Question about Samsung SGH-D500 Cellular Phone
Ring and vibration does not work simutaneously
Is it possible to get the ring tone and the vibration to operate simutaneously as the Nokia mobiles do?
  • 75 Answers
Ya it is possible you should re configure the setting of your mobile.check the tone or melody setting of your mobile care fully.if problem not solve then tell me again.
Posted on May 12, 2010
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
My mobile in not displying anything in the screen
If your phone notify the incoming calls by vibration or ring tone then you just have to change the LCD of your phone.But if it is not ringing the ring tone for incoming calls then your phone may have big problem like dead.So in this case you should go to any service center to save your phone.
Dec 20, 2009 | Nokia N95 Cellular Phone
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
Jul 24, 2009 | T-Mobile Dash Smartphone
Ring tone problem
there r three modes. 1)ring mode. 2)vibration mode. 3)silence mode. so it would be on silence mode.just make it ring mode from silence mode. which can be done by going into settings then in to ringer and volume that you can select. thanks.
Jan 08, 2009 | Cell Phones
My phone has no song at all
Hi Kathnicks2
Have you checked your profile if its in silent mode? Also check the settings and in that check if you have selected the incoming call alert as ringing or vibrate. You can also check if your mobile is ok by trying to listen to ring tones in general. So, if you are not able to just listen to ring tones, then you will have to meet a service person who can get it right for you.
Nov 19, 2008 | Nokia 1100
No ring sound and music
at first you go the setting s in your mobile in there go for phone setting in that it given the default setting select it after one min you swicth off your mobile and swicth on the mobile you got the ring tone in your mobile
May 30, 2008 | Nokia 6111 Cellular Phone
Nokia 5300 xpress music mobile phone won't ring
did you going to settings and then to tones?
Jan 19, 2008 | Nokia 5300 Grey Cellular Phone
Samsung SGH-D500 Cellular Phone Logo
79 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
