Question about Palm Z22 Handheld
Time change killed palm
My z22 worked fine until the time change this morning. When I turned it on to check the time, it would not come on. I tried soft and hard resets but no joy. The unit was fully charged but to be sure I put it on charge but still nothing.
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    have hard reset like this
    Doing a hard reset
    Only
    do a hard reset if a soft reset doesn’t solve your problem, or if you
    want to clear all of your information from your handheld.
    Important
    A hard reset deletes all records and entries stored on your handheld,
    including the username that identifies the handheld. This is another
    reason why it's important to
    synchronize often, so you have an
    up-to-date backup of your information available. Before you do a hard
    reset, be sure to synchronize.
    1. Press and hold the power button.
    2. While holding the power button, use the tip of the stylus (or a similar object
      without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
    3. Wait for the Palm Powered™ logo to appear, and then release the power button.
    4. When you see the message that warns you about erasing all of the info on your handheld, do one of the following:
      • Press Up on the 5-way navigator to finish the reset and show the touchscreen.
      • Press any other button to do a soft reset.
    5. When
      prompted, tap to align the screen, and then select the language you
      want to use on your handheld. A screen appears showing the Palm logo
      and a progress bar.
    When the Welcome screen appears, the hard reset is complete. Follow the instructions to set up your handheld.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
If thatn doesn't work, put your palm aside for a week allowing battery to completely drain. Repeat procedure after a full charge. If this is helpful please post as such.
Posted on Mar 23, 2009
Palm z22 touch screen not responding touchscreen
The Z22 palm PDA is subjected to 3 points of failure. I got a used Z22 and discovered all 3 over the course of a few years. The touchscreen digitizer on the front is a plastic sheet on the top, and a glass screen on the bottom. Invisible layers of conductive paint are facing each other. Simply carrying the Z22 in your pocket, purse, briefcase, or even storing it in a drawer with pencils, staplers, rulers, etc., will, over time, deform the screen, and the damage is cumulative, so that the screen gets worse and worse. It is imperative to have a solid sheet of plastic or hard material over the screen at all times that you are not using it. Leaving the Z22 in direct hot sunlight will heat up and soften the screen, making the problem worse. Carrying the Z22 screen in your pocket on a hot day when you are sweating, will do the same. People report that the Z22 will work in a cool place like North New York, but the screen will quit, when they travel to Florida (hot). I have temporarily fixed the touchscreen by putting it in a ziplock, and sticking it in the freezer to shrink the top layer of plastic. That only worked twice. Then I use a hair dryer to heat the screen VERY hot, to shrink the screen - which worked very well, until I put it in a soft zippered camera case, which gently pushed the screen. Then I took the screen apart completely ( which no one has ever reported doing) and this worked amazingly well, -again- until I put it in a soft case that pushed the screen against the glass backing. I eventually replaced the touchscreen ($10 free shipping from China). All the information is on my tiny website at
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
The Z22 is incredibly well designed, and after ripping it apart a dozen times, and carrying it around under extreme heat and freezing cold, I would have to give the original design team at PALM, 5 stars. Your data, on the device, even though the screen may be dead, is very safe, and unless you do a HARD RESET, the data is stored on permanent memory. I had problems with a weak and dying battery, which ALL Z22s are now experiencing, since the decades of time, even with a "new" in the box, sealed Z22 will have. Low glitches of power on the battery seem to cause the BlackScreen of Death, where the LOGIC circuits that control the ON/OFF/SLEEP etc. functions get out of sync, and the unit will not charge or turn on until ALL power is removed ( typically, after a few weeks the battery drains to dead ).
All these problems are discussed and solutions posted, with photos on my website. Also are discussions on what to do with the Z22, where to get parts, how to maintain the Z22, and how to get data off the device onto the new 64 bit WINDOWS computers...
Good luck. The Z22 was an amazing device in its day, and people report that there were a few software programs for it that have never been made since - hence, they still use it...
robindustygraves Sept 2014
Z22 PALM PILOT a75f3784-08d5-4a1b-85ae-67e479181e27.jpg b2146887-a4b6-43a4-931b-b0f3438348ac.jpg 12202c43-26c3-47df-a31f-bc94507b7482.jpg fc737f81-6cb4-492d-b006-199c695a4776.jpg
Aug 02, 2013 | Palm Z22 Handheld
Palm z22 touchscreen not responding
The Z22 is incredibly well designed, and after ripping it apart a dozen times, and carrying it around under extreme heat and freezing cold, I would have to give the original design team at PALM, 5 stars. Your data, on the device, even though the screen may be dead, is very safe, and unless you do a HARD RESET, the data is stored on permanent memory. I had problems with a weak and dying battery, which ALL Z22s are now experiencing, since the decades of time, even with a "new" in the box, sealed Z22 will have. Low glitches of power on the battery seem to cause the BlackScreen of *****, where the LOGIC circuits that control the ON/OFF/SLEEP etc. functions get out of sync, and the unit will not charge or turn on until ALL power is removed ( typically, after a few weeks the battery drains to dead ).
( I am posting this answer on a few places on fixya, so that people with Z22's can find it easily ! )
Z22 PALM PILOT
0622ac5f-1a8b-4e47-b2d3-41600350d21e.jpg Z22 PALM PILOT d66589a5-9eed-4439-8a3e-5cc1944e2ab2.jpg 61ca79eb-5d24-47a7-9aea-aab6200c19b8.jpg c90ee8fa-0ef6-4f86-8024-0ebb9f0cb5c1.jpg
Aug 08, 2011 | Palm Z22 Handheld
My Palm Z22 won't turn on. If I do a hard reset
It absolutely won't, you don't have to worry. I've done it several times, and I know I was really nervous at first, but it's fine.
Nov 01, 2009 | Palm Z22 Handheld
Palm z22-Touchscreen wont work
The Palm Z22 is a very solidly designed device to reliably store your personal data, however, it is subject to 3 failure mechanisms, all related to its AGE of over a decade of use. The batteries are all dying - even in an UNOPENED, sealed, "AS-NEW" package, the battery is almost dead. The TOUCH SCREEN is a delicate stretched layer of plastic on top of a layer of glass. The top layer bends down a touches the glass layer, and invisible layers of "wiring", electro-deposited on the layers, touch each other. Over time, with air-pressure changes, heat and cold, and mostly objects pressing on the screen (such as carrying it in a pocket, purse, briefcase, or even leaving it in a drawer with pencils, paper, pens, staplers, etc.) , the top plastic layer deforms and touches the bottom layer, which renders the touch screen dead.
My page on the Z22 is at :
and has tips and tricks on temporarily getting your screen working, as well as how to replace it yourself - $9 U.S. free shipping from China.
I hope that this helps you get your Z22 up and running again, and helps you to keep it functioning.
good luck
robin dusty graves
Z22 PALM PILOT palm-z22-touchscreen-wont-work-ngl0e1lc0ft3j10pmz4xzklk-1-0.jpg palm-z22-touchscreen-wont-work-ngl0e1lc0ft3j10pmz4xzklk-1-1.jpg palm-z22-touchscreen-wont-work-ngl0e1lc0ft3j10pmz4xzklk-1-3.jpg palm-z22-touchscreen-wont-work-ngl0e1lc0ft3j10pmz4xzklk-1-6.jpg
Aug 06, 2009 | Palm Z22 Handheld
Palm Z22 will not turn on and I don't know where to reset.
the reset button should be located on the back to the bottom right of the label.
have a look at this link.
http://www.palm.com/us/images/support/kb/articles/30113_z22.gif
May 26, 2009 | Palm Z22 Handheld
My screen went dim.
i did the same and got very annoyed i'd broken it. pretty much gave up on it until i needed a date from the calender some months later and once the battery had drained it seemed to fix itself. i now only charge it for an hour or two at a time
May 07, 2009 | Palm Z22 Handheld
Can I get my z22 repaired?
actually palm does not want u to change the batt they want u to buy a new device from them but u can do it
first check the charger voltage thru volt meter or confirm from other ways that ur charger is working fine , i am pretty sure that ur battery is Dead and it is difficult to replace but can be done if u have little expertise becoz Palm does not want u to replace the batt they want u to buy a new one when the batt is dead but u can do it thru following procedure
First check the specs on batt by taking it iut like this
How to Replace the Battery on a Palm Z22
The Palm Z22 is powered by a rechargeable lithium-ion battery which, in theory, can be recharged an infinite number of times. In practice, however, the lifespan of a rechargeable battery is finite. Replacing the battery yourself is possible if you have some skill with tools and a bit of patience.
Instructions
Difficulty: Moderate
Things You’ll Need:
* Star-bit screwdriver
* New z22 battery
* Palm z22
What to Do
Step1
Pull down on the back cover of your Palm Z22, and remove the cover from the device.there is a trick to it. The little translucent bezel surrounding the USB connector can be snapped out, revealing two T-5 (Torx) screws. Remove the bezel and the two screws and the other three sides will separate with some gentle prying as you have already discovered.
The best way to remove the bezel seems to be to slip a knife (or a thin fingernail) into the joint closest to the display. It's a tight fit but you don't have to separate it very far to get it to pop out.
The battery is not "user replaceable" - i.e. it is soldered in place, but you can buy one online if you're prepared to do the solder work.
Step2
Loosen and remove the screws from the Z22's casing using a star-bit screwdriver.
Step3
If there are tabs present on the circuit board, you will need to stop immediately. Consult with a technician about removing the tabs.
Step4
Find the battery. Move it out of the case so you can have better access to the power supply lead.
Step5
Pull the power supply lead from the battery. Grasp the base of the plug firmly and disconnect in one smooth motion.
Step6
Remove the old battery from the case and insert the new battery into the same position and with the same orientation.
Step7
Replace the rear cover on the Z22 and charge the new battery for at least four hours before use.
Tips & Warnings
* Use firm steady pressure to open the case. Sharp blows and delicate electronics do not mix.
* A star-bit screwdriver is not the same as a Phillips screwdriver. The star-bit has a six-flanged head which looks a little like an asterisk when viewed head-on.
* If your battery has a blue casing on it, do not attempt to change the battery.
How to Buy a Replacement Battery for a Palm Z22
The Palm Z22 is powered by a rechargeable lithium-ion battery. This means that you can use it forever, right? Well, no, because even rechargeable batteries wear out eventually. Since Palm currently does not offer replacement batteries, you will have to track one down yourself. Here is how to buy a replacement battery for a Palm Z22.
Instructions
Difficulty: Moderately Easy
Things You’ll Need:
* Palm Z22
Step1
Write down the technical specifications of the Palm Z22 battery. The battery is 3.7 volts and delivers 950 mAH.
Step2
Shop at your favorite local retailer, electronics store or battery specialty store. Take advantage of the sales staff’s knowledge in your hunt for a battery that is compatible with the Z22. Bring your Palm Z22 to the store to be sure that the battery fits.
Step3
Search for an online retailer who carries the Z22 replacement battery. Once you have found a couple of vendors that have the goods, shop for the best deal. Remember to include shipping costs into your decision.
Step4
Get information about return policies or money-back guarantees before shelling out any money. Returns may not be an option for the Z22 replacement battery due to the specific complications involved with lithium-ion rechargeable batteries.
Tips & Warnings
* You will need a tool kit to change your battery. The screws on a Palm Z22 require a star-bit screwdriver to loosen the shell.
* Correct use of your battery charger will prolong the life of your batteries, whether the original issue or replacement.
* Be sure that your batter is compatible. You don’t want to fry the Z22 with a high-powered, incompatible battery.
Mar 16, 2009 | Palm Z22 Handheld
Absolutely black screen - will not power up - did not give warning of low battery - palm z22 about 2 years old ---is it dead????
The Z22 suffers from 3 problems. One of these is the Black Screen of Death. I got a used Z22, and over the years discovered this problem. The small battery was a perfect fit of power and size when manufactured, decades ago, but, time alone has deteriorated the capacity, so that a "NEW" , sealed-in-the-box Z22 today, has a weak, dying battery that needs replacing. These are $10 free shipping from China. The BSoD seems to be caused by a dip in power from the battery to the LOGIC CIRCUITS that control the ON/OFF/SLEEP/CHARGE, etc states of the Z22. If the logic gets out of sync, the unit is in an INVALID state, will not charge, nor respond to the LOGIC buttons on the front - these buttons are NOT the standard ON/OFF buttons from the past that mechanically connected or diss-connected power. All the buttons on the Z22 are touch snap disks that are connected to transistors, to flip logic states. THUS, is the power in any of the transistors gets low, the transistor is neither ON nor OFF, and the control circuits are in a messed-up state. Or another way of looking at it, the ON button is a logic gate on a transistor network, and the only way to activate the "ON" logic state, is with full power to the circuits! -- the power on the Z22 is ALWAYS ON. . . The screen may turn off, and the chips may go into "sleep" mode, but the Z22 is always on. SO if there as a weak battery, you may get the random Black Screen of Death. The GOOD news, is the the DATA and programs that you purchased are incredibly SAFE, as long as you do NOT do the HARD RESET (which someone suggested ! (NOT ) ). I have ripped apart the Z22 dozens of times, and subjected it to freezing and heating and all sorts of horrible things, the data has always been 100% reliable, -- stored in permanent memory. There is a quick way to get rid of the BSoD - you have to open the unit and cut one of the two battery wires, wait 2 minutes to kill the logic circuit power, then re-connect. I added a switch on the Z22, just for this purpose. I would recommend, if you get the Z22 re-powered, to get a new battery as soon as possible. This should clear the BSoD for a while. See my tiny website :
There are many photographs and step by step procedures to try to get the data off the device, maintain the Z22, get parts, and use the Z22 with the new 64 Bit Windows computers. The BEST way to use the Z22 would be to get an old Widows 32 bit laptop (ie WinXP), and simply connect the Z22 in a standard way using the software that it was designed for... The new patches to 64 bit machines, are very limited, and many previous features do not work.
So the bottom line - all your data, information, and programs are safe. You simply have to reset the LOGIC CIRCUITS (this has nothing to do with the PALM Z22 SOFT and HARD Resets !) - it has to do with disconnecting the power from the battery, or waiting until the battery is COMPLETELY DEAD ! (which can take a long time! )...
Good luck
robindustygraves sept 2014
Z22 PALM PILOT 691d763d-1b45-4323-a389-5dd3900ad65d.jpg 4ab4c25b-c05c-4deb-898e-d858abbab87f.jpg b63d6d62-a28c-4450-b1de-0e692a79ae08.jpg 8387fdcf-76fa-42ab-a7d4-e941d697b879.jpg
Nov 11, 2008 | Computers & Internet
I had this problem in the very beginning and a few times after. What worked is the following.
Put it to charge for at least half an hour. You won't see it is charging or anything.
Then, while connected to the charger, press the reset button.
Have you guys tried it like this already?
Feb 02, 2008 | Palm Z22 Handheld
Palm Z22 Handheld Logo
91 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
