Wahing Machine wont drain--Centrex CTW 60518
Its a top loading Wshing mAchine, That i inherited with my new house, being a student id like to fix it myself, or find the cheapest way to.
It is full of smelly water, that wont drain. I tried putting it through different cycles, but to no avail. Also figured out that it makes a funny noise during the rinse cycle but doesnt move, and when it gets to the spin cycle, it beeps and some lights flash. And it stops.
Any ideas as to what it could be..and how i could fix it?
  • 15,935 Answers
It appears your pump/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Ned a new drainage hosed for a centrex twin tub washing machine. Any help?
yes go to the manufactures website and request the spares department for the part from them eric
Jan 01, 2018 | Washing Machines
Manual for Centrex CTW 60519
do a search on google.com sometimes you can find one through there.
Mar 08, 2015 | Washing Machines
How can I drain a top load washer stopped in mid cycle
Use a wet vac easiest way if unit is in the basement on a non carpeted floor lower the drain pump to the floor it should drain if not there is something in the drain pump or a bad bearing in the drain pump a bad belt will cause agitation problems too
Feb 15, 2014 | Washing Machines
My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
Jul 12, 2010 | Estate ETW4100SQ Top Load Washer
Wahing machine wont spin out with full load .will with small load
I would check to see if you have a kink in your drain hose. The timer allows the same amount of time to drain if it is a full load or a 1/2 load. If the drain hose is kinked it restricts the volume of water being drained leaving water in the tub when doing a full load.
Dec 30, 2009 | GE WBSR3140DW Top Load Washer
Looking for a lid for a centrex washing machine model ctw60518
We have a Centrex Washing Machine, Model No. CTW 60518 Top Loader, which has recently broken-down. It leaks and not emptying completely on the spin cycle. We are unable to have repaired due to parts unavailable. If anyone would like this machine for parts kindly phone (07) 4936 4185 (Queensland -The machine has not been flood affected).
Vicki
Jul 07, 2009 | Washing Machines
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
