I am trying to get my laptop to connect to the internet, I've got my router all setup just fine. The laptop shows my network on the available networks. But once I click to connect it says it cannot do so. I've got the Acer Aspire 5735/5735Z/5335 series with the Atheros AR5B91 Wireless Network adapter, running Windows Vista. What can I do?
  • msthenson Mar 08, 2009
    You do not seem to understand. The router is working fine or else I wouldnt be able to be on this page. I am on my desk top computer now. The problem I am having is from my laptop. It doesn't connect to the router wirelessly. It says that it cannot get access point from the router.
    Problem Solver:
  • 5 Answers
This happened to me once. you may try making sure that the internet you are using is connected correctly, if you have a desktop connected to the same router, than make sure the internet is working, and that ou internet provider isnt screwing up. thats how i fixed it. good luck...
Posted on Mar 08, 2009
I've setup the router (edimax 3G-6200n)and all was working well for a couple of days. This morning however, only the power light is on. The LAN network cable is fine as i connected it directly to
If the only light you have on is the power light, it is most likely dead. You try unplugging the router then plugging it back in to see if this clears the issue. If it does, the issue will probably come back. Your best bet is to replace this router.
Apr 04, 2012 | Edimax Computers & Internet
My Router Has Done This Probably Like 4 Times Already It Works When It's Plugged Up To The Laptop(Ethernet) But It Doesn't Show Up On The Wifi Connections To My Laptop I Reseted It, Took The Power Cords...
Goto control Panel -> Network and Sharing Center
Click on Connect to a network
It Will open a Small window on the bottom right corner of the screen
If it shows Not Connected , No Connections are available then
make sure that the wireless switch on your Laptop is ON
If it says Not connected, Connections Are Available and if its not showing your home network on the list of available networks , then
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 20, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot get on the internet
are you using wireless, dial-up, broadband, or dsl connection?
Nov 09, 2009 | Lenovo 3000 Y410 Notebook
Wireless network OK, NO internet
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url: or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url: and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Oct 04, 2009 | D-Link DIR-825 Wireless QuadBand Router
Laptop is showing my network
Hello write 1tune2,
1. Using a computer wired to the router, please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing or in the address field and click Enter or Return key.
3. For security reasons, the router has its own username and password. When prompted, please type in admin for the Username and password for the Password, both in lower case letters.
Note: If it doesn't take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you can't remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network.
a. Switch for the wireless adapter is turned off.
b. Distance between the wireless router and computer.
c. Possible wireless interferences.
Feb 12, 2009 | NetGear RangeMax WPN824 Router
Cannot get onto internet
disable the firewall on control panel.
check all the properties boxes on the network
connections and make sure firewall is disabled.
access the router setup and make sure that VCI is set to manual
and that you enter in the settings yourself (eg: 0,38 for aol broadband). Don't leave VCI, etc on auto, the router can't handle it.
Jan 09, 2009 | Buffalo Technology WHR-G54S Wireless...
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wireless connection
Access the routers admin page with the hardwired pc.  http://*gateway*  right click network status on pc and get gateway.  Google the model you have for the default passwords.  Setup your wifi security then do the same to your laptop and attempt to connect again.  Bad settings somewhere.
James Mac
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless router, laptop problems
Try to delete all the prefered networks. Right-Click Wireless Network Connection, View Available Wireless Networks. Click on Change the Order of Prefered Networks. Remove all prefered networks there and click OK. Now try to View the available wireless networks again, reconnect to your own wireless network and see if it connects fine. Post your feedback.
Jul 12, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
219 people viewed this question
David Payne
David Payne
