Question about Hotpoint Ultima WF860 Front Load Washer
Ultima wf840 flashing f-05 dont know where filter is
Have emptied machine but the water is not draining away on spin cycle
  • stuartimber Mar 26, 2009
    8 pence .. 3 hairbands .. 1 hairgrip .. a rivet .. a needle and a key that nobody knows what it's for - yeah i think it's safe to say our pump was blocked!! And as for all the **** in the drainage pipe!!! Just put it all back together now and running the machine (with soaking clothes) on a spin cycle. Fingers crossed but if this works you are a god mate .. thank you very much - I was just about to rush out and bye a new machine!
    President:
  • 1,294 Answers
I give you here the filter & pump details:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a ball. Lift it out carefully and you will probably find an obstructions like a coins or clips. Do not take off the white hose clips.
After the filter comes the pump, disconnect. Slide pump to left and lift, it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean out any obstruction and reassemble. Refit all as you dismantled.
Posted on Mar 08, 2009
My hotpoint ultima wf860 looks as though it is stuck mid cycle, the water will not empty and the display is flashing F-05 in the dispay. ive not tried anything yet as not sure what the problem is.
Hi Mark from retired Englishman in SW France,
Indesit (Hotpoint/Ariston) 'F05' stands for 'pump block'.
(the following I've pre-typed- very common problem!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 17, 2011 | Hotpoint Ultima WF860 Front Load Washer
My washing machine is giving me F-05 on the screen, it will not empty after the load has finished, please help (Ultima WF840)
Sound like your drain pump is blocked. Tilt the machine as far back as you can to access underneath. The drain pump is located at the rear corner. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
Hi we have a Hotpoint Ultima 6 kg PowerStream Wash System washing machine and the pipe seems to be blocked, when spinning the machine can not drain the water. Does this machine have a plug somewhere what...
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 12, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima wf840, what does this mean F-05
F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Apr 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Not draining or spinning as it should, cloths coming out wet. machine is the ultima WF840, can you help?.
You could have one of several problems:
* water pump
* motor
* clogged drain
* electronic control board
Contact an appliance service of company.
Feb 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf840
f05 meas not drained. usually due to a blockage in your filter.
you will need to get the water out by holding the drain hose lower than the machine into a basin. when drained the door can be opened. unscrew the filter and check for coins/socks etc.
Jan 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Dec 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Ultima WF840 won't go from wash to rinse cycle
the pump is blocked, so the sensor detects that the machine has not emptied in the allocated time, so this will reset the time.... the pause is because it knows there is a probblem getting rid of water.
location: bottom right near the motor. ensure you tip the washer as far forward as you can so you can get a bucket under in order to prevent flooding.
hope this helps
Aug 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima
the code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Feb 13, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
HOTPOINT WT940P
Lower the outlet hose into a low bowl, if water flows then you need a new pump cost around 20 pound to buy, If no water comes out the you have a blockage somewhere.
Nov 29, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
416 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
