Question about Bialetti Mukka Express
Espresso irregularly spurts out the center post
I recently replaced the gasket and filter in my Bialetti 6-cup pot with genuine Bialetti parts.
Now instead of gently flowing out of the center post, the espresso takes a long time to start brewing, and when it does, it forcefully spurts out of the center post, making a huge mess, and it takes a long time for the pot to finish brewing.
I thought it might be that the grind is too fine, but this grind works great in my 3- and 9-cup pots.
HELP! What's wrong?
Coffee spurts from the middle of my Mukka Express, where the upper part is connected with the heater unit.
  • 22 Answers
Could it be that the gasket is oversized and it covers the small holes ?
Posted on Oct 28, 2009
2 Suggested Answers
  • 7 Answers
SOURCE: Espresso irregularly spurts out the center post
It IS the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Funnel had NOTHING to do with my problem. Also cook on medium to low heat. High flame seems to make the problem worse.
Posted on Jul 17, 2009
My Moka Easy Bialetti electric espresso maker switches off before all the water has been percolated through into the upper pot. I have recently replaced the rubber seal etc. at the base of the pot.
I emailed support at Bialetti and here is what I got:
Check the coffee funnel for any dents around the edge of the funnel. Normally if this brewing problem happens after changing a gasket the problem is a dent or the funnel is out of round and the new gasket isn't formed to it like the old gasket was. Don't bang the funnel to get grounds out or it may dent or get out of round. Try pulling the funnel over to one side in the water chamber and if you see a space on one side pull it tight with the other finger to bend back into shape if possible or replace the part.
Take the gasket and filter plate out from under the upper unit and hold the filter plate up to the light to check for any clogs right in the center where the coffee brews up. You should be able to see through all the holes in the filter, brush clean if needed
Jan 13, 2011 | Bialetti Moka Easy 6-Cup Espresso Machine
Where can i get a replacement gasket for a principessa lavazza balzono model number 53190B/82
Try a Bialetti spare. I have had success with a Bialetti gasket for this identical model having searched for the correct Lavazza gasket for years. Mine came from from Pumphrey's Coffee in the Grainger Market in Newcastle uopn Tyne, but any Bialetti stockist (it's a very common espresso maker) should be able to get you one. It's probably the 6 cup size you need.
Dec 03, 2009 | Lavazza Coffee Makers & Espresso Machines
Barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Jun 28, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Coffee has started becoming weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Apr 21, 2009 | Bialetti Mukka Express
Feb 09, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
6 cup only making one cup
I just had this same problem and after reading this blog I went downstairs, tightened the pot down more and it worked! I usually don't tighten it this much, but will continue to tighten it down hard until the gasket is broken in. Thank you sooooooo much!!!
Jul 15, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Bialetti sputtering after gasket replaced
Flame is too high and the top is not screwed tightly enough to the bottom. Also make sure there is enough fine ground coffee in the funnel.
Feb 20, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Bialetti Mukka Express Logo
441 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Frank Russell
Frank Russell
Bill Boyd
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
