Question about Air Tools & Compressors
Tool wont work with air compressor, and shoots out air and the sander does nothing
Air throttle valve broken
Posted on Aug 31, 2009
  • 226 Answers
Normally when the air will not drive the tool, it is because 1- the tool is rusted up inside, 2- there is no lubrication of the moving parts - which can be remedied by putting something like WD40 in the inlet with the air switch open, 3- the drive parts are broken or worn out, 4- not enough air volume/pressure to run the sander.
You probably need to spray some lube as above & see if that will get it to work. Also turn the sander part by hand. Rick
Posted on Apr 15, 2009
  • jesse heineman Oct 11, 2013
    i tried all these things and it still doesnt work
Makita Belt Sander 9404 - dust collection bag not collecting the dust. Shooting dust out the front. What can be done to remedy this?
the tool needs cleaned thoroughly. there might be a section of a belt that has jammed the passageway. UNPLUG the tool and turn over to see on the backside if the clog is there, if not I would recommend using safety glasses and compressed air to blow thru the channels to dislodge the material. I havae also used a shop vac to help in this.
Jul 27, 2011 | Makita 9404 4'' x 24'' Belt Sander
Hello I have a compressor and my electric orbital sander has finally gone legs up. My question is if I get an air sander primarily for sanding wood is a straight line the best sort to get or are the...
I work in a wood working shop and we use orbitals on everything. You still will still sand with nice even strokes with the grain. It leaves a great finish. They are nice, light, and easy to use! They do use a lot of air though, so make sure your air compressor can handle the one you buy. If you compressor is constantly running you might have to take breaks so you do not burn it up. enjoy!
Apr 11, 2011 | Sander Viking Air Tools Dual Piston...
I have a porter cable belt sander that shoots dust out the front. It has a dust bag but the wood dust doesn't go in the bag. it used to. I have taped up some weak parts of the bag but I am not sure what...
the inside of the tool is full of dust not allowing it to get into the bag. I have had to completely disassemble and clean the track for the dust. You can try blowing thru every port with compressed air and see if that helps.
Nov 09, 2009 | Porter Cable 3" x 21" Electronic Variable...
Belt sander 3x24 Porter Cable
Try some "Simple Green" concentrate cleaner, or the "Simple Green" barbecue cleaner in a spray can to clean the roller. Should not use a dremel as you probably know now because of damage.
Another good idea is to blow out the tool after each use with compressed air. An air compressor is a great tool for a lot of things!
May 30, 2009 | Porter Cable Cable Tools 3" X 24" Belt...
DA SANDER RPMS SLOWED
get some air tool oil and oil it lol, if that will not speed it back up you may have to take it apart and clean it but the oil should do the trick. Do NOT use wd40, etc. use air tool oil
May 23, 2009 | Chicago Pneumatic 864 6" Heavy Duty Dual...
AIR VOLUME REQUIRED
You need to look at the tool cfm requirements because they are posted on the package or usually in the ads. Your compressor will run the sander, just how long at a time will depend upon your tool's cfm. Rick
Apr 14, 2009 | Air Tools & Compressors
Air Sander tips
* Proper match between air compressor and tool ratings. * Correct fittings that match the tool and air hose. * Well-maintained air compressor and air hose. * Correct air pressure adjustment for the tool being used.
Aug 27, 2008 | Taylor Pneumatic: DA Sanders: 10000RPM....
Portable Air Compressor Comparison
Portable air compressors give flexibility to the job both inside and outside the working environment. They're powered by electric, gasoline or diesel engine. A larger portable air compressor often has its own carrying trailer with wheels and handles. You buy a compressor based on its horsepower, pounds per square inch (PSI) and cubic feet per minute (CFM). Choose a portable air compressor to make work quicker and easier. Figure the amount of power you need based on the type of job and air tools used. Know the cubic feet per minute (CFM), such as 5 CFM for small household tools and 10 CFM or more for wrenches or sanders. All air tools have these ratings. Select a gas- or electric-powered engine. Gas gives a higher reliability for frequent use and portability, but consider electric for enclosed areas for its lack of fumes. Pick an air tank based on amount of use time and tools. Large tanks are best for longer use with sanders or grinders and smaller tanks for less time, like wrenches and air hammers. Consider the pump type you need: belt for heavy use or direct-drive for light home use. The quieter belt-drive pump needs periodic oil changes. Buy an inexpensive, small electric portable air compressor for small jobs. These typically operate from a 12-volt power outlet and inflate a 14-inch tire in a few minutes. Get a 150 PSI, 120 volt motor pancake-type air compressor for home use. These light-use models typically carry two air couplers, allowing hook up of two air tools and adequate 25 feet or more air hose. Obtain a larger PSI portable air compressor for bigger jobs, like nailing, with longer continuous use capabilities.
Aug 27, 2008 | Acme Automotive ACMA680CS Typhoon High...
Air Tools & Compressors Logo
771 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
