Question about Canon EOS 450D Digital Camera with 18-55 Lens
Occasionally I get 'ERROR 5' appear on the display on my EOS 450D - it is suggested that the pop-up flash is being impeded, but I know that it isn't. What is happening?
    Scholar:
  • 124 Answers
This is a common canon mechanical error.
Most of there SLRS do this the release inside the pop up flash hangs either due to weak spring or release catch itself. If it hangs for even a split second you get error code.
Try This.
  1. Clean Flash Release & Apply wd-40 with a q-tip to moving parts. DO NOT SPRAY INTO CAMERA. Use oil lightly.
  2. Or Assist flash when it tries to p up by lifting on flash gently. Maybe one day canon will fix this problem.
PS this happens to even Brand new Canons.
Posted on Mar 08, 2009
I have a canon eos rebel xsi 450D. i loaded the eos digital solutions disk on to my windows xp computer. it seemed to load fine. the memory card manager screen appeared on my computer.then a small EOS...
Not a good idea to post your phone # and e-address on this or any other site.
This question arrived on FixYa.
Problem is the camera firmware isn't compatible with the software possible needs a Canon free update or purchase a card reader and download your pictures stepping around the camera.
The computer will look at this card reader with the memory card installed as an external hard drive or memory device.
Download you pictures and then do a safely eject or eject before removing the memory card, once back in the camera remember to format the memory card this give the camera a nice clean surface to work with again.
Apr 17, 2011 | Canon EOS 450D EOS Rebel XSi Digital...
I am getting this message on my EOS 450d, (camera's built in flash pop up was obstructed turn the power switch to off and on again). I have done this several times the flash wont pop up - can you please...
Sometimes the pop-up flash on the EOS range of cameras can get stuck. The EOS family have a very tiny micro switch under one blade of the flash hot-shoe.
Get a toothpick and manually pop the switch. It should clear your error, too.
Good Luck.
Mar 28, 2011 | Canon EOS 450D Digital Camera
My new canon rebel T2i/EOS 550D Flash is not opening when i press shoot, it tries and tries and tries and show error 5.
A 5 error is the camera thinks the flash is not raising. Look near the hinge for a small button and see if it is up or down. This lets the camera know is the flash is up or down and if the button is stuck down you will hear the motor fire a few times and it will then error.
Unfortunately, this is one of the problems that starts to appear on cameras with pop-up flashes. You can hit the button and pull it up at the same time. Only other option is to send it to Canon to get it repaired.
or, Get an Speedlite like the 430EXII or 580EXII. The flash unit may make your camera bigger, but the results will be much better once you learn flash techniques.
Mar 12, 2011 | Canon EOS 550D Rebel T2i Digital Camera
Error 5
Hello the error 5 is a pop up flash issue and normally appears if your pop up flash is not opening properly. Try wiggling the flash open but do it gently! then clean the area it could simply be grit or dirt has got into the mechanism... let me know if this helps....
Dec 22, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
Mar 08, 2017 | Canon EOS 450D Digital Camera
CANON eos 450D error 05
I have had the same problem with my 450D. I have been living without flash on my cam for a month. Until I realized that maybe something liquid and sticky by chance got where the flash is...so i just trid to hold uo the flash my insrting my nail into the small space between the flash and the camera and tried to press the flash button. IT WORKED!!!
Oct 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My canon EOS 450D battery loses power within 5mins
If it's an original battery, call Canon, if you've only charged it once, I expect the camera is still under warranty. I've had lots of dealings with Canon Photography, the usually give extremely good customer service.
If it's a cheap one you bought of ebay - that's why!
www.yourhandinmine.co.uk
May 16, 2009 | Canon EOS 450D Digital Camera
The built-in flash on my Canon EOS 450D camera won't pop-up
Had the same issue and just tried this....and it worls [PS dont use the littel plastic hotshoe cover as this keeps the microswitch depressed]
If you manually 'help' the flash to open and it doesn't pop; the microswitch under the rails of your hotshoe is probably stuck in the down position as mine was. I used a toothpick top pop it up and it works now!
May 15, 2009 | Canon EOS 450D Digital Camera with 18-55...
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS 450D Digital Camera with 18-55 Lens Logo
411 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
