LG DVB418 DVD Player
Problem for LG DVB418 DVD Player
Snowy reception on TV with LG DVB418
By lewittons on Mar 08, 2009
Have the coaxial cable from my antennae going to my new LG DVB418 and it is picking up excellent digital TV signals. Problem is my TV reception (using the analogue tuner in the TV) is now snowy, when this was never a problem before.
Any ideas on why this is now occuring and anything I could do to fix this.
Comments:
Mar 09, 2009
- Thanks for the quick response.
The aerial cable goes from the wall connection to the 'aerial in' on the DVD player and there is an 'aerial out' from the DVD straight to the TV. The DVD player is picking up digital channels, and the TV's analogue signal has a picture, but it has some snow on some channels and interference lines on others. The setup was similar with my VCR, and the TV signal was clear.
Could the DVD have a poor internal connection that is causing the signal to deteriorate from the aerial in to the aerial out? Would a splitter be better, to split the signal from the wall to the DVD and the TV seperately - or is this going to have the same problem.
Best Solution
posted on Mar 08, 2009
Helpful)
jimscott531
Rank: Wiz
Rating: 83%, 131 votes
have you got both cables going into your video ?? if not you need a video splitter to input both the digital and analogue aerials then have a coaxial cable going to the tv
Comments:
Mar 11, 2009
- hi, as for the dvd having a bad connection it is possible but i doubt it have a look on the back of the dvd player and see if there is a set of 3 rca sockets red,white and yellow are the main colours and see if they are on your tv as well if so connect with a cable this is the best set up because it by passes the tuner on the tv if you haven't got these let me know i have a few more ideas regards Jim
Was this helpful?
Yes
No
Popular Solutions for LG DVB418 DVD Player
Questions and Unsolved Problems for LG DVB418 DVD Player
Do you recommend LG DVB418 DVD Player?
Answer
Answer
hi with certain dvds my new lg DR386D dvd player comes up with the message cannot playback due to... (More)
Answer
i have a toshiba laptop using vista the dvd player draw keeps popping out for no reason even whether... (More)
Answer
I am experiencing problems with my LG DVD Recorder (model DR386D). The recorder works most times,... (More)
Answer
there is no volume. I have turned off both the TV and DVD player and still no sound
Answer
Hi - I am in Austraolia, region 4. I want to unlock my LG V9120W DVD player. What should I do?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG DVB418 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
