Question about Philips DVDR3370H DVD Recorder/HDD Recorder
Philips DVDR 3370h dvd tray stuck
Inserted a dvd. now dvd tray will not open
Hi there, if you found solution to problem please e-mail to josepht@eskom.co.za
Posted on Aug 31, 2009
I have a dvdr 615/17 with a disc in the dvd and the door will not open. The info window goes from opening to closing but the dvd never opens .
Mine does the same thing. Press eject then press and release the face of the tray. I have also had luck with gently prying a corner of the tray face after pressing eject. One other is once you get the tray out, remove the tray face.
Daddy long legs.
May 10, 2010 | Philips DVDR615 DVD Player
Dvd is stuck inside and drawer will not open
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
Dec 02, 2009 | Philips Televison & Video
My dvdr 3380 is blocked...what can to do?
the rubber belt inside de dvd player to open de tray is broken. I replaced it with a elastiek. you need some technical skills to repair it.
Aug 01, 2009 | Philips DVDR3380/05 DVD Recorder
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
PHILIPS DVDR 75/17 error code C003 TRAY BLOCKED
jim, try to open the tray manually open the cover rotate the motor or the belt manually.
Dec 13, 2008 | Philips DVDR755/17 Burner
I have a philips dvdr 3450h and require a replacement dvdr drive it only plays cds now
it plays cd music ok unit functions h/d ect but no dvd and inside the drive clicks as though its searching when disc inserted if any help? kbg08mcr
Apr 15, 2008 | Televison & Video
Blocked
The solution for this problem is on this forum here http://www.fixya.com/support/t353456-dvd_player
Apr 13, 2008 | Philips DVDR 3355 DVD Recorder
Stuck in "UPDATE"
I just found on the Philips website a file to download and have the DVDR use to update itself to fix that problem and a few others. I've not tried it yet but will be doing so tomorrow. It's worth a shot.
Nov 07, 2007 | Philips DVDR3390/37 DVD Recorder
Televison & Video Logo
419 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
