Question about RTO RJB6361RV - RV Adapter Cord: 30A/125V RV male + 50A/125V 6361 Female
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
    Problem Solver:
  • 11 Answers
The voltage regulator (AVR ) already faulty.
Posted on Mar 21, 2009
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
Why doesn't my GE Symphony 20kw generator turn off after the power comes back on?
The transfer switch could be bad, worn internally, a manual switch, or a semi-automatic transfer switch. Check the transfer switch part numbers and google them to find out exactly what kind they are. In some places fully automatic transfer switches are not permitted in a residential environment.
Dec 16, 2014 | Electrical Supplies
Troubleshooting onan repair
Check for a bad fuel pump and a clogged fuel filter.
Jul 16, 2014 | Onan-Orderable Cummins Onan 2.8 KV-FA/...
My Onan Marques Generator runs but not swap over to 120 volts
What do you mean won't swap over to 120Volts? are you referring to a transfer switch not switching over to generator?
Dec 17, 2012 | Onan Marquis RV Generator 7000 Watts Gas
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
Nov 17, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
Rv generator output, yet no power in coach. Called Parallax about Transfer switch, yet company says just reset the transfer switch, did now says error fault relay switch. Parallax ats501 why now there is a...
Check to see if you have power going into the switch. This can be done with a voltage meter at the terminals were the cable runs into the transfer switch. Do you have power at the generator plug?
Jan 06, 2010 | Watts Onan Portable Generator - 5000 ,...
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Converting the power to genertor
You should not have to switch between battery and generator, unless you are trying to use an inverter as well. Batteries are 12vdc, typically run lighting, water pump, furnace, fridge controls. Generator powers ac, microwave, television, and anything else that plugs into a 120vac wall outlet. Inverter may also run select loads, and possibly dedicated wall outlets, but not AC, fridge, or microwave (usually).
Most RVs / Motorhomes now have automatic transfer switches that will switch between the generator, shorepower, and possibly an inverter. Your coach is made during an era of transition from manual transfer switch (in form of heavy duty electrical outlet near shore power cord) and the automatic transfer switch.
There is no specific place where a transfer switch or generator receptacle are mounted on an RV. There are no rules or regulations tha cover this as far as I know. Your RV may also have an EMS (Energy Management System) that will control the transfer switch as well. EMS panels are typically located above the refrigerator or above driver / passenger seats in overhead compartment.
Apr 06, 2009 | Watts Onan Portable Generator - 5000 ,...
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
RTO RJB6361RV - RV Adapter Cord: 30A/125V RV male + 50A/125V 6361 Female Logo
199 people viewed this question
Top RTO Electrical Supplies Experts
Ottoniel
Steve
Tom Chichester
Are you a RTO Electrical Supply Expert? Answer questions, earn points and help others
