Decalcify means that there's calcium buildup inside the coffee maker. You can buy stuff to put through it, but white vinegar works about as well. Fill the reservoir with vinegar, and start the coffee maker. You may need to run it more than once.
after it's run through, run 2 or 3 pots of clear water before you try to actually make coffee.
hi,probably your machine is need decalcify. Try to turn on the hot water knob when you start the machine. Fill about 1 water glas with hot water from machine.If the ventilate is still appear-you must decalcifying machine with special liquid for descaling.
Use diluted CLR to remove calcium, and then fill the water reservoir with vinegar, let this sit for a couple hours and then run the machine. Immediately run it again with water. Let it sit and dry for a couple hours and run water through it a final time before making coffee.
1. place water and descaler solution into tank 2. remove milk frother from arm 3. place a jug under steam arm 4.hold down the button 2nd from the right next to the menu button for a few seconds. 5.descaling machine open steam knob will appear on the display 6. after descale has finished "fill water tank" will appear. 7. refill tank with clean water no descaler 8.press the button 2nd from the right as in step 4 9. rinsing machine will appear. 10. when finished"close knob"will be displayed 11. refill water tank 12. ventilate will appear on the display 13.press the hot water button and allow to run 14.ventilate will disappear,warming should be displayed. 15. job done !!!
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
When it says to ventilate, it is asking you to prime the pump. Put acup
under the panarello wand ( the steamer/frother) to catch thedischarged
water and press the hot water button (upper left button onmy machine).
Wait until air stops coming out with the water, usually3-5 ounces, and
then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Try to make a cup of water (tea), make sure you get a full cup of water. If you only get a half cup of water then i think you have to replace the flow meter in the machine.
For ventilate: When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
For decalcify:
Recommend downloading and following these directions. http://www.partsguru.com/user/Safe%20Descaling%20method.pdf
