Question about Nikon D70s Digital Camera
View - Finder reads "OFF"
Not every time but often after I take a picture (especially in Auto Mode) the camera won't take another picture.  When I press down in the shutter the word "off" is displayed".
  • Anonymous Mar 14, 2009
    My problem is pretty much the same as daniela_fitn's, but I rarely use anything but manual mode. WEhen the viewfinder reads "Off" I usually turn it on and off a few times and wait a minute or so. It's hardly a solution.
  • 86 Answers
Firmware problem. That's why the D70s and D70 are discontinued.
Posted on Apr 09, 2009
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
Shutter will not open every time i take a photo. The photo always comes out black on the view finder
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 27, 2011 | Cameras
When the camera is in take a picture mode, the view finder is black. When viewing pictures pictures previously taken, they are show on the view finder. Why is it black in this mode?
Dec 06, 2010 | Canon PowerShot S2 IS Digital Camera
When trying to take pictures, looking through view finder or on back screen, it is blank. Am able to access menues and all though. Canon PowerShot S2 IS.
A stuck shutter is another common failure mode for digital cameras, but especially so for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 11, 2010 | Canon PowerShot S2 IS Digital Camera
I have a Canon PowerShot S2 IS and all of a sudden I cannot get an impage in view finder nor the flip lens. Any suggestions?
A stuck shutter is another common failure mode for digital cameras, but especially for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 08, 2010 | Canon Cameras
Thre image does not show through the view finder or digital screen
If camera shows previously stored images correctly in playback but does not show live view in camera mode then it is ccd imager chip failure problem.
Replace ccd imager chip in camera by local camera repair shop to fix this issue.
Let me know if symptoms are different as above.
Sep 11, 2010 | Canon PowerShot S2 IS Digital Camera
No view though the lens
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 26, 2009 | Canon PowerShot S2 IS Digital Camera
I can view prior photo's taken but. it will not take pictures. view finder is black
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 21, 2009 | Canon PowerShot S2 IS Digital Camera
View finder
Ok. On your viewfinder, there might be a round dial. Turn it to adjust focus. Otherwise, sometimes viewfinders are like that... blurry, especially electronic.
Apr 19, 2009 | Sony Cyber-shot DSC-H5 Digital Camera
Powershot S1 IS trouble shooting in images of lcd monitor
Try playing back pictures you know were captured properly ( either with another properly working camera or with your camera before the problem with quality has appeared ). If the image is ok in playback but 'noisy' in capture mode then the CCD sensor is faulty /on its way out. Ask Canon if they repair CCD faults on this model free of charge.
Aug 18, 2007 | Canon PowerShot S2 IS Digital Camera
Nikon D70s Digital Camera Logo
64 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
