monitor does not come on
The AGP video card doesn't seem to be getting power.
Took out the video card but I still get the same long
beeps every few seconds. Took out the memory too
but still the same. Tried a few different HDs as well
but still the same....HELP.
  • joeporto Mar 08, 2009
    OK, I will try that.
    Thanks for the help:>)
    Joe.
  • rtlc2us May 11, 2010
    Hello from the way it sounds it needs process of elimination. The best way to do it is have 2 computers making sure that the parts you are using work correctly like your videocard memory and so on. The main thing is if it does this as soon as the computers powered on and you have no screen and all the parts do work in another computer then either the processor is bad or the motherboard is faulty. I have had the same issue and found that the motherboard was faullty. Good luck.
    Problem Solver:
  • 17 Answers
U said the AGP video card doesn't seem to be getting power, right? May be your PSU is quite lower than your computer requires to run perfectly. Pls try to change the PSU and see if the problem gets solved....
Posted on Mar 08, 2009
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
New Geforce 6200 on AGP 8x slot has no output
if you can't get a display from the onboard vga the PSU must have killed the mother board. the 6200 gets all of its power from the AGP slot. so if the PSU killed the 6200 it must have gone thru the motherboard. it does not seem likely it took out the 6200 but nothing happened to the board. try taking out the RAM modules. if the computer does not beep then most likely the motherboard is dead.
Jan 31, 2009 | XFX GeForce 6200 Graphic Card
Brand new geforce 6100 pm -m2
This is for the EliteGroup P4VMM2 motherboard. Please remove any newly added video card. One done boot the PC. Windows should load & function (Including video display). Yes?
Restart the PC & press the delete key every 2 seconds untill the bios menu loads. Opem the manual to page 33. Change the Primary Graphics Adapter from PCI to AGP. Save & exit the bios. The system will begian to restart. Press & hold the power button untill the PC shuts down. Unplug the power cord from the PC. Install the AGP card & connect any additional power to the video card if required. Double check all data & power connections for good fit before closing case. Re-connect the power cord & start up the PC. You should have display. Allow windows to finish loading & install the AGP software. Than update windows.
Who ever heard a single long beep. This means the video card may not be seated fully & or correctly. Remove the AGP card, blow out the AGP slot with canned air. Take some alcohol dripped onto a cotton swap. Clean the AGP's copper contacts & clean/wipe the copper within the AGP slot as best as possible. Allow time for alcohol to dry. Re-insert the AGP card, firmely & evenly.
Any more troubles? Please list the issue here. Need manual for the EliteGroup P4VMM2? Click on this link: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Manual&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
Good Luck!
Mike
May 18, 2008 | EliteGroup P4VMM2 Motherboard
Black screen and beeping.
try to use pci card to getto screen agp ect ok maby bios thinks its that output reset it pull out battery then back in
Feb 03, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
Dfi wt70ec socket 423 board never used and visiontekx1300512mb agp
Either video adapter is not seated properly. Remove the video card & reseat.
Also, check to ensure the monitor cable is connected properly.
Jan 01, 2008 | DFI NT70-SC Motherboard
Video card
actually your computer is working on the onboard video adapter.
1. connect first the monitor to the onboard video card.( do not remove the connected geforce video card.)
2. switch on the computer and press "F2" on new model computer, "Delete" on old model computer.
so that you can enter to bios setup.
3. if bios setup is open; try to find the "AGP bridge configuration"
(some other bios AGP B C is in chipset) by arrow up,down,side left and right) enter.
4. Find " primary graphics adapter"
5. In there, select : If Video card is "pci" connected ; select "pci"
If Video card is "AGP" connected ; select "AGP"
6. press F10 to save and exit the setup.
7. after saving the configuration, disconnect power cord and transfer the monitor to the video card (Gforce). and then connect the ac power cord and then start. or switch on the computer.
Note: be sure to install the drivers of your GFORCE for optimum performance of the card.
hope this help.
Dec 21, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Motherboard not responding
This could be a RAM problem. try changing your ram. Is there built in graphics on the board of the mother board. You may have to turn this off in the Bios.
Dec 10, 2007 | EliteGroup 865PE-A7 Motherboard
No display on monitor
no, its working as you said. try to uninstall your video if you installed to expansion slot (agp) then use the on board. that is one of the most common problems of pc specially when you're moving this from one place to another. if it boots from your onboard vga clean your uninstalled video card then reinstall to your agp. i hope that this helps you
Dec 08, 2007 | EliteGroup ECS P4M800-M Socket...
Computers & Internet Logo
78 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
