Question about Ricoh AC104 All-In-One Laser Printer
I am having CRU fuse error in my SCX 4216f. i changed cartridge but same error is there. please help
This is a "Fuser Error" -not cartridge. Unplug machine and then plug back in...if error returns, you have a problem with the Fuser (warm up error), and you need service.
Posted on Mar 08, 2009
Error code 13.09.00 & 13.20.00 .Can u provice the soluction .This is HP 5550 color laserjet .Pls do the need ful
Posted on Nov 10, 2009
What is a cru fuse error
The cartridge is running low so the 1 amp fuse in the cartridge blew out, you can replace the cartridge or follow these steps.
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
Jun 23, 2011 | Samsung SCX 4521F All-In-One Laser Printer
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Inserted new toner it says CRU FUSE ERROR
If you have a CRU Fuse error, you have probably purchased an after market toner cartridge. If so, take the cartridge out of the machine and at the back of the cartridge you will see a small 'dummy' fuse. Take that 'dummy' fuse out of the cartridge and your printer will work. I know, it happened to me.
Nov 16, 2010 | Samsung SCX 4521F All-In-One Laser Printer
I have error with this title: CRU Fuse error, but this is not stable. if i put out the cartridge and put-on again. it will removed and machine will running well. but it will come back at the next print...
This is a fuse error which is on the Cartridge, please check the cartridge very carefully, the fuse is somewhere on the edge of the cartridge/s, simply remove it and try again. You problem will be fixed. I hope your cartridge must be similar with this one.. (click here)
Fuse:
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 30, 2010 | Samsung SCX-4016 Laser Printer
Cru fuse error on samsung scx 4521f
i changed fuse 4521F , but : (cru fuse error) ???
Feb 12, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Cru fuser error
I already solved the cru fuser error by replacing the fuse of the toner cartridge.Thanks anyway for this information.
Jun 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Have a cru fuse error
Rick and Felix are discussing the fuser, not the fuse error you are getting with the your printer. The error relates to a small fuse that is on the toner cartridge which goes into the printer. I am having a similar error message after getting a replacement from Cartridge World (although this is not the first Cartridge World replacement for this printer).
After much research, one suggestion was to remove the cartridge fuse and reinsert the toner cartridge. That worked for me and the CFU Fuse Error message disappeared for me, but I am trying to find out the PURPOSE of having a fuse on the toner cartridge itself. To protect the toner cartridge? Protect the printer? Other?
Mar 10, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Double page copies and CRU Error
CRU Fuse error equates to a problem the machine has reading the print cartridge installed in the machine. It has nothing to do with the fuser.
Suggest that you change the print cartridge.
Oct 01, 2007 | Samsung SF 5100 Laser Printer
Ricoh AC104 All-In-One Laser Printer Logo
1,236 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
