Question about Optics
I'm using a red dot scope on a mossburg turkey gun with a choke. I'm using the 3'' heavy tungston loads for longer distance shots. What distance should i zero in the scope at? 20 yards? 30 yards? 40 yards? /
  • 96 Answers
Your mossberg turkey gun is fine, 30 - 40 yards is more than plenty for turkey and other game, I'd dont see a point of adding a bigger and better red dot. I converted my mossberg 500 turkey gun into a defender with compstock, heat shield, surefire tac pump mount. sticking to slugs and hatton rounds for three purposes survival, breaching door hinges and, for defense
Posted on Dec 13, 2009
  • 117 Answers
I set my sights for 30 yards.40 yards is a long shot because you always aim for the head when hunting turkeys.Good luck with the Mossberg.I traded mine for a Remington.Still got a Mossy for a "loaner" or a backup gun for a client.The 3.5 magnums are simply too punishing to the shooter.
Posted on Mar 24, 2009
How do you boresight a Barnett Red Dot 3 crossbow scope?
I use a 22 cal rifle laser on mine , the 22 is nearest the same diameter to the bolts I use so I can lay laser right into same bolt bed on frame that bolt normally rests in , then bench rest bow and get into shooting position then adj scope to bring crosshairs/ reddot onto laser dot at white target board , try to adj at distance you'd comfortably take a shot at
Sep 07, 2015 | Optics
Gamo cfx royal
Zero the weapon to 30 yards at first then try to get all your shots inside a 40mm circle once you can do that move out 5 yards and repeat until you reach a distance you are happy with like 50 to 60 yards as long as your first shot placement is the kill shot
Nov 03, 2013 | Optics
Son just bought me a Bushnell Banner Dusk&Dawn 4 Plex, Mil-dot, 3-9x50E. Just looking for an explanation on all the marking on the reticle (inside of the scope) I understand the cross hairs and how to...
Simply put, the Mil-Dot is a way to estimate range with the scopes reticle. This type of reticle was developed for military applications. The space between the dot centers is equal to one milliradian (Mil). hence the name mil-dot. One Mil equals 3.6" inches at 100 yards, or 36" at 1,000 yards. To use this system effectively you must know the size of the target. For instance most people are an average of 6 feet tall or 2 yards. The formula used for determining range to the target is (size of target x 1000 divided by number of mils the target covers). Hope this helps FixYa up.
Aug 28, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I bought the new mossberg 22 tactical rifle . I tried to mount 3 different scops and they all shot off by 8 inches at 25 yards, the incline on the scope rail is at an incline. Is their another rail I can...
Off which way at 25 feet. If the gun is shooting low at this distance i would back off to 25 yards. It may shoot low because the scope is mounted a about 1 1/2 inch above the bore of the gun. In the 25 feet there is not enough bullet rise to compensate for that sight being that far above the bore. You may have to go with a red dot type or just add a laser if you are going to stick inside your 25 foot zone.
Aug 19, 2011 | Optics
Hi, I have a Tasco PDP3 redpoint on a 12 guage shotgun. It will group good for 3 shots then wonder off. I've found it to be loose somewhere on every occasion but the last one. My last shot hit the bullseye...
This does sound like it needs a bit of Loctite. But, You need to check this first, Is the scope being put in a bind due to heat from shooting. So, shoot for your group but wait say 7 to 8 minutes in between each shot. If in this case the gun stays on target every time, she is just getting hot and the heat is causing expansion in the mount / receiver area. If she jumps around during you timed shooting, then Loctite her in place, and Retry. If your sighting in slugs for deer hunting, your shots will always be from a cold gun, she needs to be on target cold not hot.
Dec 14, 2010 | Tasco ProPoint Red Dot Matte Red/Green Dot...
NEED INFO ABOUT ADJUSTING WINDAGE & ELEVATION ON MY MILLETT SP2 RED DOT. I LOST OWNERS MANUAL &NEED TO KNOW WHAT EACH CLICK IS EQUAL TO AT 100 YDS
the best way to sight in your red dot is clamp your gun in a gun vice or work mate? so it cant jump about!!!!!!! look through the barrel at a post say 100yds away then tweek the red dot or croos onto this post,,then test fire the gun and tweek the scope till its shooting were it points,,easy,,,
dont let the gun move at all,,,,you need to remove all the wobbely bits,,your the bigest wobbely bit?
an im not being nasty,,,you cant tweek a scope hand held?
Nov 27, 2010 | Millett SP2 Compact Red Dot Sight 5 Min...
Point of impact changes with every shot
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Jul 30, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
When you zoom your scope does the impact point change on the target? is that when you use mil dot?
No, the cross hairs remain fixed. The zoom serves only to magnify the field of view.
Aduz
Mar 25, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
How to sight scope in /what scope do i have ?
Real simple Scott.
You can 'Zero' your scope/rifle even if you don't have a laser bore-scope device.
All this is assuming that your used rifle has not had the barrel shot out and that the head-space is still within specs for that rifle. Have all this checked by a gunsmith first. You can dress up a piece of poop and it will be pretty, but still be poop. Make sure yours isn't to begin with. As for the scope, it's hard to tell unless there's obvious damage or it's an antique past it's prime. Try to get as good a quality scope as possible to start with. You would not put one ply tube tires on your mustang and expect to get the best performance, so...
Most rifles are capable of shooting quite accurately, and all things being equal, it's the shooters job of making it happen.
Ammunition should be considered as well. Toss your old military ball ammo and junk from overseas, both of'em. If you want to shoot accurately and consistently, you must spend the bucks for the best ammo you can afford.
You MUST KNOW what the BALLISTICS are for the Cal./type/weight ammo you will be shooting and the corresponding distance it will be shot from.
Make sure your rifle is CLEAN inside and out. A clean rifle is a happy rifle.
Make sure that your rifle 'fits' your body's frame and that you are familiar and practice good rifle shooting techniques.
'Zeroing' is best done from the prone position as that is the most steady position to shoot from.
Do you have a bi-pod attached? Whether you do or not, sandbag your rifle securely but still able to make small adjustments to the rifle position itself.
Set up a target with a 1" black dot at 50rds.
Remove the bolt.
Lay down with your rifle but stay OFF of it, touch it as little as possible at this point.
With out disturbing the rifle look through the bore downrange to your target. Locate the black dot and if necessary adjust your rifle from the **** end until you can see the dot through the bore. Keep making minor adjustments until the dot appears to be centered in the bore. Make sure rifle is secure and steady at this point.
Then without moving or touching the rifle, look through the scope using the correct eye relief distance and locate the black dot. Now using the Vertical(Elevation) and Horizontal(Windage) adjustment knobs, move the reticles(crosshairs) until they both are centered on the dot.
Again look through the bore to make sure that you have not moved the rifle and that the dot is still centered in the bore. If not, adjust the rifle again to center the dot, then go back to the scope and adjust as necessary to move the RETICLES to the center of the dot. It may be necessary to repeat this a few times before you have achieved this particular goal.
You do not mention brand/model of your scope. It probably adjusts the reticle or crosshairs in 1/4minute increments (1/4 inch increments with each individual click movement of the turret knobs at 100 yard distance). IT IS CRITICAL for you to know how your own scope adjusts.
Now, bolt back in and load 3 rounds of quality ammo.
You are going to shoot 3 rounds in succession without getting off the rifle or making any adjustments to the rifle or scope. You are looking for a 3 shot group to determine a rough average of how far and where the rounds are impacting initially. Use good shooting techniques, breath control, relax, sight picture, squeeeeeeze the trigger, follow through the scope, there is no need to take your eye off the scope while doing this, hold your shooting position for all 3 shots.
You will now have to make adjustments of the scope unless you are hitting the black dot already which is quite possible.
Remember that if your scope is a 1/4" adjustment at 100yds, it means that for each 'click' that you adjust either Vertically or Horizontally at 100rds, the reticle/crosshairs will move accordingly 1/4 of an inch Vertically or Horizontally. At 200yds, one click will move it 1/2 inch, at 300yrd it will move it 3/4 of an inch, at 400yrd, it will be 1 inch.
Right now you are at 50yrds distance from your target. Each click from here will move the RETICLES about 1/8 of an inch so estimate the distance that your most central shot of the 3 you fired, is from the black dot and adjust accordingly. You're not moving the RIFLE here, you are simply moving the scope RETICLES so that your point of aim and point of impact coincides.
Now load 3 more rounds of ammo and repeat as above. You should only have to use about 9 rounds to get on target, the black dot.
Once you are hitting the black dot at the 50yrd line, move back to the 100yrd line. Put a fresh black dot on your target and repeat the steps from above. Your first 3 shots from the 100yrd line should be about 1/2 to 1 inch low. Don't follow the bullet strikes! Keep your point of aim and the crosshairs ON the black dot no matter where the bullets are striking on the target. Remember, now at 100yrds your RETICLES will move 1/4inch with each 'click' of adjustment of the turret knobs.
Adjust the scope as needed at this point. Once you are 'ON TARGET'(hitting the black dot), you now have your 100yrd. 'ZERO'.
Now that you have this 100yrd ZERO, you must loosen the turret knobs , both the Vertical(Elevation) and the Horizontal(Windage) turrets and align the '0' on the knobs with the '0' on the scope at the base of each knob. Now tighten the set screws and you are set to go. If you want to know your 200yrd 'ZERO', simply move back to the 200yrd line, your 'come-up' or elevation adjustment should be about 7-9 clicks, at least for .308 168grn HPBT, but you will figure it out for the Cal./brand/wght ammo you are using. WHATEVER the 'come-up' you need to make at 200, 300,400yrds or wherever, be sure to make note of the number of clicks you used to find the Zero for that distance. Use a fine point endelible marker and actually write the ZERO info on thestock of your rifle. You don't need to mark anything for the 100yrd ZERO, it's a given already. Write; 200/9, 300/18 and so on. You should also get your ZERO for the intermidiate, 150yrd, 250yrds etc, distances as well.
Remember that weather conditions, source and intesity of light conditions, your own body condition at any particular moment or day can have an affecf on how you and/or your rifle shoot. Good luck.
Mar 21, 2009 | Tasco ® Silver Antler® 3-9x40 mm Scope...
Scope
Follow these steps
1) Mount your scope.
2) Use a bean bag or rifle mount and make sure that your rifle doesnt move much from its original position throughout this process.
3) Aim with the scope and shoot at a large backstop which will allow you to see where your shot lands, where ever that may be, it doesnt matter at this point. Again, make sure your rifle doesnt move much when firing.
4) With the rifle in the same position, look through the scope and adjust the crosshairs over to where your shot landed.
5) The scope now sighted in with the rifle. Minimal adjustment may still be required but at least your well within the ball park.
Happy Shooting
Nov 13, 2007 | Bushnell Trophy Multi-Reticle Red Dot...
Optics Logo
451 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
