Question about Fuji FinePix F650 Digital Camera
Zoom lenses is extended but wont go back in - Fuji FinePix F650 Digital Camera
  • jettablue202 May 21, 2009
    How do I set my Fuji F650 to high resolution?
  • 60 Answers
Switch on and PRESS the "wide angle" selector switch. (in camera mode)
Now the lens should move partially back in.
If it does not move inwards at all and you do not hear a whirring noise, then the activator motor is defect.(or the lens assy is out of alignment). (or a foreign object has entered the gearing, and stalling the motor)
If you do hear the motor running, then a gear might be stripped.
All these faults do require to take the camera apart.
Posted on Mar 08, 2009
What is the L switch for ?
That is the ZOOM LOCK SWITCH
This stops the zoom extending when you carry the lens.
Set it at 24 mm setting to stop the lens barrels from rotating and extending.
Unset it to free the lens again.
Aug 07, 2014 | Tamron Sp 24-135mm F/3.5-5.6 Macro Ad If...
Finepix j27 When the camera is turned on "Zoom error" message appears and lense is stuck in an extended position. When the power is turned off, the lense remains extended. Do you know how...
hi, Zoom Error occurs when there the lenses are not able to move and something is obstructing the movement like some dust or sand grains etc., to dislodge the obstructing particles try tapping the lense side corner of the camera on a table top lightly (not too hard please, as the lense and autofocus combination is quite fragile) a couple of times in switch off mode and trying to power on after every 2-3 taps.
or you might send it out to a service centre, the charges are generally just the serviceing charges as no new parts needed.
hope this helps
cheers
May 05, 2011 | Cameras
Canon Extender EF 2x II
There are 2 Canon fittings, EF for all EOS cameras and EF-S for 'crop' cameras. The Canon extender does not fit crop cameras. Whichever make you look at, make sure it will fit the type of mount you have.
If you have not yet bought your lens of choice, Sigma are good and do their own extender compatible with their own lenses but not Canon's. This may be a good option for you
Mar 07, 2010 | Canon EF 2x II Extender Lens 6846A004
Fuji finepix a600
If the camera was on when it was dropped you probably jamed the lense coil. The lense coil is what helps the camera smoothly pull in the lense and back out. Now, just to specify, what exactly are you having a problem with? Will the actual lense not go back into the camera when you turn it off; or can you not get your camera off zoom?
Let me know~
Olivia
Oct 30, 2008 | Fuji FinePix A600 Digital Camera
Zoom error
you may be true that sand must be creating this problem, as this happens very often. the sand enters into the lense assembly, creating friction in the movement. if this has happened total dismantelling and cleaning of the lense assembly will solve the problem, but that has to be done by an expert at the repair shop.
Aug 17, 2008 | Olympus Camedia C-350 Digital Camera
Zoom problem
sitch on when the lense extends take hold of the end and gently twist and pull the lense you may hear it click. be gentle do not force it then switch on and off again this should solve the problem
Jan 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Lenses
Your camera's problem is with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 15, 2007 | Canon PowerShot SD850 IS Digital Camera
Zoom error message
Aug 07, 2007 | Olympus SP-350 Digital Camera
Fuji FinePix F650 Digital Camera Logo
230 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
