Question about Fujitsu LifeBook S2020 Notebook
Fujitsu s2020 runing xp pro 32 bit screen **** in and out
Hi, my computer has problams and whene i start it the screen cuts in and out
  • Glenn  Sage
    Glenn Sage May 11, 2010
    Please clarify your unservicability a bit more - can you unit boot totally into your OS - is there some display visible in the background ( test in a dark room ) if you display flashed on and off you have a defective inverter in your display
  • Fujitsu Master
  • 32,281 Answers
Connect an external monitor to your laptop and boot up the laptop. If you get a steady image on the external monitor then the problem is the backlighting. This could be a faulty inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp, most likely thw CCFL lamp is nearly burnt out.
This problem can be repaired.
Go to www.lcdparts.net for parts, repair service and DIY information.
Posted on Mar 08, 2009
I cannot get rid of pceu virus on a windows xp pro fujitsu desktop because it has disabled safe mode and I do not have the windows xp cd to reinstall windows and the cd/dvd drive does not work .
Download the SP3 installation ISO. Save it to your Desktop. Download ImgBurn and save it to your Desktop. Double-click the installation executable for ImgBurn and click "Next." Follow the remaining onscreen prompts and click "Finish" to complete installation of ImgBurn. Insert a blank CD-R/DVD-R into your DVD drive. Open ImgBurn by going to "Start," "Programs" and "ImgBurn." Click "File," then "Browse for a source file." Navigate to your Desktop and select the SP3 ISO file. Click "Open." Click the blue "ISO to CD" button located on the bottom left of ImgBurn. The program will begin creating the Windows XP SP3 installation CD. This process may take anywhere from 10 to 20 minutes to complete depending on the speed at which the CD-R/DVD-R is being burned. Click "OK" once the CD-R/DVD-R has finished burning. You've successfully created a Windows XP SP3 installation CD.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en xp pro sp3 iso http://www.imgburn.com/ Download the iso also download the imageburn or
http://windows-xp-pro-startup-disk.soft32.com/ Bootable disk for XP Professional. The Windows XP start up disk allows computers without a bootable CD-ROM to perform a new installation of the operating system. Hope this helps.
Jan 21, 2013 | Fujitsu Computers & Internet
Hi, my windows XP pro is no longer runing. i end up with a physical memory dump Screen. But no longer open on my desktop PC screen.
Download Malwarebytes from filehippo.com and run on both computers in safe mode
Go to start and right click on my computer click on properties and then advanced then startup and recovery click settings. Where it says write debugging info click(small memory dump (64kb)
Jun 27, 2010 | Microsoft Windows XP Professional Full...
No operating system found after win xp uprade -
your operating is currupt ,you need to be repair your window.you choose the first boot device cd rom & repaire it.
Nov 22, 2009 | Fujitsu LifeBook S2020 Notebook
How to intall the audio divice to my computer
use the mainboard drivers disk which came with the system. Place it into your cd or dvd drive and windows should run the software on the disk automatically. then simply follow the procedure in the software..
Nov 02, 2009 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
I have a dell inspiron 9300 laptop runing windows xp. i want to download the trial version of sony vegas pro 9. do download 32bit or 64bit version --or does it matter? Thanks in advance for your help.
Right click on My Computer on your desktop and select Properties. If you have a 64-bit system it should say so in the window that pops up. It would say x64 after the Operating System name or 64 bit near the bottom.If it does not say, it is a 32 bit system.
You can also select Start>Run, type winmsd in the box and press ENTER. In the right pane look for Processor. If it is a 64 bit system the Processor line will start with ia64 or AMD64. If a 32 bit system it will start with x86.
Thanks for using Fixya.
Oct 12, 2009 | Sony Computers & Internet
Password forget to turn on fujitsu s2020
please remove and replace the cmos battery after 1minutes.
Sep 24, 2009 | Fujitsu LifeBook S2020 Notebook
Lifebook s2020 wont boot
try to replaced memory card or clean it first the pin of the memory card by using dry clothes
Aug 17, 2009 | Fujitsu LifeBook S2020 Notebook
Power button only turns laptop on when I disconnect battery, powe
The four buttons are for changing between your first four windows. Your screen dims to save power.
Your drivers sound like they are messing up your boot-up.
Use safe mode or your trick and use your fujitsu update my drivers program or use a program like Driver Detective.
I hope this fixed your problem.
Jan 20, 2009 | Fujitsu LifeBook S2020 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Fujitsu LifeBook S2020 Notebook Logo
96 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
