Question about TechnoMarine TMC TMCS05
TechnoMarine TMCS watch moon phase does not seem to rotate?
I need to know how to set my wife's TechnoMarine TMCS watch moon phase setting, it does not rotate as the moons phase changes. Is it suppose to move as I lost the manual and am not sure if or how to set that?
  • 274 Answers
SOURCE: technomarine
Sounds like the main drive is not "engaged" or you are in "stop watch" mode. Check to make sure you are in the correct mode. Then check to see if you can change the hour/minute hands. Reset the time and re-engage. See if that corrects the problem. (You've probably have done this already)
The watch has a 2 year warentee plus because it's water resistant down to 330 feet, I would take it back or to an authorized dealer to have it repaired. Other wise you stand the chance of damaging as really nice watch. And while you are there have them explain all the features. Really is a nice watch.
Posted on Nov 18, 2007
VOTIT
  • 2071 Answers
SOURCE: Technomarine NT02 sport
First find the set button and press it for 15 seconds the number is going to flashing,that is the time you going to set,go to mode button there where you going choose to set ,the hour; the date ;the alarm and whatever you like to set.to set the time first the hour and the minutes by the opposite button is use to scroll up the number and to scroll down.after you finish set the time ,there is you going to choose normal time 12h or military time 24h.That all lyod message me whatever the result.
Posted on Jun 18, 2008
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Posted on Sep 29, 2008
escapement
  • 2334 Answers
SOURCE: i need to remove watch links
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
SOURCE: Sunrise/Sunset Time and Moon Phase wrong on watch!
Just in case you're still interested in a solution. Your watch uses a geographical location and the current date to estimate the sunrise and sunset times. While the date (and time) information is, most likely, set on your watch correctly, you, probably didn't specify the geographical location (latitude and longitude, as well as the GMT correction for your time zone). Having setup correctly these parameters you'll enjoy the precise sunrise and sunset time. Good luck!
Posted on Feb 04, 2010
How can I set?
Shirley, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 17, 2016 | Watches
Tide indicator not keeping time
http://www.watchrepairsusa.com/MB&F/watch-repair
Dec 28, 2013 | Timberland Mens Dress Watch QT7111102
I have a Merona watch with a moon and stars in the face and a calendar at the bottom and it is from target . I can't set the calendar. Can you help?
You have to pull the winding stem halfway out so that it's not fully extended but not pushed all the way in. then you can turn it to set the date. As for the moon and stars, it's to show the phase of the moon. You just have to wind the arms around until you get the moon in the right position. Use this site to set it correctly: https://www.watchnetwork.com/moonphase/index.html
Apr 18, 2011 | Watches
I purchased a Marco Max watch with day, date and moon phase. How do I set each of the dials to match the correct day of week, month and hour?
The crown has three positions. The A position is when it’s pushed all the way in. You can’t set anything in this position. The C position is when it’s pulled all the way out. The B position is the click between all the way in and all the way out. My biggest problem is that I read the directions to mean that there were FOUR positions. I didn’t realize A was all the way in. I thought there was three pulled out positions.
To set the day of the week (Sun, Mon, etc.): Pull the crown all the way out (position C) and turn the time to just after midnight. The setting will click to the next day. To advance it an additional day, you don’t have to turn the hands another twenty four hours. You can turn the hands backward to before midnight (you will see the day of the week setting click a little, but not go backwards), then turn the hands past midnight again.
I recommend setting the day of the week setting to YESTERDAY. You’ll see why later.
To set the date: 3341598183_60e77d12e5.jpgPull the crown one click out (position B) and turn the crown away from you (clockwise). This will advance the day indicator (it looks like a second hand). To set the month, you have to keep turning until you get past an entire year. There is no separate way to set the month. To make the correct month show, you must keep turning the crown past every day of the year until you get to the correct day.
I recommend setting the date to YESTERDAY. I’ll explain why later.
To set the moon phase: Pull the crown one click out (position B) and turn the crown toward you (counter clockwise). To find out what phase the moon is currently in, here are a couple of websites:
Once again, set it to the moon phase for YESTERDAY.
To set the time: Pull the crown all the way out (position C) and turn the crown either away or towards you to set the time. Keep turning the time away from you (clockwise) until you get past midnight. Once you get past midnight, ALL the settings should change (day of the week, date and moon phase). Now you KNOW you’re on today’s date at just after midnight. Set the correct time and your Luar watch is ready to go!
Review 3342440924_5fa48ca4fe.jpgMany of the Swatch enthusiasts were disappointed that the Luar is a battery powered watch instead of an automatic. With a price tag of approximately $450, it’s a little much to expect an automatic with a real moon phase. I’ve talked at length about what I desire in a watch here:
My desires have changed a lot since that day nearly four years ago when I went looking for the perfect
To set the date: Pull the crown one click out (position B) and turn the crown away from you (clockwise). This will advance the day indicator (it looks like a second hand). To set the month, you have to keep turning until you get past an entire year. There is no separate way to set the month. To make the correct month show, you must keep turning the crown past every day of the year until you get to the correct day.
To set the time: Pull the crown all the way out (position C) and turn the crown either away or towards you to set the time. Keep turning the time away from you (clockwise) until you get past midnight. Once you get past midnight, ALL the settings should change (day of the week, date and moon phase). Now you KNOW you’re on today’s date at just after midnight. Set the correct time and your watch is ready to go!
Aug 11, 2010 | Watches
How can I recieve a manual for my Gevril Chelsea?
hi i have a Gevril automatic watch and it said in the manual never try setting the watch between 21:00 - 04:00 , that would damage the internal parts
Nov 25, 2009 | Gevril 18K Chelsea Swiss Automatic...
Set the moon phase on Longines
Good day Sir, here's the link below where you can find your users manual.
hope it will help you.
manual
have a nice day.
Mar 29, 2009 | Longines L2.673.4.78.6 Watch
Need to change the battery
Go to the watch repairing shop near by your place and get it reapired.
OR let me know your address so I can provide you the repairing center near you.
Thanks.
Mzas
Jan 03, 2009 | Colibri Pocket Watch Gift Set, Chrono...
Trouble with Fossil ME1014
I looked at a picture of the watch. I see the date. the dial that is right below the hands is a moon dial which does the phases of the moon & below that you have a separate second hand. A lot of times on a watch that looks like that if you pull the crown where you set the watch with out half a click it will set the date if you turn it on way and the moon dial if you turn it the other way. To set the moon dial on the watch you need to put it on the full moon when the moon is full again then it will keep up with the phases of the moon. I hope this helps.
Mar 09, 2008 | Watches
TechnoMarine TMC TMCS05 Logo
74 people viewed this question
Top TechnoMarine Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you a TechnoMarine Watch Expert? Answer questions, earn points and help others
