Question about Roper RAS8445KQ Top Load Washer
Top load roper washer water will not cut off after filling machin
Hot and cold does this have a valve and where is it
  • Roper Master
  • 3,361 Answers
The water valve is the part where your water hoses connect.
Replace the water valve if the water is constantly running after the machine has been turned off.
If it only overfills during the fill cycle, check your water level switch and connecting plastic air pressure hose.
Posted on Mar 08, 2009
Cold water fills very slowly
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Jan 02, 2013 | Roper RAS8445KQ Top Load Washer
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Have a Roper RAS7133RQ3 top loading washer. Will not fill with water when turned on but will spin and drain when you take it through the cycles.
First, always check for the obvious causes, if you haven't already, we all tend to overlook these.
1. Are water valves open, and if so is there water.
2. Check hose filter screens for plugging, or hoses themselves,
After these possible causes have been ruled out, check machine's inlet for both hot and cold taps for blockage, other wise you most likely have a bad fill valve, which are fairly cheap and simple to replace. If you have hard water, this is your best bet. These valves have two solenoids, one each for hot and cold, one or the other will energize when the temperature selector switch is selected for hot wash or cold wash, if warm wash is selected both solenoids energize to allow both hot and cold water to enter the machine and mix to warm.
Hope this helps
kcomp1863
Jan 10, 2011 | Roper RAS8445KQ Top Load Washer
ROPER TOP LOADING WASHING MACHINE
Check the lint filter at the end of the hose. The filter is actually inside the washer. My husband cleaned it out and now ours works great. Both hot and cold had stopped running in because of our hard water.
Sep 20, 2008 | Roper RAS8445KQ Top Load Washer
Roper washer wont Agitate
you have a bad watwer inlet valve but the agit. has nothing to do with the water unless you are not getting enough into the machine to start the agit cycle
Jul 29, 2008 | Roper RAB2121KW Top Load Washer
Roper washer: Slow fill on hot setting
You can really thank the government for this- your washer has a 75/25 split valve (75 cold 25 hot--- so warm is mostly cold) which they mandated for all standard top load machines. In 2010 they are banning manufacting of all standard top loaders. The thermistor is because your machine has a ATC (automatic temperature control) system. It has a computer which monitors water temp for better laundry care. You could possibly have a repairman (this wouldnt be covered under warrany) try to retrofit a older service valve in your machine.
Jan 13, 2008 | Washing Machines
Washer takes forever to fill
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
133 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
