Question about Nikon N70 35mm SLR Camera
Would like to convert photo image from nikon DSCN to DSC.
For some unexplained reason many of my pictures are in DSCN format. I have no option at this time other than to process each one manually using adobe photoshop and once photo edited to any degree it then coverts to DSC. I have many to process and in total would be quite time consuming.
  • olympus4 May 11, 2010
    What camera are you using? You've posted your digital imaging question in the Nikon N70 film camera thread.
5 Suggested Answers
inlarry4
  • 98 Answers
SOURCE: WHY ARE MY PHOTOS FROM
Nikon CoolPix cameras, in all but a very few old models, save in .jpg format. DSCN is the filename prefix, not the file type like a JPEG or TIFF. Some models will also save in TIFF format, or in a very select few very high end models in .NEF (Nikon Electronic Format) RAW files, but unless you're using a Nikon DSLR this is highly unlikely. If the images will open on any other program that views jpg files, such as the programs supplied with your computer then it's not a formatting issue.
For example, the file names should, from the time the camera is new, begin naming as DSCN0001.jpg, DSCN0002.jpg, and so on. If you're trying to transfer directly from the camera, to an IPAD, it's likely a driver issue instead of a file issue. Just remove the card and use a $5 SD card reader, or plug the card into the IPAD if it accepts them. You may also search to see if there is software available for your camera to use on the IPAD.
Posted on Sep 04, 2011
  • 3 Answers
SOURCE: Can I transfer photos back to the card after editing the images?
Connect the cam to a pc and turn it on. Discard the box that pops up. Open windows explorer. You'll see Removable Disk listed in the folders pane. Drop all image files you want to transfer to a folder named Nikon under the Removable Disk folder. But the files must be named DSCNxxxx for the camera to understand them.
Posted on Sep 13, 2005
  • 395 Answers
SOURCE: opening RAW images from Nikon D70 on photoshop
A Photoshop Raw file is a Photoshop PSD file without a header. The header
information must be entered when the file is imported into Photoshop. The
raw format is used import and export bitmap data using a very simple,
uncompressed binary format.
Posted on Nov 30, 2008
evanusa
  • 197 Answers
SOURCE: took extraordinary pictures with nikon d40 but can't edit them
You have your camera set to RAW format. It is not a compressed file, it is a full size file. Opening this in editing programs will either crash your computer or will refuse to open because of the size of the file. They are not damaged but your computer cannot handle the files. You should take them to a photo shop and have them put the files on a cd and consult your manual to change your camera to JPEG format.
Posted on Apr 30, 2009
  • 11967 Answers
SOURCE: deletion option for "all images" has gone missing
Go into the menu and find "format"...follow the on-screen instructions.
Posted on May 04, 2010
Nikon error code
This error the manual says: please contact the Nikon service centre closest to you. You could try to switch of the camera, remove the battery and replace it and then switch the camera on again, but if the error comes back you should contact Nikon.
Don't forget to check if everything on you camera is ok.
Battery charged, lens correct mounted. Memory card with enough space to save pictures )(correct format)
Dec 30, 2013 | Photography
WHY ARE MY PHOTOS FROM MY NIKON COOL PIX IN DSCN FORMAT. I CAN'T EMAIL PHOTOS TO HUSBAND ON IPAD. PRIOR CAMERA (CANON SURE SHOT) TRANSFERRED WITH EAST.
Jul 19, 2011 | Nikon N70 35mm SLR Camera
Can the pictures in Nikon F65 transferred in computer?And can the pictures in that camera uploaded in Facebook? PS:This is an OLD camera
When you get your film processed, you can request that they be put on a CD. The CD can then be read on a computer and you can do whatever you wish with the photos. For existing photos, you can also have the negatives scanned and put on a CD. If you only have prints, they can also be scanned but the quality will suffer.
When I get film processed from my Nikon 35mm SLRs, I ask for only the CD and no prints. This only costs me $2, and I can choose which pictures I want printed--after doing whatever photo editing I want.
Any camera store can do this for you, as can many department and electronic stores.
Nov 26, 2010 | Nikon F65 35mm SLR Camera
How to see the picture after it has been taken for nikon f65?
The F65 is a film camera. You must get the film processed before you can see any pictures. If you have the setup yourself, you can develop the film. Otherwise, take the film to a photo processing lab (any camera store and many department stores, drugstores, and supermarkets either have them or have access to one) and get it processed. If you're shooting negative film, you can get prints. If you're shooting slide film, you can get slides. Either way, you can also request a CD containing the digitized images.
Again, the F65 is a film camera. The camera can't show you the images it has taken.
I have trouble taking indoor (low light) photos. pictures come out blury and the camera does not snap the picture properly i have a nikon 35 mm n6006 camera
Hi Rebecca--
The hardest thing about low light photography is balancing your available shutter speed to the amount of action you're trying to capture.
Here are a few things to try:
1) Try using a tripod. Steadying your camera during long exposures will greatly improve your image clarity.
2) Buy a faster film. You may need to increase your film's ISO setting. Try 400 to start, then go up from there. Remember, faster film always produces grainy images, and it usually costs a little more to process. If you're stuck with 100 ISO, you can always "push process" the film, where a given ISO is let to sit in its developer longer than usual--This will cost you more too!
3) Invest in a good flash system. Nikon has tons of hotshoe flash systems that rarely compromise the ambient light-mood of a given situation. Look for one that lets you aim the flash in different directions, and try to find one that will meter a light situation on its own.
4) Turn on the lights. If you're ok with losing some of the romance of an image, turn on some more lights to give you some more flexibility when making your exposure choices.
5) Open up your aperture. You may find that a lot less in depth of field will give you a lot more in image clarity and exposure flexibility. Shooting at f2.8 with only a birthday cake lighting your subject will grant you many more valuable shutter stops that shooting the same with f5.6.
Remember, Rebecca, if you're shooting handheld, you must do everything in your power to shoot with the quickest shutter speed available. This will cut down on the blurriness of your indoor images.
--Hope this helps.
Oct 06, 2010 | Nikon N6006 35mm SLR Camera
I have a Nikon N60. Can't take pictures outside
can you manually change your f-stop to faster shutting. When the shutter stays open longer, it will draw in to much light. If you have an option for only outside pics, then I would try that as well.
Feb 06, 2010 | Nikon N60 35mm SLR Camera
I see a spot on every image taken with my Nikon D70
This is probably dust on the sensor.
You can clean this yourself or you can send the camera to Nikon.
If you want to see what you have to do, search for "nikon d70 sensor cleaning" on the internet.
There are instructions and videos to help.
It involves taking the lens off and locking up the camera mirror using the menu option.
Then either blow it off with a camera blower or clean the sensor with a cotton swab.
I did this myself on my D80, it is not hard but you have to be careful.
Feb 02, 2009 | Nikon N70 35mm SLR Camera
Photos have streaks
Sounds like you are shooting at shutter speeds of 1/30th of a second or slower, and/or your flash unit is set to "slow sync" or a similar mode. Try shooting in shutter priority or manual, and using a speed of at least 1/60th but not more than F4's sync speed of 1/250th. If you are shooting a moving subject, you may find that this "problem" actually creates some very interesting effects.
Sep 24, 2008 | Nikon F4s 35mm SLR Camera
Nikon N70 35mm SLR Camera Logo
945 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
