Question about AOpen MX4LR (91.89Y10.002) Motherboard
Need to know how to do the power leads and so on to motherboard
    Problem Solver:
  • 8 Answers
Hello the easiest way to do this is get the model number off the motherboard once you have that go to the makers website like asus , Msi , etc depending on the board and type the model number into there serch bar and it should give you an option somewhere to download the manual for the motherboard which will have all the connectors listed on the motherboard so you know what goes where. Good luck
Posted on Mar 08, 2009
Need directions to hookup leads
Hi ,
The best way is to get the manual for the motherboard , you can do this by going online and google the make and model of your motherboard , but its somewhat easy , you have the power supply cords you need to plug in and then install your processor or CPU , along with the fan that has a connection lead you need to plug in right next to the cpu ............and really thats it .
if this doesnt work , let me know ............Roy
Aug 06, 2011 | Computers & Internet
When i turn my computer on the power light on the front flshes about 2 or 3 times then thats it i dont know wut to do about it
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem:
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
hope this helps you
Jul 28, 2011 | EliteGroup 661GX-M Motherboard
CPU problem - when i turn on my computer the red LED blink nine time's and my computer does not boot.. i check on the forum it say's CPU problem, Motherboard or power supply.. My power supply are still...
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 29, 2011 | Computers & Internet
Does not work
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Mar 08, 2011 | Computers & Internet
Sorry I do not know where I will plug the power sw, power led , speaker cable
This might help you > http://www.ehow.com/video_2200437_install-power-reset-switches-computer.html
Mar 01, 2011 | Computers & Internet
With power button push in the light comes on and fan comes on but in 5 seconds it turns off. I've tried with battery out and just with power plug , still the same results.
Can be one of the following
  • Remove battery and power lead - press and hold the power ket for 60 seconds. put in power lead and it may start.
  • If you are getting beeps or lights flashing then you have a Power On Start up Test (POST) error. This means you have a hardware failure in the system. The actual error depends on the motherboard and the error beeps. Solutions vary depending on the error, can be from replace memory to motherboard is shot. Please let me know if you are getting beep codes, this may need professional repair.
  • Does not start and no beep codes, then the power or the motherboard has failed, this will need professional repair.
Jan 19, 2011 | Toshiba Satellite M65-S809 Notebook
MS-7061 Motherboard ver 1.0
I want ms-7061 motherborard ver1.0 dirver please help me
Aug 08, 2008 | MSI : MS-7061-020...
Front panel leads
if you can get on the internet just type in on google the motherboard you have and maby you can get a picture
Jun 24, 2008 | E-Machines Computers & Internet
Reset/power/led etc..lead connections
hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
Aug 05, 2007 | EliteGroup P4M800PRO-M Motherboard
AOpen MX4LR (91.89Y10.002) Motherboard Logo
70 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
