Question about Canon MultiPASS F50 All-In-One InkJet Printer
My Canon Multipass F50 has "check printer" error and won't print. The ink cartridges will not move when you open the door (as if to replace). The cartridge unit only moves partially, which may be the problem, but I don't want to force it.
  • 1 more comment
  • bde2 Mar 08, 2009
    Thanks for offering a solution; unfortunately, it did not work. I found my book and it says that if the printhead does not move, it may be a paper jam or something like a paperclip stopping it; however, neither are the problem for me.
    I may have to contact Canon - yuk!
  • emich Apr 18, 2009
    I have the same problem - my F50 wouldn't print this morning and has an error message, "check printer" - I can't find anything wrong - all connections are secure. When I open the lid to the ink cartridges, the print head (ink) won't move over like it should. What do I do?
  • Gusmoe May 12, 2009
    My Canon Multipass F50 has "check printer" error #343, and won't print. The
    Also, there was a concern that the wast tank might be full, well it was replaced and still get error and wount allow me to anything.
  • 23 Answers
If you have your CD re-install, or try refreshing your printer through the print manager
Posted on Mar 08, 2009
Changed ink cartridges, error code Wrong Cartridge, won't print, copy or scan
I had this same problem with my HP All in One. They told me the cartridge was defective, or the sensor was bad. Try a new cartridge first.
Apr 22, 2010 | Canon MultiPASS F50 All-In-One InkJet...
I am out of several of the color inks, but the Canon says "Check Printer" and the cartridge won't move to the middle so that I can change the ink.
If you are gentle you can manually move the print head to the middle by hand. You don;t want to force it or push very hard. There will be a bit of resistance but it should just move smoothly. You may find it works when the printer is unplugged.
When you power it back up after changing the cartridges it will return to the side and print normally.
Apr 21, 2010 | Canon MultiPASS F50 All-In-One InkJet...
My Canon Multipass F50 has a "check printer" error and won't print. The ink cartridges will not move when you open the door (as if to replace). It won't even turn off to cycle it to clear the error,
I had a similar problem. Go to this page http://www.fixyourownprinter.com/forums/inkjet/29693 and try the codes they suggest to reset the count for the waste tanks. Good luck.
Jun 01, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon MP F50 "wrong cartridge" error
remove all cartridges leaving printhead intact.
close cover, turn off
turn on, let power up, error message should be gone.
open cover, reinstall cartridges
if you cleaned your print head like I did you'll probly
eventually end up getting a new one anyway, due to the color variations
but I can at least print text.
Apr 08, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon Multipass F30 not printing
Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
good and your printer shows under device MGR, then it is the printer
itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
cart is in the right spot, bl in one spot and color in a spot.
Dec 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Cartridge jammed and sccaning error
When you open the clamshell does the ink carriage slide back and forth with jamming?
If not then try getting some silicone grease and apply a very very thin line of it on the rail.
If it does then try making a copy, in the middle of the process, before the error, open it up and see if the ink carriage has even moved from "Home" position.
You might have a belt issue and this could be one of many things, stripped plastic gear, streatched belt...
Jun 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Wrong Cartridge Error Message
I have same problem.Please let me know if u find an anser
Feb 10, 2008 | Canon MultiPASS F50 All-In-One InkJet...
MultiPASS F50
check the Canon Knowledge base at www.canontechsupport.com, it may be the printhead or unit itself.
Oct 23, 2007 | Canon MultiPASS F50 All-In-One InkJet...
The Print Head might be the fault of that,try replacing the print head and see if that helps
Jan 31, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
198 people viewed this question
old marine
old marine
