Question about Lux Elba OV 5085 LUX
We need an opering manual for the cooker we can not get the oven to work properly
    Sergeant:
    Champion:
  • 234 Answers
This model you have here is for a wirlpol tub.
http://www.mansfieldplumbing.com/v3/pc-template1.jsp?item=341&cat=1679#.
Posted on Mar 16, 2009
Can't light oven in Wedgewood caravan oven
Do you have manual for proper lighting procedure? Do top burners have good flame?
Feb 27, 2013 | Atwood Mobile Products Atwood Wedgewood...
I have a AO Smith GPS 75 200. The power is on, however the temp control does not light up and nothing is working. Is the White Roger thermostat gas valve shot, is there some test I could do to make sure...
You have AO Smith tank-type power vent water heater with FVIR flame arrestor.
1) I believe this system has White Rodgers intellivent gas valve, with led indicator lights.
To test if valve is operational:
-NORMAL operating mode displays no lights on gas valve.
-Unplug unit from electrical outlet and plug back in. All lights on gas control should display for 1-5 seconds.
-Press BOTH Hotter and Colder temperature buttons for one second to 'wake up' the control, and release buttons and LED will display temperature.
-Press Hotter or Colder and see if any indicator light shows on gas valve.
This will give baseline if gas valve is functioning.
-Intellivent gas valve requires outlet that is wired 100% correctly. Test outlet with circuit analyzer.
-Water heater must be properly grounded for intellivent to operate.
2) Open following link to identify gas valve and download possible service manual with error codes and testing procedure. Service manual is a large file and will probably not load on dial-up.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
3) Open following link for AO Smith manuals and service handbooks.
Shows same intellivent service manual, and shows manuals for power vent, but does not specifically list the GPS75 series
http://www.hotwater.com/resources/product-literature/service-handbooks/
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 08, 2011 | Water Heaters
C2 11 code
Before calling service technician, open following link for Rheem error codes and troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error code C2 11 is 'no ignition'
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
There is no service bulletin covering how to perform these actions.
Rheem will ask that you call qualified service technician, who can give you tips and tricks for keeping the unit working, including opportunity for yearly service that will eliminate the expected $1-8 monthly savings from owning tankless.
Read manual for yearly maintenance needed to keep unit working at prime efficiency.
Apr 18, 2011 | Rheem Tankless Hot Water Heater...
Tested my bosch 250 sx with no gas hookup a2 error showed up.I s this possible wit no gas hookup yet?
1) Error code A2 shows on following link:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
2) Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
3) As a general rule, tankless are best when installed by experienced, trained technician.
4) This is partly because Tankless manufactures refer you back to installer when there is a problem, and party because so many factors affect tankless operation.
5) Tankless require perfect alignment of factors to work properly, including vent, air supply, gas supply, combustion maintenance, water flow, water pressure, water quality, overall maintenance, plus internal parts working in harmony.
6) Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Feb 09, 2011 | Bosch AquaStar 250SXO-LP-RE...
My pressure is low on my halstead eden cbx24 boiler, i can find the loop to fill it up but dont know where to put the water in, can anyone help?
Do you have a sight glass that shows water level in boiler on this loop? If so is it marked where normal water level is supposed to be? There should be a water line connected to boiler with a valve on it. This will be a manually operated valve unless it has auto fill control. Locate this valve and slowly add water until level in sight glass is back where it should be,then shut valve.While you are doing this the boiler should be at operating temperature because hot water expands and you don't want to overfill. There should be a temperature and pressure relief valve on top of your boiler to prevent unsafe conditions but I wouldn't count on it working properly if it is very old. My main concern is for your safety so if you are unsure of something don't do it. If your boiler has a automatic water make-up on it then you need to have a service tech. find out if it's not working,and repair or replace it. I hope this helps you. Thanks
Nov 24, 2010 | Water Heaters
Thermostat keeps cutting power off to elba excellance oven
I have a similar problem with an Indesit oven. There are two thermostats one controlling the oven temperature which i think you have replaced and another over-temperature stat to prevent the oven getting to hot should the temp stat fail to control the temperature. The over- temperature stat could be operating to quickly and this cuts power to the the digital display, oven light, temp light and circulating fan. I am going to replace this over-temp stat
Jan 18, 2010 | Lux Elba OV 5085 LUX
Electric oven not working on our elba excellance oven. Thermo has been replaced but oven worked for 1 day then went again. What is the problem please?
Elba Oven not heating? How to replace a Elba fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
You searched for Elba element How to Repair Home Appliances
Jul 06, 2009 | Lux Elba OV 5085 LUX
Lux Elba OV 5085 LUX Logo
323 people viewed this question
Top Lux Water Heaters Experts
Gene Haynes
Bill
Level 1 Expert
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
