Wont print i sent my stuff to print and it does nothing but it will scan and push paper out no printing though
  • Jim Scott May 11, 2010
    have you got the drivers set up correctly ?? when you scan can you see the document on your monitor ??
  • 24 Answers
Friend,
Please print an internal test page. If this only will produce a blank page as well, replace the toner/ink cartridges/print heads.
//Al
Posted on Mar 08, 2009
My calibration page printed on plain white text paper
When you calibrate the 5100 AIO, first, you push in the photo paper drawer until it CLICKS. Next, print an alignment sheet. It will use the photo paper. Pull the drawer out, put the printed sheet in the scanner bed, with the arrow in the right hand corner, closest to you. Press start and it will scan and print a sheet on full sized paper.
If your initial scan doesn't print onto photo paper, you don't have the drawer pushed in the whole way. There is a definite click and the green light will turn on.
May 14, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Hi, my canon i80 printer wont feed paper through
There is only one solution to the problem with the i80. Here it is: there is nothing jammed. This problem is the result of the top of the printer being pushed down, effectively crushing the paper feed path by a sixteenth of an inch, right at the center of the machine. Likely this is the result of being carried in a travel bag full of other stuff, like the power supply, or from things being placed to rest on top of the printer. The solution is to open the two top covers, to grasp the main steel bar that runs the entire width of the printer with a pair of long-nosed pliers and to simply apply upward pressure. This will, in turn, lift a black plastic paper guide that has been pushed down into the path of the paper by the slightly bent metal. The printer will happily feed paper after this relatively simple fix. Mark the problem up to bad industrial design (though the mechanisms of the printer are otherwise ingeniously well thought out).
Sep 16, 2010 | Canon i80 InkJet Printer
Orange exclamation point is blinking, screen says "replace supplies", but it says that all the time. Nothing will print or copy. It will scan the document like it's going to copy, but then just stops....
I'm a tech on that printer. That's a generic message if one cartridge is at 0%. When one toner or drum reach 0 it wont print even though you don't use that supply. The unit should show the level on the screen, if one is empty replace it.
Aug 04, 2010 | HP LaserJet 2840 Printer
Recived faxes only print out blank pages
Someone sent you fax upside down. If your machine prints and copys OK, it's not your machine.
Aug 19, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Design Jet 450 C won't print
***it could be a communication issue: port setting, cable, ecc.
It could be a driver problem too. You need a compatible version with your Windoes version.
Please read here
www.plotterdriver.it
CAD & Prints
Mar 06, 2009 | HP DesignJet 450c InkJet Printer
Canon MP520 can print but not scan
I had the same problem. The all-in-one driver download doesn't include the stuff you need for the scanner. Go to this link (canon), click "OSX" on the dropdown list for what os you're using, then click "mp520sosxsd1391ej7.dmg" under "MP520 series Scanner Driver Ver. 13.9.1 (Mac OS X 10.2/10.3/10.4/10.5/10.6)." It doesn't take long to download and completely fixes the problem.
Feb 28, 2009 | Canon MP520 All-In-One InkJet Photo...
Hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Dec 10, 2008 | HP LASERJET P1006 Printer
Printer says out of paper. paper added still wont print
The solution to this is bizarre but worked for me.
In Vista press the windows key and R button. The Run window opens and in the run window type services.msc and then press Enter.
2. Locate Print spooler from the Services window which opened in the previous step.
3. Right click on it and select Restart.
Your printer will print a self-test page but then should be good to go.
Nov 22, 2008 | HP PSC 1210 All-In-One InkJet Printer
Printer wont print
On some of these inkjets, if the color cartridge is out or dried up from little use, they will not print using just the black cartridge.
Mar 30, 2007 | Epson Stylus Color 740 InkJet Printer
59 people viewed this question
jasbo
jasbo
