FixYa.com
Tags:
IBM EXP400 External SCSI Storage Enclosure p/n 17331RU  Drive Case
IBM x345 + EXP400
By Duke - usenet poster
I've been reading some older posts to figure out how to get either
4.10 or 5.2.1 running on an IBM x345. Here's what is in this
particular machine...
x345, 6 internal 10k 146GB disks.
An internal U320 LVD SCSI Adapter
An EXP400 External Array with 14x146 10k drives
What I found was this...
But I'm curious to know...
a) does this work for arrays setup using the ServerGuide
configuration CD delivered with the hardware?
b) does all this actually work? :)
c) what kind of error reporting is there, if it works, to the
Operating System?
Hopefully we won't have to go the "luser unix route"
Thanks.
mailing list
To unsubscribe, send any mail to ""
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Mini Me
Mini Me - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Keep in mind that the ips driver can give you some trouble in the 5.2.1.
branch. The ips.h was wrong, so that the serveraid was not recoqnized. Use
the latest 5.2 current and then updated to 5.2.1 release, will keeping the
ips drivers from the current source.
Also important is that the ips driver doesn't support the scsi pass-through
bus. So if you use a tape drive (or LTO / DLTO etc) use the onboard
controller (LSI). The ServerRAID 6M is a hell of a card, very fast in RAID
5!!. Uses the latest Xscale processor from intel and has standard 256mb
battery-cache onboard.
Oorspronkelijk bericht
Van:
[mailto:]
Verzonden: donderdag 12 augustus 2004 7:52
Aan: J.Molinger
CC:
Onderwerp: Re: IBM x345 + EXP400
On Thu, 2004-08-12 at 07:45:24 +0200, J.Molinger proclaimed...
I'm not sure of the exact ServeRaid controller model -- it's
probably a 6M or the model right below that (if there is such a
thing!).
Did you have to do any magic besides what you send in the url?
Also, slightly offtopic for this group, but I've seen an x345 dual
processor "freeze" after a brand new installation once the console
comes up. Going into single-user mode makes things freeze when the
prompt for what shell I'd like to use comes up.
I'll try it in about 12 hours :)
mailing list
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
thing!).
mailing list
Solution #3
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
I have approx. 8 IBM x345 machines running FreeBSD (5.2.1 release). They
have all a ServeRaid 6M controller because there is also a LTO drive
connected. Works fine no problem. What kind of RAID solution are you having.
We also have the EXP400 (very nice indeed!!).
I should go for the 5.x Freebsd. 5.3 will be released very shortly.
The ServeRAID cd works. If else you can configure RAID1 through the bios of
the LSI controller.
See also
d=346895&sortby=lastpost&sortorder=descending
Greetz
Jeroen Molinger
Van: [mailto:]
Namens eric
Verzonden: donderdag 12 augustus 2004 6:20
Aan:
Onderwerp: IBM x345 + EXP400
Operating System?
Thanks.
mailing list
mailing list
Can you Help with these Drive Cases problems?
Drive Cases
Down-loaded vedio not...
Sir, I had downloaded some... Answer This...
Drive Cases
Firewire not recognised
Hi I have a Plumax  ?... Answer This...
Drive Cases
Nano shuts off and won't turn...
I bought a nano zen plus last... Answer This...
Drive Cases
external hard drive
light blinks and makes noise... Answer This...
Drive Cases
Password protect folders on my...
I have a folder that has... Answer This...
Repair Service
Find Drive Case Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
