Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine wont drain out water
It is sayingclean pump ,it was also making a buzing noise
  • victoriam31 Mar 10, 2009
    My Duet 9200L stopped at 2:00 before the end of a wash cycle. Now there is some water left that won't drain and it won't spin. Every time I try to do the Rinse/Spin cycle, it just makes the buzzing noise and nothing happens. I also smell a very light burning smell, almost like a motor is spinning its wheels. Before there was an error code that came up that was F0 something, but now I can't get the error code to come up, so I don't know exactly which one it is. Help!!!
  • Anonymous May 16, 2009
    How do I remove the front panel of my whirlpool top load washing machine?
    Scholar:
  • 87 Answers
Is this a front loader like a whilpool HE series? If it is, simply remove the bottom panel by removing the 3 screws. There is a drain clean out right in front that could be plugged. That happens a lot. Just make sure you have something like a shop vac or pan so you don't get water everywhere. If that doesn't do it, possibly the pump impeller is off the motor and you'll need a new pump. Either way I think we can get this going pretty easy and in-exspensivly. Let me know what you find. The model number should also be behind the door and that would help
Posted on Mar 08, 2009
My dodge durango 2000 makez a buzing and grainding noise in the diferential
Front or Rear ?
Not the Transfer Case Chain ????
Change the fluids front,rear & transfer-probably
won't help, but you get to see if any metal comes out
Aug 11, 2014 | Cars & Trucks
My Panasonic panasonic pt-61lcx70-k is making a buzing sound. What could that be? Is that the bulb?
Someone would have to open and "listen" with it on to localize the problem--power supply, a coil or transformer, a ballast etc.
Nov 02, 2012 | Panasonic PT-61LCX70 61" HDTV
Buzing noise and failure to drain during spin cycly washer wont spin
This is a very common issue on these units, the drain pump needs to be cleaned. You can access the drain pump by removing the back panel of the washer. If you find that the drain pump has failed you can purchase the part from the link below.
http://www.appliancerepairlesson.com/
Mar 06, 2011 | Frigidaire ATF6000ES Front Load Washer
Buzing noise from power unit
What kind of system is it?
What "power thing" inside what?
It's a good chance its a ground loop issue.  Make sure the power cords aren't wrapped around each other or touching the speakers or running parallel with the speaker wires for more than a couple inches (interference transmitted into the speaker lines audible through speakers).
Aug 04, 2009 | Sony DAV-SA30 System
Kenmore model-c45072 will not start ant cycle and make a loud buzing noise (like electric noise)
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 43142 Front Load Washer
KUD101FKSS Kichen aid dishwasher does not work.
There are three tabs that are holding the whole assembly, accessible from the bottom...they need to come out. Only then you can remove or even move the assembly...
Apr 07, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool Duet GHW9150P Front Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal De
