I have a UC35 Mn2 washer extractor and the timer wiring is numbered and also the timer is also numbered for jumpering.I want to check that all wiring codes goto timer correctly.Surely there is a wring diagram showing wire numbers to the timer.
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Whirlpool LSQ9544KQO won't spin
if it fills with water and then nothing check the lid switch,if it's bad it won't do anything but fill,some will agitate but then no drain or spin,the easiest way to check it is open the lid a few inches and close it,do this a few times,if you don't hear a clicking sound the switch is bad,or open the lid and stick a screw driver into the hole on the right side where the strike from the lid goes into,if it doesn't click when you push it down and let it up it's bad,part number 3949237 and it's around 50 dollars.watch this video,it's a different lid switch but changes out the same way.
http://www.youtube.com/watch?v=MFsvLiuTniU
you can also stick a jumper wire into the two outside wires to check it,flip up the top console,you'll see the lid switch connector on the right side plugging into the top of the frame,unplug it,stick the jumper into the connector that unplugged from the frame and it will have three holes in it,the middle is ground so stick the jumper into the two outside holes,set the timer to drain and pull out the timer,if it starts to drain and spin then you know the lid switch is bad.hope this helps.
Jun 04, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a frigidaire stack washer and dryer model fex831cso Iam not getting voltage to my pump motor but drum is spinning what do i need to look for Iam thinking it might be the timer all help appreciated
In a packet on the back side of the diagonal panel between the washer top and control panel,is the wiring diagram. It will show you where the wires come from to power the pump. I am not absoluty sure but believe its directly from the timer to the pump. So find what wire is the hot one and check continuty on it from the timer to the pump,and the neutral wire check that for continuty as well. The hot wire is exclusive for the pump circuit,the neutral wire ties into all neutral wires so continuty can be checked on it from any neutral wire to the neutral for the pump.If continuty on both wires,Replace the timer. The washer timer part number is 131758600 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Gene..OldTech2332
Aug 20, 2011 | Frigidaire FEX831CS Top Load Stacked...
My washer has filled up with water and then just stopped and wont begin the cycle...
Try manually advancing timer . If washer starts , timer motor is bad or gets stuck , or water level switch is bad and not sending power to timer.
If washer doesn't start ,the lid switch is stuck not sending power to timer or god forbid, timer is shot.
In some models , lid switch controls everything which may be your problem .Try manually operating lid switch or jumping it with jumper wire.Or just replacing. Its' the easiest to fix and most likely problem.
Good luck
Aug 15, 2011 | Maytag PAV2300 Top Load Washer
Washer filled with water but has stopped and will not adgetate or spin
next time send the model number.check the lid switch.set it on spin,close the lid and then open it a few inches,do this a few times repeatedly,if you don't hear a clicking sound when the lid opens and closes the switch is bad,you can try sticking a screw driver into the hole on the top right side to see if it will spin,no clicking sound when you push down on the switch the switch is bad,or you can pop up the top console,you might have to remove the corner covers to get at the screws,when the screws are removed push in the timer so no power is going to the machine,set it on spin,lift the console up and you'll see two clips,on the right side you'll see a white wire harness connection,that's the lid switch,disconnect the harness,it plugs into the top of the washer on the right side,when it's apart,stick a jumper wire into the two outside holes of the harness that you removed from the lid switch,the middle hole is the ground,when you have the wire pushed into the two outside holes pull the timer out and if it starts to spin then you know it's the lid switch.let it drain out the water then push in the timer knob to shut it down remove the jumper wire and get a new lid switch,when you have it pop the two mtal clips and then you can pull the frame off of the washer to get at the switch.if you send me the model number i can look up your washer and give you the part number or you can call your parts store,give them the model number and they will sell you the correct part.good luck with your washer.if the motor runs but it's doing this you could have broke the motor coupling,let me know what problem you find and i will send you a video to help you change out the lid switch or coupling.
Jun 21, 2011 | Kenmore Washing Machines
I just bought an older electronic Intermatic timer at a yard sale. Model ET7215C. Timer power can be 120/240/277. There are 5 terminals for this, numbered 1-5. Looks like a variable tap power transformer....
I think you have the ET70215C SPDT
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
If this is not your timer, then add a comment.
Manual for ET70215C (same manual is for other models too)
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70215c%20-%20english.ashx
Just as you figured, timer has selectable voltage.
Page 28 shows wiring diagrams and jumper settings:
Timer comes with a jumper, and then you select with voltage by installing jumper
Sample wiring diagram below shows 120Volts:
ET70125 appears to have 8 terminals.
Some models have 5 terminals.
There are many ways to wire this timer. Off hand I can think of 10 different ways.
Add a comment if you need help with a specific project.
In any case, the clock terminals are 1 and 2.
To put voltage to the timer switches in the simplest wiring options, is to put a jumper wire from terminal 2 to 3
If you are using 240-277 voltage with two hot wires, you still need to jumper from clock terminals to switch terminals. For example one jumper wire from terminal 2 to terminal 3 & then second jumper wire from terminal 1 to terminal 6
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 08, 2011 | Intermatic Hardware & Accessories
Kenmore 80 series washer, replaced lid switch already, will fill, wash (agitate) but stops before draining and spinning and will not run. Is the timer the next step for replacement? Model: 110.29852991
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Aug 14, 2009 | Kenmore Washing Machines
The washer timer gets to the drain part of the timer before rinse cycle and stops it never emptys the water out the washer and the timer stops. I think it might the time delay switch knob just guessing...
i think its the lid switch.... pop the timer consol up and locate the wire harness connected to the housing take it off and put a jumper wire there and see if it goes then .... whirlpoolpartssurplus.com i can send you this part free shipping if you call me
Jun 26, 2009 | Kenmore Washing Machines
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Jul 04, 2008 | Maytag Atlantis MAV6451 Top Load Washer
WASHER BROKEN HELP I HAVE A FAMILY OF FIVE NO TIME TO WASTE!
Probably needs a new timer. This is usually more than the machine is worth.
Jul 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
