Most economical use of heating
We have just had a honeywell programmable room thermostat fittd with our new bolier. Could anyone advise me what is the most economical way to use it please? We're out at work from 7.30am and get back about 3 so the heating doesn't need to be on all the time. It has 6 settings and I only need to use 2 in the morning and 2 in the afternoon/evening. (On & Off times)but I'm not sure what to do. I would really appreciate some help
  • 189 Answers
There should be "how to"program instructions with the new thermostat. If you had this professionally installed... the tech should have set it for you. All T/stats are different. I suggest that you "do not" set the temperature up or down more than 4-5 degrees. If you go back more than this you are defeating the purpose of the program. Yes you will save $$$ when it is set down to a lower temp. BUT.... when you turn it "back up"... not only are you heating up the ambient air in the house that you lowered. You are also heating up the couch, the walls, the drapes, the table, ect . this can possibly use back up all that you saved and then some!
I am a retired heating contractor. I have been in the business since 1977. I now teach heating and cooling to high school students at a career center. I have experimented with most thermostats at my own home. I want to know them before I would sell them. From my own experience I found that the most economical savings is to find a comfortable temp and leave it alone. It is cheaper to maintain a constant temp then to keep playing with it.
Posted on Mar 08, 2009
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ... > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
I have a new Honeywell Round Non-Programmable Heat Only thermostat MFG # T8775A1009. I turned it down to 50 degrees. The room temp. is reading 70 degrees and heat is coming out of my baseboards. Why is...
Make sure the switches on the back of the thermostat is set for hot water heat. If you have more then 1 zone you may a stuck zone valve or a short in the wiring somewhere keeping the boiler on.
Apr 02, 2010 | Honeywell Programmable Thermostat Heater
Hot Water But No Heat In The Radiators
bleed radiators and check for dirty flame sensor and clean it with steel wool
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
229 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
