Question about Cameras
My Olympus camera will not turn on even when new batteries are inserted- the power light flickers then goes out.
  • doodygoodman Mar 08, 2009
    I have tried the advice from the first expert myself with no effect.
    Still no response- the power flickers then goes out
  • 154 Answers
Reset your camera and try again.
Posted on Mar 08, 2009
  • crysiszone Mar 08, 2009
    Tt seems that you purchase some wrong batterys (it may be of high AMPs.)
    President:
  • 987 Answers
Remove the batteries and let it sit for at least 12 hours, to make sure the
camera's completely drained. This will cause the camera to reset to factory
defaults and maybe, just maybe, bring it back to life.
  • Sibananda Mar 08, 2009
    If you are using alkaline batteries or have bad electrical contacts
    between batteries and camera, that could be the problem. I accidentally
    had an Adaptive Lighting option turned on and my camera indicated
    battery low until that option was turned off. The more programs your
    camera is running, the heaver the load.
    Repair of cameras is more expensive than replacement, but it may help to clean and charge the batteries as described below.
    A friend asked me to clean and charge her new 2000mAh Duracell
    batteries as described in the next link. Those batteries are still
    going strong after four months of normal use and have not been
    recharged.
    Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts.
    http://www.google.com/base/a/4210404/D13...
    Most NiMH rechargeable batteries lose charge and should be recharged
    when not used after two weeks, but Duracell and RayOVac new formula
    2000mAh NiMH batteries hold charge one year when not used. Also,
    2000mAh batteries seem to have a longer life. Did not like these
    batteries at first, but have 12 over five years old and all are still
    as good as new. Higher mAh batteries (about one year old) still work
    well in flashlights, but won't start my camera.
    CAUTION Do not overcharge! Batteries can be damaged. Use an automatic
    two or more hour Energizer Compact smart charger with temperature
    monitor, trickle charge technology, and safety timer ($9.76) at
    Walmart. Use pre-charged 2000mAh Duracell ($12.97) or RayOVac ($5.97)
    batteries (both hold charge one year) and a full cycle charge. To
    preserve battery charge, use the viewfinder.
    This could be the best slim line camera with a viewfinder and ... It's
    PINK, but it uses a $49.50 Series G Rechargeable 960mAh lithium-ion
    battery.
    http://shopping.yahoo.com/p:Sony%20Cyber... ...
    http://www.digitalcamerareview.com/defau... ...
    http://www.batteryuniversity.com/parttwo... ...
    This link is about prolonging the life of lithium-based batteries which
    last from two to three years, but are very expensive. A Sony series G
    rechargeable 960mAh lithium-ion battery is $49.88 at Walmart.
    If batteries are removed more than a few hours, the date/time setting
    and other set-up information will be lost. If the camera is being
    stored for a long time, the batteries should be removed and stored
    properly.
    Carry and dispose of batteries in baggies, blister packs, or other
    containers to protect ends from short circuit. Batteries explode when
    short circuited. NiMH batteries are environmentally friendly and may be
    discarded with trash.
    Camera reports batteries low, but is it low charge or bad electrical
    contacts? Overcharging can ruin good batteries! The secret to making
    digital cameras work better is having good electrical contacts between
    batteries and camera.
    Digital cameras require lots of power. Bad electrical contacts can
    cause lots of problems so battery and camera contacts must be cleaned
    properly. Batteries may be fully charged, but camera will indicate
    "low" if contacts are not really good. The LCD screen is a low steady
    load, but when lens extension, optical zoom, focus, and flash charging
    are added in the capture mode; the load is very heavy. Bad contacts
    make cameras do strange things like making bad pictures or shutting off
    with the lens out.
    NiMH batteries should be recharged when camera reports batteries low.
    Old batteries can discharge over night, but may provide normal service
    immediately after being charged. Battery pairs no longer usable in
    cameras may work well in flashlights. Do not drop batteries or allow
    voltage below one volt.
    CAUTION To prevent memory card corruption, keep batteries charged,
    format in camera, and don't delete or fill card completely. Wait for
    lights to stop flashing then turn camera off before removing memory.
    For card readers, double click Safely Remove Hardware. Select, then
    click Stop and OK.
    Never touch battery ends or camera electrical contacts. Oil from
    fingers will contaminate contacts. Use batteries in matched pairs of
    same brand and rating. Do not mix old and new batteries. New will only
    do as well as old.
    Click source link for other camera tips and complete instructions on cleaning camera and battery electrical contacts.
    Source(s):
I have olympus camera battery charger, it charges a battery then when the next battery goes in the light keeps flashing it should be solid light
three things to try.. reverse polarity on the charger (turn the plug around), clean the copper contacts on the battery and charger, get a new battery
May 20, 2011 | Digipower Travel Charger for Select...
Camera won't work even with new batteries
Just had that same thing happen.
Try lithium batteries...Should solve it.
Jun 14, 2009 | Olympus FE-210 Digital Camera
Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Apr 15, 2009 | Samsung Digimax A6 Digital Camera
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
No power on olympus D-535
Did You try to reverse the battery's (Put the left battery on the right side and etc)?
Oct 30, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Camera malfunction
mine is doing exactly the same arrrrrrrraaaaaahhhhh
Apr 25, 2008 | Olympus SP-350 Digital Camera
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
DIGITAL CAMERA
clean the battery and battery compartment with alcohol and let air dry for an hour before inserting battery
Dec 20, 2007 | Olympus SP-700 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
